Software Tab ???
Discussion in 'General Talk' started by joe williams, Sep 2, 2018.
  1. joe williams
    joe williams Well-Known
    Hey....what's up with that new menu tab ? :D
  2. joe williams
    Is something happening on September 4th ?.....what are we going to do until Tuesday ?
  3. David the swarfer
    @Mark Carew : on the cam setup it shows the 'end gcode' as below
    but that is incorrect
    it should be
    G0 X0 Y0 ; the Y is missing from your code
    AND!!!!
    I cannot type a Y there to fix it. many other letters can be typed, but not Y
    joe williams likes this.
  4. joe williams
    @Mark Carew, @David the swarfer, I'm hoping the Linux driver download works some time today....I mean "Y" not? All will be revealed today, right?
    #5 Peter Van Der Walt, Sep 4, 2018
    Checking from my side, the Linux DL works (and installs fine on my Ubuntu box) - can you elaborate on any issues? (Ctrl+shift+i -> devtools console always gives some clues) or use the alternate download at OpenBuilds/SW-Machine-Drivers (download.openbuilds.com just tries to present it a little prettier - but Github releases is the backend)
  7. joe williams
    @Peter Van Der Walt, all the green buttons show just a placeholder link: [ Download OpenBuilds Software]
    I'm using:
    • Ubuntu 18.04
    • Google Chrome: Version 68.0.3440.106 (Official Build) (64-bit)
    • Acer i7 laptop
    I'll try that alternate download link later, thanx!
    The buttons has a JS onclick event (So the Placeholder is valid HTML) - that executes an ajax getJSON to Github Releases to grab you the Latest exe/dmg/deb/appimage etc as appropriate - using ajax instead of hardcoded links means I dont need to keep updating the link :) and spend more time making cool features (As each Github Release has the Tag in the URL)
    (Checkout OpenBuilds/download if you want to know what it does under the bonnet)
    That said - I think I see bug (; Gimme 10 and i'll fix it for you!
    [edit: fixed :) ]
    #9 Peter Van Der Walt, Sep 4, 2018
  10. GrayUK
    Well...... That went straight over my head. :D:p
  11. joe williams
    @GrayUK , back when I was still doing some web development, we were just beginning to use some ajax routines to make life simpler. Now when I think about digging into anything web development-like, my eyes roll back in my head and i start to drool :rolleyes:
    @Peter Van Der Walt , still not working for me, but the problem is probably on my end:
    been having some Java issues since upgrading to 18.04. I got the linux driver at github, installed the deb and the browser based CAM finds the driver. The App itself doesn't open. I get the above error instead. I guess I'll fiddle with it all later! Thanks!
    :) Always a chance its our side :) - especially the Linux side (not so many users - so gets a bit less testing) - so don't rule that out yet :)
    I picked up you knew a little though when I saw you checking the placeholder/href )
    Quick question: Is this the DEB or the AppImage one?
    (I'll download 18.04 tonight - been putting off updating) and see if I can replicate - the AppImage shouldnt be running in /opt - and maybe just maybe the .deb installer is doing something odd)
    If you are on the .deb, try the AppImage too - it's kinda cool AppImage
  13. joe williams
    so now everything is magically working, download buttons and the app. Downloaded the deb a second time, installed it and it works (there was some kind of error screen, but it continued on to load and run) Jogging my test setup now!
    :) Sweet! I fixed the download button bug (stupid mistake, had a little code in there (windows only) from before we added the mac/linux versions hehe) so I'll say that less likely magic (;
    But the other one, I didnt do a fix.
    However the error was because it was started with a parameter, which wasnt a file.
    (You can run './openbuildsmachinedriver file.gcode' and it'll open the file. The error looked like it was getting a parameter, but said parameter wasnt a file. Maybe ubuntu was adding something onto the end of the command for some odd reason. Still, it needs some extra coding to handle that without throwing an error :) - the 1.8gb Ubunntu 18.04 ISO is in my download queue - will see if I can replicate and then fix
  15. joe williams
    :thumbsup:
    #15 joe williams, Sep 4, 2018
  16. HC.Carbo
    HC.Carbo Journeyman
    mmm, (maybe it's my old sys. win7 / google chrome)
    put a circle in > move it...& get Pinokkio on your screen :)
  17. HC.Carbo
    HC.Carbo Journeyman
    works fine with imported .svg files > export to mach4 :)
    Nope, known bug - but super rare :) this would be the third instance I know of, in 7 months)
    Workaround:
    move (it messes up the first point)
    Undo, (ctrl+Z)
    Now move again, and it works. (Well for the two other times I've found this)
    Do drop me the test file, from the other two I couldnt find why those drawings had issues with their first vertex jumping differently (With only two files, its hard to pickup a pattern to debug - so one more may just help) - also include which CAD it came from :)
    I actually want to rewrite DragMove entirely (Todo: DragMove: Enhance to support selected objects as well · Issue #2 · OpenBuilds/cam ) to also make it more useful, that might just incidentally solve it - but would be better to find what the issue is, and properly fix it.
  19. HC.Carbo
    HC.Carbo Journeyman
    lol: now i have pacman on my screen. :)
    This happens only when use the build in circle tool, not with a imported svg.
  20. Peter Van Der Walt
    Aha! Will check it out! :)
  21. joe williams
  22. Peter Van Der Walt
    HC.Carbo likes this.
  23. Peter Van Der Walt
  24. HC.Carbo
    HC.Carbo Journeyman
  25. Peter Van Der Walt
    Yeah I only addressed the Move - the undo is a different little can of worms :) - it's on the todo!
  26. Peter Van Der Walt
    Was fixed today :) - you can test again please and let me know if you find any new issues
  27. HC.Carbo
    HC.Carbo Journeyman
    jep, seems ok now (y)
