I am new . Have just order the Black Box , looks as what i need,
Discussion in 'General Talk' started by Lloyd Downunder, Jun 5, 2019.
  1. Lloyd Downunder
    1. my first Q'S is as it runs under GRBL is it pre flashed? to the unit.?
    2. OK if so , how do we calibrate it?
    3. I am using a 20 t pulley on X/Y and Z M8 lead screw.
    i am 78 an lov this stuff , so please explain in old and drecriped language??OK
    Lloyd
    MaryD likes this.
    1. Yes
    2. Download OpenBuildsCONTROL -> Tools and Wizards -> Calibrate
    2.1 We also supply predefined profiles for all our machines on the Grbl Settings tab (no need to calibrate/guess settings)
    3. There are step size calculators on the Grbl Settings tab next to each steps-per-mm box where you can tell it your belt pitch, pulley diameter and microstepping (1/8th by default on Blackbox) and it calculates it for you
  3. Lloyd Downunder
    Gyday Pete
    Thanks for your reply, you have explained it for me. to start with.
    Have loaded the controller but yet to explore it? is there any manuals or instructions ?
    my lazer runs GRBL no probs. the Router was running Marlin (hate it) and is now brainwashed, so the black box.
    Lloyd
    BlackBox runs Grbl, so between docs.openbuilds.com/blackbox and github.com/gnea/grbl/wiki you'll find all the reading material you need
  5. Lloyd Downunder
    thanks Pete
    i now have some reading to do.
    Lloyd
    also checkout our many wiring/controller/software tutorial videos on OpenBuilds® (even if your specific machine is not the subject of a video, the system is quite modular so what counts for one counts for most)
