7050 Sphinx
Discussion in 'CNC Mills/Routers' started by Michael.M, Jul 15, 2017.
  1. Sprags
    Sprags Well-Known
    As everyone else that has posted....this design and build looks very good. Now that I've seen this build I sure would like to have a machine like this. I just started reading through the discussion posts as well as everything else and I'm wondering if there is a list of materials and components including electronics and motors somewhere amongst everything here?
  2. Michael.M
    Michael.M Veteran
    If you do a search for "Kyo Sphinx" you should be able to find the original build guide with all the information you need. There's also a link to his designs & builds under his profile.
  3. Giarc
    Sprags, It was originally called the CBeam CNC then changed to CBM Sphinx and eventually it evolved to Sphinx. Here is the link C-beam Sphinx. It has a great manual and he did videos for how to set up the electronics. Under the parts list tab, there is a download link for the file.
    DA98520 and Michael.M like this.
  4. Michael.M
    Michael.M Veteran
    Thanks Craig, can you tell me how you add a link like that? I can add that on the front of the page.
  5. Michael.M
    Michael.M Veteran
    I added what I thought would be a link at the top of the page but it's not working out
  6. Sprags
    Sprags Well-Known
    Thank you for the quick response...just out of curiosity is there a chance anyone can tell me a ballpark cost for all the parts for this machine?
  7. patdee
    patdee New
    MUCH higher than one of OpenBuilds "kits". So best to go with a kit, than to buy all the parts and build one; if price is your limit. One caveat. You will have to settle for things you may not want and possibly be frustrated with, when you say, "If I had only thought it out better". Think it out carefully; there is probably no rush.
    I chose to buy the parts. It is very high. Approaching $3500.00 now. So I am exceedingly blessed in having the money without strain; to go for "full bore". Not recommended for most budgets. But I am loving every minute of it. Thankfully, it did NOT come from me..............I assure you! Remember, He turned 2 small fishes and 5 loaves of bread; and turned it into enough food to feed 5,000 people; AND...................when they were done filling their bellies, they gathered up 12 baskets full of food! Believe it or not!
    Praise Jesus.
  8. Sprags
    Sprags Well-Known
    As part of job as an engineer I estimated costs for fabricating machined parts for the medical industry. I also managed the build as well the design of a robotics de-burring and polishing system for jet engine components along with part transfer systems for an automotive manufacturer. So I like think I can put a pretty close value on machine components. I do lack extensive experience with electronics though.
    My estimate was around $4000 which is something I can handle. So if I can come in under that even better. If it's a little over I can handle that too.
    This build is looking like something I'm going to go with.
  9. patdee
    patdee New
    That is awesome Sprags. My best to you in your endeavor.
    I am not an engineer. Just a lowly electronics technician for 45 yrs (now retired 21 yrs). I am having some real problems in understanding G-code and the other newer state of technology mandatory for CNC. I would hope I could ask you some questions when you get yours built.
    I have some pictures of how far I am as of this moment if you care to see the build in its infancy. I will be making more this coming week. As I have a bunch more parts that were delayed in shipping.
    Thanks,
    pat
  10. Sprags
    Sprags Well-Known
    If I were you I'd give myself more credit than you have...but humbleness is a virtue. I'd be happy to help with the g-code programming. Message me with any questions.
  11. Michael.M
    Michael.M Veteran
    Hey I upgraded my air blast nozzle and I can't recommend this one enough. I have full control of air pressure and coolant (future) but this allows me to use a fairly low performance air compressor. DSCN1429.JPG DSCN1424.JPG
  12. Michael.M
    Michael.M Veteran
    Hey Sprags I also want to say that I started this build with really minimal tools and materials. So this was factored into my running total.
  13. Michael.M
    Michael.M Veteran
    This air nozzle I just posted is only $20 on Amazon. After using the different nozzle I had prior to this, I can say this new nozzle is a tremendous value.
  14. Michael.M
    Michael.M Veteran
    Here's a picture of the funky magnet bracket I made for the Z axis hall effect sensor DSCN1452.JPG DSCN1455.JPG
  15. Michael.M
    Michael.M Veteran
  16. Michael.M
    Michael.M Veteran
    I really need to get around to add a parts list for my build. Make sure you contact Chris from Blue Ox via email (plate set). I went with the taller plate set and 4 wheel X + Z gantry plates.
  17. Sprags
    Sprags Well-Known
    Another friend from DIYAudio convinced me I could build a Tubelab.com SSE tube amp since I built a Tubes4HiFi.com VTA ST-120 Dynaco type tube amp from a kit. A year later I'm still working on it. Electronics baffle me.
  18. Michael.M
    Michael.M Veteran
  19. Giarc
    I just open another tab in my web browser, find the page I want, and then highlight and copy the web address from address bar at the top and and then paste it into the page I am writing on. Also, if you want to point someone to a specific post in this forum, click on the post number and a box will open up giving you the option to copy and paste it somewhere, or to share it on a social media site. For example, this post i am replying to (#156): 7050 Sphinx
    Now it is your turn to try it by posting the amazon link for the nozzle control. Basically the one I have is just an on/off valve. :)
    GrayUK likes this.
  20. Michael.M
    Michael.M Veteran
    https://www.amazon.com/gp/product/B071DXGGP4/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    Here you go buddy. It's actually a few dollars cheaper now. I see other sellers charging quite a bit more for the same nozzle so snag one up!
  21. Michael.M
    Michael.M Veteran
    I also had one with just an on / off lever and it was ok but this one is night & day better
  22. Michael.M
    Michael.M Veteran
    I actually bought another one because one on each side would be awesome. I was really impressed by the quality. I mean I don't think the more expensive sellers could possible have a better nozzle
  23. GrayUK
    I'm sorry if you have already said, but what pump do you use for your constant air supply?
  24. Michael.M
    Michael.M Veteran
    Oh I use a California Air tools compressor model 1P1060S. It's pretty quiet but it was also only $100 on Amazon.
    GrayUK likes this.
  25. Michael.M
    Michael.M Veteran
    I'm sure one of those aquarium pumps would work also but this compressor can also serve other purposes.
  26. Michael.M
    Michael.M Veteran
    I was originally going to use a heavy duty aquarium pump but I figured in the end, this option wasn't much more. The compressor itself is pretty quiet but it has a small tank.
  27. Cole
    Cole New
    Hey Michael, I was wondering what router you bought to mount on your machine? I want to build my own cnc mill right now too. I am looking for a router I can mount that will take an end mill that can cut aluminum. I was curious if you had any thoughts.
    -Cole
  28. Michael.M
    Michael.M Veteran
    The router / spindle I chose is an 800w Huanyang spindle & vfd combo. You can find the set for about $300 plus you have full control over rpm
  29. Sprags
    Sprags Well-Known
    By chance is that spindle water cooled?
  30. Michael.M
    Michael.M Veteran
