OpenBuilds WorkBee 1010
Discussion in 'CNC Mills/Routers' started by Mark Carew, Jun 15, 2018.
  1. stargeezer
    stargeezer Journeyman
    Hi Torr,
    I've not built my 1010 yet, but I''ve built several other hobby CNC machines and I feel very confident in telling you that it will work just fine with 360.
    Buy it, build it, have fun with it!
    Larry
  2. Torr Ramdass
    Hey Man, TY for the response. I am going to get it as soon as i can. Hoping to be able bringing my pc mods ideas to life with it :), among other things.
  3. Craig Hollabaugh
    Craig Hollabaugh Well-Known
    Matthew Bates and GrayUK like this.
  4. GrayUK
    I'm there, I'm there. :thumbsup:
    Let the journey begin :D
    Till the Chips Fly!! :thumbsup::thumbsup:
  5. stargeezer
    And I'm ready to start building! There's a mini mill on my bench I started just before I took up residence in a hospital for the first 3 months of the year and now I'm ready to move on! I put the electronics on it today and latter tonight I hope the to get the firmware installed and tested. I'm not too sure what shipping times are like with the new kits, but I hope it's not too far out. I'd like to get it done for a special project for my son's wife.
  6. Craig Hollabaugh
    Max, that spindle mount attachment to Z c-beam is different then openbuilds.
  7. Mark Carew
    Hey guys just a heads up. We updated the build with an easier to understand xPRO controller diagram in tha main build page that should help to see how to easily wire up the machine to the xPRO controllers.
    Hope this helps.
    Adam Filipowicz likes this.
  8. stargeezer
    Thanks for the heads up Mark! I was just looking at that. This will be my first project with the X-pro board, so any warnings will be much appreciated. I did order the Smoothie Board with it as well, just in case, but I'm sure I'll have no problem and can use the Smoothie Board on my upcoming lathe build.
  9. Giarc
    Yes. You can design things with fusion 360 and cut it with any of these cnc machines. I use fusion 360 to design pretty much all of my stuff now. Some I 3d print, some I mill out of aluminum, plastic, or wood. I used to generate the gcode with Fusion 360, but recently I started using estlcam.
  10. stargeezer
    Can somebody tell me the outside dimensions of the 1010 Workbee? I'm putting together a workspace for it to rest on once mine arrived and assembled but can seem to find these dimensions - spoilboard, yes - but not the outside finished space required.
    Thanks!
  11. TrishC
    TrishC OpenBuilds Team
    Hello stargeezer. Attached is an illustration which includes the "Footprint" of the 1010 Workbee.
  12. M. A. Wilson
    Stargeezer, according to the SketchUp model, the 1010 is approximately 1116mm x 1116mm with the motors. Without, it's approximately 1007mm x 1012mm.
  13. Keith Kimura
    I just completed the build of my Workbee 1010, awesome looking machine and very excited. But now I'm in a quandry; I don't know how to connect all the motors, CNC xPro Controller, 24v Meanwell Power Supply, and computer. Can I get some help?
  14. Craig Hollabaugh
    GrayUK likes this.
  15. Giarc
    There is also the instructions for hooking up the xpro at the website for that product or their wiki Spark-Concepts/xPRO
  16. stargeezer
    I am now at the testing stage with my 1010 Workbee and it's a good place to finally be except for a couple issues with the X-Pro. This is the first one of these boards I've used and the first time using anything except Mach 3. Would anybody be kind enough to post your microstep jumper settings and working configuration for Universal G-code sender? Also, is there anything I need to do with the A axis settings to get it to work as it should? My board arrived with the y axis clone jumper soldered and all axis configured for 8 microsteps.
    Thanks!
    Larry
  17. Keith Kimura
    Thanks for the info, guys. I found a lot of information on hooking up the CNC controller but the information on the Power Supply wasn't very helpful. I am not an electrician and all of the information seems to be geared toward someone who understands electrical schematics! Unfortunately, I tried copying what I saw on Youtube, as far as which wires go where (on the Power Supply), and ended up FRYING THE UNIT. Just wasted all that money! What I'm looking for are instructions that tell me which wires in the power cord are Hot, Negative, and Ground and then which terminals they are attached to on the Power Supply. Since I have to order another PSU, I hope there is some "simple" wiring info on this. Any help in this direction would be greatly appreciated (my wallet will appreciate it, too!).
