Brand new black box
Discussion in 'Controller Boards' started by Chadfarmer, Jun 3, 2019.
  1. NthAxisWorkshop
    - Alex, you beat me to it. :)
    If I understand correctly, the stepper wiring / current has been resolved and now limit switches are the issue? To wire "plain jane" switches to the Blackbox : "c" (common) goes to GND and "no" (normaly open) goes to SIG. Wire "nc" to SIG if you run your switches for break sense. If using Xtension switches GND to GND, V+(LED) to V+, SIG to SIG. Not rocket science, kiddo. As Alex said, wire color not really important except for keeping your connections straight. I think the Xtension wires use BLACK,RED, BLUE color scheme. Switches broke..from the PCB? From the solder terminals?
  2. sharmstr
    He indicated on the FB page that it ended up being a loose wire.
  3. NthAxisWorkshop
    Ah. The infamous FB. Didn't realize these were being mitigated there as well. Noted.
  4. sharmstr
    I try to send support issues over here. Its much easier here than FB. But everyone has their preference I suppose.
  5. Chadfarmer
    Got it all going doing opposite of the diagram lol go figure.
    Did you notice the text above the image?
    See the TIP section.
  7. Sully3535
    Sully3535 New
    I am having the same problem. Won't connect.
    Follow the advise above, step by step, and advise.
    Disconnect everything
    Just plug in USB
    Make sure you have FTDI Drivers installed
  9. Sully3535
    Sully3535 New
    Thanks for the screenshot but no mention of the rest?
    - Wiring mistakes can prevent the board from booting properly
    - incorrect FTDI Drivers can cause USB issues: Virtual COM Port Drivers
  11. Sully3535
    Sully3535 New
    I tried all of that. Tried a different computer as well. Same issue.
    Thomas C Kelly likes this.
    Have you tried reflashing from Tools and Wizards -> Grbl Flashing on the toolbar at the top?
  13. Sully3535
    Sully3535 New
    Yes. I can see a red light on the controller flash when I do that. But after that still no connection.
    Does it succeed or fail (on the Serial terminal)
    :) The more details the quicker we can get to the bottom of it.
  15. Sully3535
    Sully3535 New
    I don't know what that means. It was working fine until the fan quit. I have made no changes to the controller or my computer.
  17. Sully3535
    Sully3535 New
    Thanks. I have been in contact with them already.
  18. Sully3535
    Sully3535 New
    Flash failed
