G Code Errors
Discussion in 'CNC Mills/Routers' started by Miklstel, Feb 17, 2019.
  1. Miklstel
    Miklstel New
    This a new install. I'm using grbl Ver 1.1 and UGS 2.0. Just trying to cut a simple circle.
    G Code from CamBam.
    ( Made using CamBam - CamBam CNC Software )
    ( Circle 2 Test 2/17/2019 9:09:29 AM )
    ( T0 : 0.25 )
    G20 G90 G64 G40
    G0 Z0.125
    ( T0 : 0.25 )
    T0 M6
    ( Profile1 )
    G17
    M3 S1000
    G0 X2.125 Y0.0
    G0 Z0.0625
    G1 F10.0 Z-0.5
    G3 F30.0 X-1.0625 Y1.8403 I-2.125 J0.0
    G3 Y-1.8403 I1.0625 J-1.8403
    G3 X2.125 Y0.0 I1.0625 J1.8403
    M5
    M30
    When I send I get this message.
    System starts and runs normal even without clearing above message.
    When I get to this point (shown below) UGS stops sending code. If I click SEND again code sending resumes. If I do a double pass the second pass goes without a problem.
    Below is text from Console window. Lock up point is indicated.
    [MSG:Caution: Unlocked]
    ok
    Skipping command #3
    Skipping command #4
    Skipping command #5
    >>> G20
    >>> G90
    >>> G64
    >>> G40
    ok
    >>> G0Z0.125
    Skipping command #11
    >>> T0
    >>> M6
    Skipping command #14
    >>> G17
    >>> M3S1000
    >>> G0X2.125Y0.0
    >>> G0Z0.0625
    Skipping command #19
    >>> G1F10.0Z-0.5
    >>> G3F30.0X-1.0625Y1.8403I-2.125J0.0
    ok
    (error:20) Unsupported or invalid g-code command found in block.(error:20) Unsupported or invalid g-code command found in block.
    ok
    ok
    ok
    ok
    ok
    ok
    ok
    ok
    ok
    LOCKS AT THIS POINT
    click SEND
    **** Resuming file transfer. ****
    >>> G3Y-1.8403I1.0625J-1.8403
    >>> G3X2.125Y0.0I1.0625J1.8403
    >>> M5
    Skipping command #25
    ok
    ok
    **** Finished sending file in 00:07:03 ****
    ok
    Another thing What is all the Skipping commands about?
    I can get my part cut but not knowing what is going on is troubling.
    Thanks for the help.
  2. David the swarfer
    GRBL does not support tool change codes, so just remove the T0 M6 line.
    It also does not support the G64 command, so remove that too.
    all those 'skipping command' lines are worrying.
    the only things in that program that needs to be skipped is the Tx M6 toolchange command and the G64.
    like this
    Code:
    (Block-name: block)
    (Block-expand: 1)
    (Block-enable: 1)
    G20 G90 G40
    G0 Z0.125
    ( Profile1 )
    G17
    M3 S1000
    G0 X2.125 Y0.0
    G0 Z0.0625
    G1 F10.0 Z-0.5
    M5
    M30
  3. Miklstel
    Miklstel New
    Thanks for the help. I corrected the code as you said and it ran flawlessly. It still returned some Skipping command # as shown below. What does the #xxx indicate? Thanks.
    ok
    Skipping command #288
    Skipping command #289
    >>> G20
    >>> G90
    >>> G40
    ok
    >>> G0Z0.125
    Skipping command #294
    >>> G17
    >>> M3S1000
    >>> G0X2.125Y0.0
    >>> G0Z0.0625
    >>> G1F10.0Z-0.5
    ok
    ok
    ok
    ok
    ok
    ok
    >>> M5
    Skipping command #304
    ok
    ok
    ok
    ok
    ok
    **** Finished sending file in 00:00:57 ****
    ok
  5. David the swarfer
    UGS will have popped up a prompt saying something like "this code is not supported do you want to skip it?" and you answered YES. What UGS did not make clear is that it will filter that code forever!
    So, in UGS, select 'settings'
    select 'Gcode processor configuration'
    there you will see some things in the list. untick 'decimal truncator' and remove any entries in the 'regular expression pattern remover' area.
  6. Miklstel
    Miklstel New
  7. Miklstel
    Miklstel New
    I don't seem to locateSettings/'Gcode processor configuration'. I'm running UGS Platform Ver 2.0
  8. David the swarfer
    ah, ok, in platform it is accessed via
    tools
    options
    UGS
    Controller options
  9. Miklstel
    Miklstel New
    Got it. Thanks. I'm switching over from Mach 3 so having to learn all over. Your help from these forums make it easier.