  18. Craig Hollabaugh
    Typically in US, if you cut the end off a computer 'IEC' power cord
    Black is 'LINE'
    White is 'NEUTRAL'
    Green in 'GROUND'
    In the US, looking at the outlet, the shorter slot is Line, the longer slot is Neutral, the round hole is Ground.
    Switching power supplies will have an input section labeled L, N, G for Line, Neutral, Ground. Their output while be + and -, + for DC positive and - for DC negative. The term 'Hot' has no meaning.
    You may run across a different color scheme with your AC computer power cord. In this case,
    Brown is 'LINE'
    Blue is 'NEUTRAL'
    Green-Yellow is 'GROUND' or sometimes called protective earth.
    Hope this helps. Send photos next time before you apply power and someone will probably reply. Smoke bad, let's not do it again.
    Rick 2.0 likes this.
  19. Keith Kimura
    Thank you Craig. Just ordered a new PSU. I'll definitely get verification before applying power next time. Yes, smoke bad! Popping noises, too! Just want to say again, Thanks. This "community" environment is reassuring to know there are others out there to give support and advice. Your time is well appreciated.
  20. Craig Hollabaugh
  21. Keith Kimura
  22. Keith Kimura
    20180709_111707.jpg 20180709_111652.jpg I'm still confused here. The NEMA 23 motors have four wires; Red, Green, Blue, and Yellow. But the wiring diagram shows the four wires as 2 reds, and 2 blacks? I don't know which goes where.
  23. Rick 2.0
    Yeah, that'd do it. On a positive note, you had the green one in the right spot. :thumbsup:
    Next time, white to N and black to L. Wires from +V and -V go out to the controller/drivers.
    As for the wire colors, the diagram may intentionally be left vague as different manufacturers use different ordering to their wires. If you have a wiring diagram that came with the steppers it'll tell you which wires are matched pairs to fit into the A1, A2, B1 & B2 positions. If you don't have the wiring diagram you'll need to find the matched pairs. Take 2 of the wires and hold the bare ends together. If the stepper is noticeably more difficult to turn than it was without the wires touching, you have found a matched pair. Connect them to the A1 and A2 positions and connect the remaining wires in the B1 and B2 positions.
    MaryD likes this.
  24. Craig Hollabaugh
    https://www.robotics.org.za/image/catalog/generic/85BYGH450D-008/85BYGH450D-008 - Layout01.jpg
    do you have a multimeter? if so, measure the resistance between pairs on your motor. If the resistance between 2 wires is low (< 100 ohms). That's a pair and connect that pair to the motor driver A or B output. If the resistance is high, like no reading, that's not a pair.
    Don't worry about which goes on A- and A+, B- and B+ just yet. Get your machine together and see if it moves the direction you expect. If it moves in the opposite direction, just flip a single pair of wires on a single motor output. flip A+ and A- for example and check if correct movement happens. Do this for X, Y and Z. be careful on your dual motor drive axis. the motors might fight each other. Make a very small movement, 0.5mm or 0.1"
  25. Keith Kimura
    Craig, thank you. Your explanation is so simple. I'll keep you updated.
  26. Giarc
    If you sourced your motors from a single supplier, then wire your two y motors the same for a screw driven CNC. Since this one is completely screw driven (I believe), wire up your x axis first. Once you have that one going the right direction, you can use that wiring scheme to easily get the other two axis going the proper direction.
    MaryD and Craig Hollabaugh like this.
  27. Craig Hollabaugh
    Excellent approach, thanks.
  28. Keith Kimura
    SUCCESS! LED's are glowing and nothing is smoking! Except me and my cigar. Now, time to tackle the software install and get these motors turning. Any advice
    MaryD likes this.
  29. Craig Hollabaugh
    Get a beer or some fine wine to go with smoke.
    Re-read the ooznest full kit instructions then wire it up.
    GrayUK likes this.
  30. Keith Kimura
    I am running a test toolpath file created from Fusion 360. In the CAM operation/post processor I have selected the Grbl/grbl configuration. When I run the file I get an "(error:20) Unsupported or invalid g-code command found in block." I don't know what this means. Where to find the definitions of errors from UGS?
