Fusion G code problems
Discussion in 'CNC Mills/Routers' started by michael lacasse, Mar 27, 2019.
  1. michael lacasse
    Hey guys I am using the new black box and using Openbuilds Control to move it around. It works great when I use the Openbuilds cam software to cut g-code but when I use fusion 360 all I can get is the tool to move from 0,0,0 to the side of my part and it wont move any futher. Also, I am using the WorkBee - Duet.cps post processor since F360's grbl doesnt seem to work. Can some one please help?
    Thank you
    p.s. see attached. 001 is my cut file (a simple square)
    • 001.txt
      File size:
      6.6 KB
      17
  2. sharmstr
    I looked at the code and nothing is jumping out at me as being an issue. Its missing some codes that I normally like to have in my files, but again, I dont see that as an issue.
    Try this post: swarfer/GRBL-Post-Processor
  3. michael lacasse
    See attached image. I get blank properties when I try to write with the Openbuildsgrbl post processor. Same thing when I try the fusion36 - easel. Am I doing something wrong?
  4. sharmstr
    That's usually an indication that there is something wrong with the javascript. How did you get the files? Did you download or copy and paste?
  5. David the swarfer
    from github you need to download the zip file and then extract from there.
    hit the green 'clone or download' button and download the zip
    now extract the cps from that.
    (yes there are other ways but this is the simplest)
  6. michael lacasse
    Thanks guys. I will try that. I did a right click, save link as.
