Cube 3 / Pro hacks
Discussion in '3D printers' started by eychei, Jan 16, 2017.
  1. Tom Dirriwachter
    Tom Dirriwachter Well-Known
    Sorry I couldn't help revive your system. Enjoy the build!
  2. Freight Train
    No worries. The particular one I have is more or less a hand me down anyways. And Thanks!
  3. JT3D
    JT3D New
    When my Ekocycle Cube was bricked with a permanent error message, I contacted 3DS Customer Support and harangued them until they sent me a .zip file of the SD card files (customized for my serial number). The procedure then was to format the SD card, extract the files directly to the SD card, and reinstall the card. The printer came up asking for it's serial number, messed around a while and then booted up normally.
    It might be worth a try to call them.
  4. Tom Dirriwachter
    That is great info, JT. I've had luck with their support team as well with other issues.
  5. Freight Train
    I'm giving it a shot. So far, they've been rather helpful, and might be able to revive my printer.
    UPDATE: They were able to get me the files to fix the printer! It is working as well as it did beforehand. Now all I need to do is get another micro SD for the Raspberry PI i pulled it out of. Thanks for the tip, JT!
    #515 Freight Train, Sep 4, 2018
  6. JT3D
    JT3D New
    Yay! Glad you got it sorted.
    And, I'm glad to hear 3DS is still willing to support Ekocycle Cube/Cube3.
    #516 JT3D, Sep 5, 2018
  7. Abinav Shankar
    I am a master degree student in Singapore. We have a cube 3 printer in our university. I am working on cyber-physical systems and as a part of that I need to control my 3D printer like the nozzle and bed movement. I know the original Cube 3 firmware doesn’t allow that but can I do that sort of controlling with Cube Toolbox. Because
    for my project,
    I need to establish a control of the nozzle with my computer.
    Thank you.
  8. Tom Dirriwachter
    Nice to know guys. Great news!
  9. Alisonreis
    [QUOTE = "eychei, post: 47538, member: 62585"] Esta Ă© a nossa primeira versĂŁo da Cube Toolbox para o firmware Cube 3 e Cube Pro.
    Com esta ferramenta vocĂŞ pode extrair, reembalar e, claro, corrigir o firmware.
    Ao corrigir o firmware, vocĂŞ pode interromper o processo de contagem do chip de filamento e, assim, usar o filamento de sua escolha.
    NĂłs nĂŁo assumimos qualquer responsabilidade e nĂŁo nos responsabilizamos por qualquer dano causado pelo uso da nossa Caixa de Ferramentas do Cubo.
    VersĂŁo de firmware de trabalho para o patcher sĂŁo:
    Cubo 3: v1.14B
    Cubepro: v2.00
    Notas de versĂŁo do Patcher:
    Buggy entĂŁo deletou os arquivos
    ____________________
    v1.11
    - Removida verificação de MaterialCode (por exemplo, arquivos de impressão ABS com cartucho PLA) para o firmware Cubepro
    v1.1
    - Verificação removida de MaterialCode (por exemplo, arquivos de impressão ABS com cartucho PLA) (apenas no cubo 3)
    - Telnet ativado (porta 23) (não é necessário nome de usuário / senha) (somente no Cube 3)
    __________________________
    Link para o mais novo download da versĂŁo: CubeToolbox_v1.0.zip
    Por favor, contribua para o nosso trabalho e envie-nos uma doação.
    Link do Paypal:
    www.paypal.me/akizakian
    Thx vai para [USER = 60318] @Kiza [/ USER], que Ă© um dos mentores deste projeto, ele Ă© o cara do software.
    E [USER = 54597] @ Geezer70 [/ USER], que ajudou muito na parte eletrĂ´nica.
    Esse segmento também coletará todas as informações e hacks para essas impressoras.
    Uso / Como:
    1. Faça o download da caixa de ferramentas do cubo
    2. Faça o download do firmware
    3. Abra o Firmware no Cube Toolbox
    4. firmware de patch
    5. Copie o arquivo de firmware atualizado para o pendrive
    6. Firmware flash, indo para Configurações -> tela de firmware
    Conheça os problemas:
    - O cartucho da impressora também foi inicializado primeiro. Isso significa que os cartuchos de 100% não funcionarão. Isto é devido a ignorar a rotina de escrita no firmware.
    PrĂłximos Passos / Todo:
    - Encontre a rotina para verificação do material e corrija-a. Agora você só pode usar material que também esteja programado no chip. Portanto, se seu arquivo de impressão .cube3 for para ABS, você só poderá usar o ABS-Filament. Se você usar o filamento de PLA, a temperatura de extrusão será muito alta e o seu bocal ficará danificado / entupido.
    - Crie uma GUI para os arquivos XML de configuração do software Windows Cube para alterar as temperaturas de extrusão e a velocidade de impressão.
    - Gere um arquivo de configuração de trabalho para simplify3d para Cube 3 e Cubepro
    _______________________________________________________________
    Arquivos STL para modificação de cubo
    Obrigado ao Cube_3 por esta modificação. Com isso, você pode mudar a tubulação para a extrusora e usar o cartucho sem o revestimento superior.
    Modificação do cartucho do 3D Systems Cube 3 por Cube_3
    ola eu fiz o procedimento e o meu cubo3 quando envio travas de impressĂŁo no aquecedor, vc sabe me dizer o pq ou como resolver.
  10. DANAUTA
    DANAUTA New
    Saben si existe la posibilidad de utilizar otro software como cura o netfabb con una cubepro?
