Mach 3/4 Control Software
Discussion in 'Control Software' started by Mark Carew, Aug 24, 2015.
  1. Mark Carew
    Mach 3
    http://www.machsupport.com/software/mach3/
    Mach3 turns a typical computer into a CNC machine controller. It is very rich in features and provides a great value to those needing a CNC control package. Mach3 works on most Windows PC’s to control the motion of motors (stepper & servo) by processing G-Code. While comprising many advanced features, it is the most intuitive CNC control software available. Mach3 is customizable and has been used for many applications with numerous types of hardware.
    Discuss all Mach 3 related topics here
    #1 Mark Carew, Aug 24, 2015
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Hi Guys,
    I have been using Mach3 for more than 10 years now (since it was Mach2) and it has always served me extremely well. Over these years there have been many developments in the available add-on hardware / motion controllers / versions of the Windows OS etc. etc. and Mach had always been revised to keep up with the pace of change.
    Something to be aware of…
    Since the introduction of Mach4 further development or revision of Mach3 has ceased and it is my understanding that no future changes will be made to Mach3’s coding to correct for any bugs or other problems that may be discovered in the future. Having said that, full support for the product will continue to be available through the Artsoft and CNC Zone forums for many years to come and as a result I am perfectly happy to continue using Mach3, with my machines, at least into the foreseeable future.
    I do have a licensed version of Mach4 installed but until such time as it fully emerges out of it’s beta stage it will not get used by me for any serious work. It has been a long time coming and I suspect it will be another couple of years or so before Mach4 is truly ready to take over from Mach3 in the hobby CNC world.
    Tweakie.
  3. MikieLikesIt
    Hi Mark,
    I'm new at this site and need some help with programs, software, controllers ect... I've downloaded Autodesk Fusion 360 for design on my PC. I've also downloaded Mach 3 on my older PC that will be used as PC for my CNC machine out in my shop. My CNC steppers are 4 nema 23's. I was hoping down the road I could run a 4th axis. Therefore I've purchased xPro controller for my shop PC. I find out after the fact that it will not work with Mach 3. One of my questions is, do I send the xPro back or is there a solution? I only have a few weeks left if I were to return this item. I am not sure what I need to get my machine up and running. Can you help?
  4. Steven Bloom
    Steven Bloom Journeyman
    Hi All, I am using Mach 3 and a C-Beam. I wanted to know what would be a good guideline for the motor setup. In other words what should be the maximum mm/min setup as well as the acceleration. I am also using a 24.0 kg-cm (333.2 oz-in) Nema 23 motor.
    Thanks Steven
  5. Tweakie
    Moderator
    Hi Steven,
    Its difficult to be precise because, when it comes to maximum speed, a lot depends on the quality of the stepper motors and their drivers.
    I would start out by setting a maximum speed of 4500mm/min with an acceleration of 450mm/sec.sec. then adjust, as necessary, from there to obtain optimum performance.
    With acceleration the higher the value the better the performance (less rounding of corners in constant velocity mode) but the more the machine starts to shake around so it can be 'trial and error' to find the optimum.
    Tweakie.
  6. Tweakie
    Moderator
    Hi Mikie,
    If you want to use Mach3 then the XPro is of no use to you. On the other hand, why not use GRBL with the XPro ??
    Tweakie.
  7. Priit Paat
    Hi!
    Starting my first cnc project and trying to build electronics. Using breakout board (SainSmart 4 Axis Mach3 STB4100) and ST-40-45-A1 controllers.
    Everything looks working well, but when i loading sample g-code and run it, then only Y axis moves, slave A not moving at all?
    In jogging mode Y and A moves together and A reversed nicely. Are there special g-code needed to run on slave A? Thats not logical?
    Can someone help newbie?
  8. Steven Bloom
    In Mach 3 go to config and then slave settings. Here is a config pic. My A axis mimics my Y axis.
  9. Priit Paat
    Thank you for answering, but I have already made this setting. All works when i jogging. When I load arbitrary code, then A axis will not move.
  10. Charles Roseberry
    Has anyone gotten mach 3 windows 10 and the provx1 board working?
  11. ahpeelen
    ahpeelen New
    Hello Experts, I discovered a strange behaviour in Mach3 when tuning my steppermotors. I used the 'Set Steps per Unit' option by traveling 1000mm. I measured the distance the machine traveled along the Y-axis and putted this figur in. Mach3 change the settings for the y-ax accordingly. no comes the problem. given a simple G-code in the ALT-2 screen: G0 Y1000, the Y-axis moves exactly 1000mm. So far so good. A new test: G0 Y750: tavel distance 756; G0 Y500 distance 511, G0 250 gives 258 mm and G0 Y0 gives exactly 0 again. so the only 2 which are correct is the tuning distance and the Zero.
    does anyone knows what is hapening here? or has had the same problems?
  12. tazma
    tazma New
    hola, perdon por la traduccion
    . Estoy buscando un consejo con cnc Tengo esta máquina CNC OpenBuilds OX cnc mi problema es que con arduino funciona bien al 95%
    Pero decidí cambiar a mach3 y no puedo configurar mach3.
    NEMA 23 La interfaz de motor + mach3 + tb6600
    Ya probé varias configuraciones, pero el motor no responde, ¿qué puedo hacer?
    Gracias
    [ATTACH = full] 39573 [/ ATTACH] [ATTACH = full] 39574 [/ ATTACH] [ATTACH = full] 39574 [/ ATTACH] [ATTACH = full] 39575 [/ ATTACH]
  13. Gary Johnson
    cnc placa .jpeg .Just bought that one . Did not have instructions on how to hook up the stepper motors and power connections.
  14. tazma
    tazma New
    Gracias, ya ha sido resuelto.
  15. tazma
    tazma New
    Aqui otra vez
    hola estoy usando mach3 en cnc pero quiero unir un comentario láser que soy un aficionado
    el problema es que no sé cómo puedo conectar el láser tengo una tarjeta
    interfaz nach3 5 ejes pero repito no tengo claro las conexiones
    Espero que alguien pueda ayudar
    Gracias
    Consider a more modern, easy to use solution. See https://docs.openbuilds.com/blackbox as a replacement
  17. tazma
    tazma New
    Hello if it is another option but considering that my economy is not going very well and that I already have the mach3 installed in cnc I only have to attach the laser
    I do not earn a living working with cnc is my hobby
    there is that my knowledge is limited
    that's why i ask for help
    thanks
    Checkout mach3 5 axis breakout diode laser wiring - Google Search
    Which is exactly why we recommend the Easy to use BlackBox, which comes with great documentation, which tells you exactly to how wire a laser, https://docs.openbuilds.com/blackbox (see section 3.3.2 and 3.3.3) and also wiring Videos on our YouTube channel.
  19. tazma
    tazma New
    ok gracias veo el enlace