  10. crnrstndes
    crnrstndes Well-Known
    Hi all, I seem to have the same issue, sort of. I got my machine (C-beam XL) working with my new BlackBox, limit switches homing works great, thanks for the help, when I try to run a job (my gcode is generally from Makercam so the files are .nc) gives me this error. (error:20) Unsupported or invalid g-code command found in block.
    I tried the file(s) (which worked fine before the BB upgrade) in both UGS and Open Builds Control with the same error code. Interesting the file works fine in Easel.
    I was using Arduino Uno/ Cshield before and the files all worked good.
    Any insight would be really appreciated!
    Thanks!
  11. sharmstr
  12. crnrstndes
    G20 G90 G40
    (profile 1)
    G0 Z0.5
    T0 M6
    G17
    M3
    G0 X0.1412 Y0.0286
    G1 Z-0.127 F30
    G1 X3.3323 Y0.0286 F30
    G3 X3.337 Y0.0288 I0 J0.0625
    G3 X3.3732 Y0.037 I-0.0094 J0.125
    G3 X3.4053 Y0.0555 I-0.0456 J0.1167
    G3 X3.4307 Y0.0826 I-0.0777 J0.0981
    G3 X3.447 Y0.1159 I-0.103 J0.071
    G3 X3.4528 Y0.1526 I-0.1192 J0.0377
    G3 X3.4528 Y0.1536 I-0.125 J0.001
    G3 X3.4476 Y0.1893 I-0.1251 J0
    G3 X3.4318 Y0.2229 I-0.1199 J-0.0357
    G3 X3.4093 Y0.2484 I-0.1042 J-0.0694
    G1 X2.9286 Y0.7152
    G3 X2.9274 Y0.7162 I-0.0435 J-0.0448
    G2 X2.9246 Y0.7201 I0.009 J0.0097
    G2 X2.9233 Y0.7246 I0.0117 J0.0058
    G2 X2.9232 Y0.7259 I0.013 J0.0013
    G2 X2.9237 Y0.7293 I0.0131 J0
    G2 X2.9258 Y0.7336 I0.0127 J-0.0035
    G3 X2.9319 Y0.7441 I-0.0504 J0.0369
    G3 X2.9584 Y0.8428 I-0.2659 J0.1241
    G3 X2.9595 Y0.8682 I-0.2923 J0.0254
    G3 X2.9494 Y0.9447 I-0.2934 J0
    G3 X2.9059 Y1.0372 I-0.2833 J-0.0765
    G3 X2.8333 Y1.1093 I-0.2402 J-0.1693
    G3 X2.7404 Y1.1522 I-0.1678 J-0.2416
    G3 X2.6385 Y1.1606 I-0.075 J-0.2847
    G3 X2.5398 Y1.1337 I0.027 J-0.2931
    G3 X2.4563 Y1.0746 I0.1256 J-0.2658
    G3 X2.3981 Y0.9905 I0.2088 J-0.2065
    G3 X2.3732 Y0.9003 I0.2667 J-0.1223
    G3 X2.3688 Y0.9029 I-0.0339 J-0.0525
    G2 X2.329 Y0.925 I0.6071 J1.1376
    G2 X2.2675 Y0.9616 I1.5554 J2.682
    G2 X2.2302 Y0.9847 I2.2722 J3.7177
    G2 X2.1457 Y1.0378 I11.7855 J18.8536
    G3 X1.9294 Y1.1713 I-6.6937 J-10.602
    G3 X1.8081 Y1.2415 I-1.946 J-3.2252
    G3 X1.593 Y1.35 I-1.5184 J-2.7423
    G3 X1.4214 Y1.4181 I-0.7546 J-1.6505
    G3 X1.1991 Y1.4736 I-0.4466 J-1.3165
    G3 X1.0177 Y1.4835 I-0.1366 J-0.8358
    G3 X0.8126 Y1.4411 I0.0369 J-0.6963
    G3 X0.6361 Y1.3421 I0.2244 J-0.6067
    G3 X0.5318 Y1.243 I0.4911 J-0.6218
    G3 X0.4165 Y1.0926 I1.0718 J-0.9408
    G3 X0.3336 Y0.9558 I1.5576 J-1.0372
    G3 X0.2436 Y0.7777 I2.5839 J-1.4182
    G3 X0.1803 Y0.6329 I3.232 J-1.4989
    G3 X0.113 Y0.4599 I4.5678 J-1.877
    G3 X0.074 Y0.3502 I5.1341 J-1.8875
    G3 X0.0269 Y0.2099 I9.2289 J-3.1716
    G3 X0.0144 Y0.1767 I0.1068 J-0.0593
    G3 X0.0116 Y0.1506 I0.1193 J-0.0261
    G3 X0.0131 Y0.1312 I0.1221 J0
    G3 X0.0286 Y0.0884 I0.1206 J0.0194
    G3 X0.0586 Y0.0543 I0.1052 J0.0622
    G3 X0.0991 Y0.0335 I0.0752 J0.0965
    G3 X0.1412 Y0.0286 I0.0348 J0.1173
    G1 Z-0.254 F30
    G1 X2.9286 Y0.7152
    G1 Z-0.381 F30
    G1 X2.9286 Y0.7152
    G1 Z-0.508 F30
    G1 X2.9286 Y0.7152
    G1 Z-0.635 F30
    G1 X2.9286 Y0.7152
    G1 Z-0.76 F30
    G1 X2.9286 Y0.7152
    G0 Z0.5
    M5
    M30
    I am working on the text file!
