Rock n Roll
Discussion in 'CNC Mills/Routers' started by rob4cnc, Nov 26, 2018.
  1. rob4cnc
    rob4cnc New
    rob4cnc published a new build:
  2. Rob Taylor
    Now this is a build up my street! All over this. :thumbsup:
  3. rob4cnc
    rob4cnc New
    I am currently looking for a team of enraptures, net-workers, wonks, and the like who will be interested in the entire project. A a refined version of this machine will be franchised and networked in a large number of Small Manufacturing and Recycling Enterprises. The team will be developing the physical plant that includes grinder, washer, mill, electroplating equipment, and injection molding machine. The franchised and networked enterprises will recycle PVC plastic into Snploc a patent pending device for joining all kinds of pipes and rods.
    To develop this franchised and networked recycling and manufacturing process we will be seeking well suited grants from Colorado Department of Environment and Health and from crowd funding sources.
  4. Rob Taylor
    Sounds good! Sounds like it's something along the lines of Dave Hakkens' Precious Plastics initiative, actually, which is great!
  5. DarkPenguin
    DarkPenguin Well-Known
    "Built to go fast and light."
    You are aware you're making this out of granite, right?
  6. rob4cnc
    rob4cnc New
    Exactly, with the addition of precision molding.
  7. rob4cnc
    rob4cnc New
    The foundation or table is a granite sandwitch with concrete in between. The bottom is two scraps side by side. I poured concrete on top and floated a full 3' x 4' piece on top of that. Then I hand milled the surface flat and glued the y axis rails to it.
