v-slot for OpenSCAD
Discussion in 'CAD' started by Franco Ponticelli, Aug 3, 2014.
  1. Franco Ponticelli
    Since I was not able to find any v-slot for OpenSCAD, I made my own:
    https://github.com/fponticelli/smallbridges
    Right now they are quite high-def and I might add some options later to make them simpler for performances.
  2. Glenn West
    Nice. What about a cutout version.
    It would make it nicer to build corner components.
  3. Franco Ponticelli
    What do you mean exactly? I am not sure I understand ;)
  4. Glenn West
    In building a corner component, or a frame, (In delta we call it a vertex), its handy to "subtract" a vslot
    from the body.
    Example code of something I was doing this morning.
    When you use this, you get more complexity that needed. It results in non printable part.[​IMG]
    include <MCAD/units.scad>;
    include <MCAD/materials.scad>
    use <MCAD/shapes.scad>;
    use <smallbridges/scad/bom.scad>;
    use <smallbridges/scad/vslot.scad>;
    module body()
    cube([50,50,50]);
    module vslot_cutouts(){
    $fn = 32;
    translate([35,35,0]) rotate([0,0,90]) vslot20x20(200);
    translate([15,0,35]) rotate([0,90,90]) vslot20x20(200);
    translate([0,15,15]) rotate([0,90,0]) vslot20x20(200);
    module corner()
    difference(){
    body();
    union() {
    vslot_cutouts();
    corner();
  5. Franco Ponticelli
    Oh I see. I was planning to make a simplified version of it to speed up rendering time but to be honest I just didn't feel the need yet. If I recall correctly commenting out the part that subtract the holes on the corners and the one in the middle should be pretty trivial. Feel free to create a pull request if you find yourself adding interesting features to that file.
