New here been making stuff with C-Beam
Discussion in 'General Talk' started by Roach855, Sep 17, 2018.
  1. Roach855
    Roach855 New
    Hey everyone!
    I have been putting together some machines and thought that I would share them with everyone here.
    The First one is a foam router that I put together, it does not have to be rigid in any sense cause the foam cuts so easily.
    The second was a printer that I designed a while ago and did a retro fit using the 20x20 beams.
    Kyo, MaryD, Scotty Orr and 4 others like this.
  2. Mark Carew
    Looks great @Roach855 ! The foam router with the super large work area is amazing. Thank you for sharing
  3. Roach855
    Roach855 New
    Well thought I would share some more!
    This is a 12 foot by 18 foot 2 axis hot wire cutter.
    It was more of a retro fit as the original rail system was rusted and destroyed, so I gutted the electronics and put a GRBL system in and replaced the rails with C-Beam.
    Pardon the mess... It has been working non-stop for about a year and a half, and we have not had a lot of time to clean up. ;P
    MaryD, GrayUK and Rick 2.0 like this.
  4. GrayUK
    Sweet little thing you have there! :D:thumbsup:
  5. joe williams
    joe williams Well-Known
    Hey!...nice retrofit! What are you cutting/making in foam?
  6. Giarc
    Those are cool!
  7. Roach855
    Roach855 New
    A lot of random stuff... everything from crown moldings to fascia subs! :)
    joe williams likes this.
  8. makerdave
    makerdave New
    So for the long runs of C-Beam, are you just butting them up end to end? Anything special needed at the seams?
