Looking into connecting a DuetWifi conntector to DQ542MA Driver Hoping for some help, so i dont screw this up lol. Let me know if you guys see any issue with this setup.
Ok i am not sure whats up.. at first i wired up one.. seemed fine, but now after i wired up all three when i turn it on and try to move the steppers.. they Hold strong, but dont move. DQ542ma are being powered from one set of 12GA wires. and then split into three (one for each driver) every thing is mounted to a wood board.. could this be a grounding issue. Red light shows on DQ542MAs error code says Motor doesn’t run, but maintains holding torque Without input pulse signal Adjust PMW & signal level on DuetWifi firmware i have the driver configured like this M569 P5 S1 T5:5:5:0 for pulse timings
disconnect "enable" maybe? Assuming the rest is connected correct. I think you need to power that breakout board with 5vdc? Or check that there is already 5Vdc on the small side headers..