  11. epicstoryguy
    So I downloaded firmware 2.0 for my cubepro, but ithe firmware "fails to download" from the usb with both the normal V 2.0 and the patched V 2.0. I'm currently on firmware V2.02. Any proposed solutions? Is there a limit on the size the usb can be?
  12. JT3D
    JT3D New
    Did you use the method outlined in post #375 on this thread?
    (i.e., rename the 2.0 firmware file to match the exact name of the currently running firmware file...)
    The firmware load function will not accept a filename of an earlier version...
  13. Dean Mehling
    I didn't see anything about that in post #375.. Am I missing something?
    Am I supposed to rename my v2.02 file to something like v1.14B?
  14. Dean Mehling
    Update: never mind. I read through and found the various things I needed! Testing in progress!
    I can't say how thrilled I would be for this to work, so it can be my backup PLA printer. After years of struggling, we were able to get a Prusa 2.5 that prints like a dream.
  15. JasonDeth
    JasonDeth New
    So I commented on the print3dforum post about this and I don't know if people would be able to help in this but I put the "fixed" firmware into my Cube 3 so that I can use any filament and when I put my modified cartridge (nothing done to the chip) and attempt to start a print, the print will halt and say that the cartridge was removed and then will say its not installed and will stop the print. I tried a few cartridges and tried resetting and doing it again to no avail. I currently have put the old un-patched firmware back in the printer and it works just fine but obviously I still run into the issue of that percentage ticking down when I make prints like normal. I don't really see other people having this issue and I wonder if this is just my printer being borked or what. the only alternative I found was some hardware build, an ebay listing to reset the chip, and a $150 chip resetter that people have mentioned several times. I'd prefer to find a way to fix this patched firmware issue than be spending any more extra money on this project if possible.
    Any ideas?
  16. JT3D
    JT3D New
    Idea 1 - Try 'fixing' the stock firmware yourself. The method can be found in this thread, if I remember - if not, then in the Print3dForum.com thread. The reason I suggest this is that a couple of us have come up with differences in the value of the checksum on the two hex code lines that are changed. You just need to use a hex editor, and search for the telltale hex strings, and subtract something (0x10, I think) from the certain bytes, and then add that same amount to the checksum byte at the end of each of the lines.
    Look here
    Cube 3 / Pro hacks
    Idea 2 - There is a DIY cartridge resetter that is pretty easy if you are fairly handy with computery stuff. I used an Arduino Nano clone, which I got on ebay for about $10 for three of them.
    Look at haxtom.com. The basic resetter microcode was free, but for a reasonable donation, Tomuro will provide you the microcode to not only reset the % used, but also change the cartridge type (Cube vs Ekocycle), material, and color.
    #526 JT3D, Jan 5, 2019
  17. celina zain
    Where do u find it? I read through the howl thread and didn't find anything.
    Only the "Rename the same and Swap USB Drive" but my Cube Pro trio always cancels the update process immediately after I unplug the USB.
    My Specs:
    CubePro Trio
    Firmware. 2.02
    What I Want:
    Install the patched 2.00 Firmware
    Can someone help?
  18. Vince Hunt
    Hi, is there any way to patch the ekocycle printer? I patching the firmware but it's not supported, so I patched the cube firmware and it updated that firmware but when I tried to update by USB it won't work. I renamed the firmware to match the latest firmware available for the ekocycle v1.05 and I renamed it to v1.06 but wouldn't work. Any ideas? This thing is basically worthless as the only way to buy filament is 3d systems with 4 colors and old stock not to mention the price. Any help would be great. Thanks.
  19. JasonDeth
    JasonDeth New
    I'm not super great with this kind of stuff but I think this will probably be my best option plus then I get to learn but I have no clue where to start other than buy a arduino nano and breadboard kit. I hate to be the newb in this forum but I've had this thing for years and wanting to actually use it. Anyone able to assist so I know what the hell to do?
  20. JT3D
    JT3D New
    Here's how to patch the Ekocycle 1.05 firmware:
    Cube 3 / Pro hacks
    #530 JT3D, Jan 23, 2019
  21. JT3D
    JT3D New
    Have you wired up something electronic on a breadboard before?
    Have you installed the patched "do not update the cartridge % used" firmware?
    Check your PM.
  22. Shwe
    Shwe New
    Does anyone know where I can download cubepro V2.00.ar from?
  23. Tom Dirriwachter
    All of Cubify is available through this page: http://cubify.s3.amazonaws.com/
    ...just add the subfolder and filename from within the list.
    Printers/Cubepro/cubepro V2.00.ar
  24. Shwe
    Shwe New
    Thanks Tom. I am a newbie to this so appreciate that.
  25. GlavanicSC
    Thanks for the link, I'm a newcomer too :)
  26. bolsoncerrado
    bolsoncerrado Well-Known
    We've set up a small mini subforum for all things CubePro recently here: CubeX / CubePro Forum
    Just in case anyone wants to chime in on firmware hacks, gcode injections, filament hijacking and all things CubePro :D
    GlavanicSC and Tom Dirriwachter like this.
  27. GlavanicSC
  28. cwhiseant
    cwhiseant New
    Looks like the Cube3 has been mostly left behind, but I still had mine sitting and I got bored, so I made a new nozzle assembly that relocates the stupid T24 causing switches to the top of the print head. I'm using this with the "hubcap" extruder. If anybody else is still using theirs and interested to try it, it's on Thingiverse - STL and Solidworks files.
    Cube3 Retrofit Nozzle Assembly by Cwhiseant
  29. Gregory Brogna
    Did you ever find the password?
  30. TheMemeThunder
    doesn't work just says download failled
