Need help with upgrading my X and Z axis setup...
Discussion in 'Other Builds' started by thatguypeter, Jun 8, 2019.
  1. thatguypeter
    Does anyone have the step file for the Open Build WorkBee X and Z plates? I look everywhere in the parts file and its not available. I don't want to buy the whole Workbee plates set. I just need the X front and back plates. Can someone provide a step or stl file of these plates? The plates is available in Sketchup but not for Step file. Is there a way to export the parts out of Sketchup?
    Peter
  2. Giarc
    If you just need an stl file, you can open it in Sketchup and export it.
  3. thatguypeter
    I try that and it doesn't work on the web base Sketchup. I can't get the parts I needed to be a single part, even after I exploded the component many times to get the single part to be select able. It will not allow me to export it as an STL for the single part. It capture all the parts and make it as a single part when exporting to STL.
    Peter
  5. Christian James
    Christian James Journeyman
    These any good?
    thatguypeter likes this.
  6. thatguypeter
    Thank You Thank You!!! You guys rock! Now I will used my old setup to mill out the new plates for the x and z!
    Peter
