Drag knife question
Discussion in 'CNC Mills/Routers' started by artfuturo, Feb 25, 2018.
  1. artfuturo
    artfuturo New
    Hi guys
    I have a question about drag knives. I am in the process of building a Workbee and among a lot of other things, I will be cutting wood veneer, very thin slate veneer (0.3-0.5mm slate on 0.5mm cotton & glue backing) and leather and probably some vinyl as well. After some research, I realised that the typical vinyl knife won't cut it with thicker materials like leather (up to 3.5mm).
    The only solution I came across consistently that seems to be capable of dealing with my rather diverse requirements was the Donek drag knife. It appears very well established, there is a lot of experience in integrating it into Vectric SW (which I am using) and it has aides to adjust the g-codes to cater for the directional moves that are very specific.
    There is only a little catch - it is very expensive, roughly about £230 if I purchase it from a UK dealer and about $294 if I buy it directly in the US.
    My questions:
    • Has anybody in this forum used a Donek knife? What materials did you cut? What were the experiences?
    • What tools did you use to adjust the g-codes for the directional changes?
    • Are there alternatives with similar capabilities that are cheaper?
    Thanks very much for any feedback.
    Phil
  2. Kyo
    Kyo Veteran
    Hello Phil, hit up Brain for his Drag Knife files "Here". Cheaper then a good cup of coffee and free to make if you have the right scrap :thumbsup:. It is one of the projects I want to get to this year myself. I mostly want it for cutting leather and custom boxes / packaging. He has a series of videos on how to make it as well.
  3. artfuturo
    artfuturo New
    Hi Kyo
    great feedback, thanks. Do you know how you have to adapt the g-codes with this knife? Do you do it in the same way as you would do it with a Donek? Is the geometry the same as a Donek?
  4. Gary Caruso
    Estlcam has build in feature for drag knife, i have not tried it yet, but plan on soon.
  5. David the swarfer
  6. stuart wallace
    Do you happen to have a copy of this? The link no longer works. Cheers
  7. Giarc
  8. stuart wallace
  9. David the swarfer
    the bCNC GUI for GRBL can also do it, in the tools section. Note that you can use that tool to add the drag knife corners and save the Gcode, then load that into OpenbuildSCONTROL to run your machine as usual, so no need to completely switch interfaces.
  11. stuart wallace
    Thanks y'all. I have a call today with the Donek guy to work this out-- probably first step is to fine tune the blade offset. I appreciate it. Cheers.
  12. rbrown55
    rbrown55 New
    What would you use to crease cardboard in conjunction with the knife cutting for the cut outs?
