Limit switches with BlackBox
Discussion in 'Controller Boards' started by Eli Endres, Jun 6, 2019.
  1. Eli Endres
    Can I add switches to both ends of my axis by daisy chaining together limit switches?
    Parallel wiring if you are using Normally Open Switches
    Serial wiring if you are using Normally Closed Switches
    See gnea/grbl
  3. Eli Endres
    Thanks! I'm using the xtension switches that normally open.
    The third pin is just for power to the LED right? I can just run that in parallel as well?
    Correct :)
  5. Neil Scott
    Hello, I have simple question, is it possible to add a LED direct onto the limit switch itself? if so any ideas on what sort please. Controller is Blackbox, awaiting arrival.
  6. sharmstr
  7. Neil Scott
    Thank you, I haven't got my kit yet , just about to order, and looking at the switches I didn't realize they had one, thats great thank you. Saves a bit of work now!!
  8. JTB715
    JTB715 New
    Will OpenBuilds make a schematic for the Xtension Limit Switch available?
    Pretty basic, so if you have issues, let us know what and we'd be happy to help troubleshoot:
    Switches closes SIG to GND when triggered. V+ is used to power the LED and pull-up resistor.
    There is a filter cap across SIG and GND. That's all there is to it
  10. Guillaume Rancourt
    I've had a problem installing the blackbox to an older CNC a friend had, we got the motors working, but he connected the wires for a micro switch on Ground and V+... resulting in the blackbox not responding anymore and motors will not be powered or moving anymore. Do we have to ask for a replacement board for the black box or there is a relay i can look at to get it going? maybe a capacitor?
    I must have created a short adding the v+ power to the rest of the circuit.
    I'm trying to trouble shoot but now, the computer won't connect to the blackbox when before we hit the limit switches, all was working flawlessly.
    Thanks,
    While I am truly sorry to hear about your unfortunate accident, unfortunately there is a big warning on docs:blackbox:connect-micro-limit [OpenBuilds Documentation] against exactly that: - you can ask [email protected] if they might be willing to sell you a replacement Brains Board only (cheaper than a complete BlackBox) but very NB do recheck all wiring before powering on any time you work on wiring.
    Shorting out the power rails typically results in unrepairable damage.
  12. Guillaume Rancourt
    I know exactly That! Still, we need to get it working so, i'll have to order a new brain yes.
  13. Jerry Fountain
    Peter, regarding a schematic, I've got the same question since it would give appropriate values for the cap. Likewise, I can measure V+ for determining the current limiting resistor for an LED, but it's always nice to have documentation. I noticed that all of the CopperPour listings indicate "This design or build includes CopperPour, LLC design work(s) shared Open Source under the CC BY-NC-SA 4.0 License". Is this just the mechanical parts or are the electronics also open source? If so, where would we find the source :)
  14. Jerry Fountain
    I see the suggested filtering values listed here. Can we assume these are correct for the Black Box implementation? Is V+ here 5V or is it 3.3V? I haven't checked my BlackBox to see what it uses.
  16. Jerry Fountain