    Thanks Shawn
    #12 crnrstndes, Jul 9, 2019
  13. crnrstndes
    My Mouse text file
  14. sharmstr
    Its the Tool change line. Remove T0 M6. That was mentioned above as a solution to the OP problem too. G Code Errors LOL. Also, I edited your gcode post. I asked that you attach a text file so you wouldnt post the gcode in the thread. Sorry I wasnt clear about that. Ooops. LOL.
  15. crnrstndes
    Thanks Shawn, That is what I thought needed to be done. I suspect every one of my .nc files will need to be changed! OB Cam is a little quirky, not as intuitive as UGS moving vectors around and zooming so I prefer UGS.
  16. sharmstr
    You mean MakerCAM? I havent used it but maybe there is a way to tell it to not output tool commands. Or maybe they have another post processor that handles grbl correctly.
  17. crnrstndes
    I was referring to Open Builds Cam. I just ran the mouse file and it was fine! I can open the file in Universal Gcode Sender and there is an option to edit the gcode, simple fix! Thanks again!
  18. sharmstr
  19. crnrstndes
    Yes that is true! Not sure why Makercam does or why it never was an issue with the Arduino?? I went through last night and change that one line of code in UGS so I will decide which program will suit me in the future. I am an old school woodworker and I prefer inches as opposed to metric. If OB Cam could change to inches it would work best for me! Thanks again!
    #19 crnrstndes, Jul 10, 2019
  20. David the swarfer
    Note the Gcode can be inch or metric, the controller does not care so long as the correct mode code (G20 or g21) is given.
    Makercam may have settings that will prevent the tool code output.
    OBcam is still young, give it a chance (-:
  21. crnrstndes
    Yes OBCam is young, I was referring to the view of the simulator screen, it is in metric and I like imperial. As well I can't really do anything with the view as it goes all funny and distorted! Not sure why!
  22. Peter Van Der Walt
    1 inch = 25.4mm (;
    But yeah i know. We added inch mode to CONTROL will add to cam someday but lots of more important things above it on the todo.
    Glitchy view: export workspace from the file menu, zip and upload the .obc file to check and tell you why
  23. crnrstndes
    The mouse is about 3" long and won't simulate properly.
    Zoomed way out!
  24. Peter Van Der Walt
    Post the gcode then :) same rule, need the file of the thing that causes issues to see why it does, otherwise guesswork is all I can offer
  25. Nurgent Leukes
    I am in need of assistance. My cnc was working fine and then it said it needed version 1.0.1 at least. I updated both the arduino with the grbl and the openbuildsControl software. Now it is giving a error code and I cannot get the machine to work. The error is error: NaN - undefined [$J=G91G21X1F4979] Please help me.
  26. Peter Van Der Walt
    Grbl 1.1 has been out since Dec 10, 2016! :) so excuse us for not supporting older versions, its pointless by now.
    $J is the Grbl 1.1 way of jogging, you need a Grbl 1.1f or newer controller to use OpenBuildsCONTROL.
    You still have an older version (so either you didnt upgrade to at least 1.1f, or your upgrade didnt actually succeed at all) as it rejected the $J jog command that CONTROL sends it: See gnea/grbl
    If your controller can't be upgraded, consider a OpenBuilds BlackBox 4X Documentation
  27. Nurgent Leukes
    Lol!!!
  28. Nurgent Leukes
    Hi, thank you for yesterday. I do appreciate it. now I'm not sure if this is the right platform or not, but I'm trying to upload grbl to my arduino uno. I have a cnc shield, not sure which one it is. But whenever I upload grbl to the arduino it always fails and gives me a message of avrdude: stk500_recv (): programmer is not responding. Now when I remove the shield, the code uploads, but when I attach it it does not recognize the device. I have held in the reset button of the shield and uploaded the code but it did not work. Can you please help me.
  29. DavH
    DavH New
    If you are getting G code errors using GRBL, the post processor from your cam program is incorrect. CamBam has a post processor for GRBL.
  30. signup@100%
    in UGS platform,makesure you save your toolpath as grbl.gcode but my cnc is calibrated in mm.you wont get that invalid gcode file error again.
