Double D-Bot 400mm x 400mm x 600mm
Discussion in '3D printers' started by Troy Proffitt, Nov 30, 2016.
  1. Troy Proffitt
    Troy Proffitt Journeyman
    Ok, I re-designed the upgraded carriage pieces that I'm going to mill out of aluminum so that the belt attachments aligned better, and added the fan attachment for 50mm fans. Here is the link to the files on thingiverse: D-bot Linear rail Carriage by tmproff
    new_carriage0_v2.jpg new_carriage2_v2.jpg new_carriage3_v2.jpg new_carriage4_v2.jpg
    #61 Troy Proffitt, Feb 15, 2019
    patnap71 likes this.
  2. Troy Proffitt
    Cut out on my CNC last night. Everything matches up and ready to install on my printer: 20190219_081228.jpg 20190219_081248.jpg
  3. Troy Proffitt
    Also, here is a vid of my CNC cutting the aluminum. Pretty happy with the speed at this point and the cuts are perfect:
    cobrettee likes this.
  4. Troy Proffitt
    New carriage installed on the printer last night. Unfortunately, the belt material was about 1" too short on both sides for this smaller carriage so I had to order more. 20190220_071942.jpg
  5. Troy Proffitt
    I decided to upgrade to a Duet wifi 2, and while I was at it, I tore down my old printer and upgraded it to the new C-beam z axis upgrade: upgrade1.jpg upgrade2.jpg upgrade3.jpg upgrade4.jpg
  6. patnap71
    patnap71 New
    Looks good!!! :thumbsup: If you have a few moments to spare can you take a tape measure and tell us your verticals, horizontals, sides and rails lengths. I know I'm a pain. :D
  7. Troy Proffitt
    Sure, I can do that when I get home from work.
  8. Troy Proffitt
    Ok, sorry for the delay. Vertical pieces are 26". Front and back horizontal pieces are 21 1/8, side pieces are 19"
  9. Zip15
    Zip15 New
    I’m just getting started with 3D printers and this looks like exactly what I’m wanting to build. Has anything changed since your last post? I’m not sure I even know the right questions to ask yet, but this build looks great. Can you post a new picture of it?
  10. Troy Proffitt
    Search for d- bot on thingiverse. It has all the instructions. I have changed a few things but nothing major. Its printing well right now. Dont want to mess with it
  11. Zip15
    Zip15 New
    Could you tell me where you got your hot bed? And what build did you do for your CNC machine.
  12. Troy Proffitt
  13. Troy Proffitt
    Well I took the Cbeam concept a step further and switched to linear rails and designed a 3d printed part that connects it all together. I have installed it on my printer and should be attaching the bed tonight. Here is the file on thingiverse if you are interested: C-Beam Linear rail z axis actuator by tmproff
    patnap71 and Peter Van Der Walt like this.
  14. Troy Proffitt
    Well, this didn't work out as well as I'd hoped. The ABS mount isn't stiff enough (and I think the orientation of the linear rails) , so the bed is unstable. I'm going to rotate the linear rails so they face inward and use a piece of CNC'd aluminum instead of the 3d printed piece to attach the linear rails to the bed. Should have some pics tonight.
  15. Troy Proffitt
    Ok, got the new piece installed and attached to the linear rail. It's rock solid and moves pretty smoothly. Going to try to get the other side done and the bed attached tonight 20191105_214617.jpg 20191105_220221.jpg
    #75 Troy Proffitt, Nov 6, 2019
    patnap71 and MaryD like this.
  16. Troy Proffitt
    IT WORKS! I'm super satisfied with the movement and stiffness of the linear rail. I do need to move everything down about an inch so I can use more of the rail (I should get about 400 mm z movement). Also need to rotate the z axis stepper 180 so it doesn't interfere with the bed.
    Rachel Holley and Paul Stoller like this.
  17. Zip15
    Zip15 New
    Thanks for keeping everyone updated on your build. I’m hoping to start mine this month and am sure I’ll have lots of questions.
  18. Troy Proffitt
    Now I just need to figure out how to get prints to stick to my shiny new piece of tempered glass...
  19. patnap71
    patnap71 New
    Has anyone tried frosted or sandblasted glass?
  20. Troy Proffitt
    Update... I LOVE printing on Glass!! Using extra hold aquanet hairspray, and prints stick very well and come off so easily after bed cools down. Never going back to PEI.
  21. patnap71
    patnap71 New
    I have heard sandpapered Polycarbonate (Lexan) about 5mm thick stays flat under heat and sticks like PEI and is cheap at big box hardware stores.
  22. Troy Proffitt
    That video sure didn't convince me :) looked like he was having a very hard time with it
  23. Troy Proffitt
    I cleaned my x and y linear rails last night. I was amazed how dirty they were, and also noticed some play in 2 of the blocks. I ended up replacing the bearings in the blocks and it improved them significantly.
    Here is a link to a vid that shows how to clean them (which only takes about 10 mins per linear rail):
    Here is a link to the ball bearings for MGN12 linear rails : https://www.amazon.com/Inch-Chrome-...ECZW7WH8JP0&psc=1&refRID=2EJBMPZ51ECZW7WH8JP0
  24. SilentMike
    I saw on your YouTube channel you upgraded to a Duet Wifi and BlTouch. Are you still using the Pi with it or just using the duet wifi?
  25. Troy Proffitt
    you don't need the pi if you have the duet wifi. It comes with a web interface and all the nice upgrades of 32 bit.
  26. sergeygygierm
    Вечер добрый, прошу прощения если темой ошибся, на моем компьютере этот сайт с ошибкой открывается наверное у меня программа глючит в чем проблема не могу понять, у меня у одного так или у всех?
  27. Troy Proffitt
    Here's a vid of some rapid printing @ around 130 mm / sec :
  28. Troy Proffitt
    I'll probably start a new thread about this upgrade but just for posterity sake, I'll add it to the overall build thread as well. I am currently testing out the concept of using an external air source for my parts cooling fan and using a long CPAP hose to attach to the print carriage. This should provide 2 advantages...Firstly, if I ever enclose my printer, since the air source is external, it will be pumping cool air onto the print object. Secondly, it should lighten up the carriage and reduce vibration (I currently use 2 50mm fans attached to the print carriage).
    For the air source, I took apart an old CPAP machine and retrieved the 3 phase centrifugal fan:
    To control it, I ordered a 3 phase 12v controller off Amazon:
    This includes a switch to invert the direction of the motor and a potentiometer to increase / decrease the speed of the motor. I used the 12v 5amp power supply that came with the CPAP machine since I felt like this would be too powerful for my Duet2wifi controller so I purchased a DC-DC relay so that it will use the printer controller fan voltage to signal the relay only. To protect everything, I went to Home Depot and purchase a little electrical box and drilled holes to accommodate the input air for the fan, the fan speed control and wires.
    Finally, I needed to re-design my D-bot carriage to receive the incoming air source and divert it to cool the print part. Right now, I'm waiting for the 1/8th inch to 3/16 barbed tubing connectors to come in the mail so I can put everything together. Also, while I was at it, I'm transitioning to an E3D Volcano hotend (can't hurt right?) More pics to come.
    #88 Troy Proffitt, Jan 3, 2020
    SilentMike and patnap71 like this.
  29. Troy Proffitt
    So I finally got the CPAP blower working on my printer. Works great! I have the blower set to a very low RPM and it still puts out more air (and it's cold air since it's away from the bed). Here is a video of it in action:
