Workbee 1010 stopping randomly in a job
Discussion in 'CNC Mills/Routers' started by Icefox20, Mar 2, 2019.
  1. Icefox20
    Icefox20 New
    Hey All
    I'm a Newbe when it comes to CNC, we have brought a workbee 1010 for my wife's Online biz and we have set it up got it cutting ...BUT... randomly in a job it will just stop moving, not always the same spot does it stop so i can't see a pattern , I press pause and start again and off it goes but after 3 times of doing this it just stops wanting to go and I have to force it to stop everything and home it.
    I'm not sure why it's doing this was thinking it was the home switches tripping with the rattling etc but that doesn't seem to be it, I'm at the end of my "lead rope" with it and I need help
    if anyone has ideas that would be great I'm not at home while writing this so once I do ill upload the gcode and Vcarve file to looking.
    thanks in advance
    Scott
  2. Giarc
    Are you getting good airflow over the controller? If the DRV8825 chips get too hot they can go into thermal shutdown.
    #2 Giarc, Mar 2, 2019
    Icefox20 likes this.
  3. Dmhaes
    Dmhaes New
    Make sure your fan is working, and maybe try another usb cable.
  4. Alex Chambers
    What control setup are you using @Icefox20.
  5. Icefox20
    Icefox20 New
    Awesome thank you guys ill have alook in the morning about the fan and maybe a new usb
    By controller setup do you mean the board?? @Alex Chambers
  6. Alex Chambers
    Yes, and software and connection method (usb, ethernet, WiFi?) Alex.
    #6 Alex Chambers, Mar 3, 2019
  7. Icefox20
    Icefox20 New
    @Alex Chambers its a xPro V3 (GRBL V1.1) its by USB and the software im using is the openbuilds control. thanks
  8. Colin Hart
    Colin Hart Well-Known
    I had a similar problem... The plug in the wall was not pushed in fully.. yes a schoolboy error but this was the root cause for my issue.
  9. Icefox20
    Icefox20 New
    So ive done some testing and the vfd and spindle turned off it does an air cut without stopping..... any ideas from anyone ??
  10. Alex Chambers
    Interference? Have a look at how your cables are routed to see if you can keep your spindle cables away from others.
  11. Icefox20
    Icefox20 New
    Thanks to all moving the spindles power cables has done the trick yahhhh. Ive made an arm to keep it above the cnc see photo :)
    Any ideas why i would be getting chipping on the cut outs tho ?? See 2nd photo . Im guessing it might be blunt cutter?? 20190306_213032.jpg 20190306_213032.jpg 20190306_213459.jpg
  12. Alex Chambers
    What cutters are you using? Unless I need a really small diameter bit I use router bits for cutting wood. Up-cutting milling bits would tend to damage the top edge of a cut. Even a sharp bit can occasionally chip a bit out of wood - it depends on how the tree grew. In your example it would be difficult to do this, but you can minimise chipping if the cutting edge cuts INTO the edge of the wood rather than OUT of it.
  13. Icefox20
    Icefox20 New
    Thanks for that can you recommend a bit so i get an idea of what im buying please thanks :)
  14. Alex Chambers
    Not knowing where you are based it is a bit difficult to recommend a specific bit. I tend to use cheap router bits from the likes of screwfix and Toolstation in the UK and replace them as soon as they start getting blunt. I find this is more cost effective than more expensive bits which don't last that much longer to justify the extra cost. Cleaning bits often (use solvent to clean off any resin buildup) will keep them sharp for longer.
    GrayUK and Icefox20 like this.
  15. Giarc
  16. Icefox20
    Icefox20 New
  17. Giarc
    I cut in from the top. On harder materials I ramp in from the top. On HDPE plastic, which is what I have used it on the most, I just plunge from the top as seen in the video down the page here: Adjustable Rod Holder Track Mount For Fishing
  18. Christian James
    Christian James Journeyman
    Yes, important question Icefox because some straight flute bits do not have a full cutting edge across the tip - those are side entry only. Giarc is using one which has a full cutting edge on the tip so it can plunge down into the work.
  19. Icefox20
    Icefox20 New
    Awesome thanks everyone for all the advice its going to make CNC cutting a lot easier with help like this :)
