Motor Problems?!
Discussion in 'CNC Mills/Routers' started by ICE-tiii, Jan 22, 2019.
  1. ICE-tiii
    ICE-tiii New
    Hey there!
    I have a 1515 workbee and i have The Problem that The y and a axis are vibrating/grinding while
    im doing a Job as you can see in The video.
    Motors are Pretty loud but i have no missing steps.
    X and z are Perfect!
    Colling for The x pro v3 is on, belts and pully Are tight, if checked The settings which after playing around didnt seem to make any diference.
    When the Electric is of i can feel and here some vibration when moving the y and a axis.
    I made a video to so you can hear that, if that is maybee The Problem?!
    But if i want to go to home or to Zero The Maschine drives smooth as it should. No vibrating
    So i Hope you guys can help me there !
  2. Mark Carew
    #2 Mark Carew, Jan 23, 2019
  3. Mark Carew
    FYI @ICE-tiii was nice enough to take the time to share the solution he found :thumbsup: Thank you
