4' by 2' Lasercutter
Discussion in 'Laser Cutters' started by MTO, Sep 25, 2017.
  1. MTO
    MTO Well-Known
  2. cathode
    cathode New
    I like your vacuum table. I'll have to do something similar. how tall is the void inside the vac table, and what do you use to move the air?
  3. MTO
    MTO Well-Known
    I basically used 2 sheets of 4mm plywood. The top and bottom are single sheets each, and the middle layer is off-cuts, so the void is only about 4mm. I just use a simple cheapo shopvac. I was mostly inspired by this video:
  4. cathode
    cathode New
    Cool. That’s much thinner than I thought. How good is the suction?
  5. cathode
    cathode New
    May I also ask you about the L-cheapo laser? Was this the one you used? L-Cheapo
    What are you thoughts on it so far, and could you post pics of the mount? I’ve been hunting around for my laser and the 10w is at the top of my list.
