OpenBuilds PowerCase
Discussion in 'Other Builds' started by Mark Carew, Nov 27, 2018.
  1. Mark Carew
    Mark Carew published a new build:
  2. Rick 2.0
    Are these capable of handling the higher voltages of 36V and 48V power supplies?
    Should do fine, the only active component is a red led in series with a 2k2 LED. On the higher voltages, you might be punishing the LED but even if that kills it, the rest is passive and will work as planned
    Mark Carew and Rick 2.0 like this.
  4. Michael.M
    Michael.M Veteran
    Just watched the youtube video. This thing is pretty cool Mark.
    TrishC likes this.
  5. GrayUK
    I just bought a new power supply. Can I buy just the front end? :rolleyes:
  6. Rick 2.0
    PowerCase Kit
    Mark Carew, GrayUK and Michael.M like this.
  7. GrayUK
    Thanks :thumbsup:
    I just don't seem to look in the right place :banghead:
  8. Avenicio
    Avenicio New
    My power supply stops working when I connect the PowerCase front plate to the terminals. The led is on when I just connect the power and off when I add the front plate. I have taken apart the PowerCase to troubleshoot the issue but I can't see what I am doing wrong. Is it me or the board?
