OpenBuilds CAM Software
Discussion in 'CAM' started by Mark Carew, Oct 8, 2018.
  1. Jet Jaguar
    Thank you for this software. It is amazing!
    One issue:
    I encounter an error when attempting to open a Gerber file.
    An unknown error occured:TypeError: Cannot read property 'primitives' of undefined
    1. I created a PCB with Eagle 9.4.0.
    2. I opened the CAM Processor.
    3. I set the Units to Metric.
    4. I clicked the Load job button.
    5. I moused over Templates and selected "Single Layer Default".
    6. In the Output Files section I clicked the Top Copper item.
    7. At the bottom I clicked Advanced.
    8. I clicked the Mirrors Gerber output horizontally button.
    9. I clicked the Process Job button. A notice indicates that the Job processed successfully.
    10. I opened OpenBuilds CAM Gcode Creator - Public Beta in Chromium Version 74.0.3729.131 (Official Build) snap (64-bit) on XUbuntu 19.04.
    11. I clicked the File button and selected Open Drawing File.
    12. I selected the file copper_top.gbr (attached, zipped) and clicked the Open button.
    The error displayed in red at bottom of web page.
    Thank you
    Jet
    Lovely detailed report with files too! Thank you! Makes my day to look into this one for you :)
    Will let you know when i get it fixed :)
  3. Jet Jaguar
    Anytime.
    Jet
  4. Nick W
    Nick W Well-Known
    upgraded to 1.0.172, and it will not launch. I get the message below.
    I reverted back to my last download, 1.0.156 and it works fine.
    Windows 10.
    :) wrong thread. This is OpenBuilds CAM
    Control is over on: OpenBuilds CONTROL Software
    Hehe
    156 is pretty old so hard to know what the issue is then. Head over to OpenBuilds/OpenBuilds-CONTROL and try a not so old version like 170, or 169.
    Also, uninstall and cleanup before installing the new version. Try a different PC too.
  6. sitoru
    sitoru New
    I have a Logitech wireless 3 button mouse, but it still won't work correctly in Mac OS. It did work under linux correctly. I've already tried their software to set the middle button, but cam still sees left and middle button as the same.
    Use the transform tool on the left. You can just type where it has to move to, no mouse move needed
  8. sitoru
    sitoru New
    this is all I have to the left
    Bottom one
  10. sitoru
    sitoru New
    hadn't seen that
    Click and explore. Theres many buttons, playing with them is the best way to learn what each does
  12. Fábio Pires
    Hi there guys. i love your cam software. i loved to use it but i found a problem. i'll try to describe it.
    this is my workflow:
    i design something in sketchup (2017 version) for example a 100 milimeter square.
    the i export it as a svg file using a sketchup extension. then due to known problem with the svg format i have to open it in makercam.com and save it there.
    then i open it in openbuilds cam software but everytime the 100 milimeter square is smaller around 95 milimeter. it hapens with any file i import.
    can you help me?
    Use the GuitarList DXF plugin to export DXF Polylines from Sketchup. Works straight away, and DXF uses mm as a native unit so no scaling problems
    Convert Sketchup SKP files to DXF or STL | guitar-list
    As SVGs are more for the artists, it uses Pixels as a unit, and varying DPIs between various programs, to try and scale back to mms. Lack of standardization means always battling scaling issues with SVGs. DXFs are for Engineers (;
  14. Fábio Pires
    thanks i'll take a look.
  15. David the swarfer
    or you can generate you gcode from Sketchup using the SKetchUcam plugin.
    swarfer/sketchucam
    You can then import the Gcode into OpenBuildsCONTROL. We are working on a new release that will send it direct.
    SketchUcam Howto - YouTube
  16. gregers05
    gregers05 Well-Known
    My lead is now powered up finally, but I have been having issues with the OB Cam software. When I add a toolpath, specifically a pocket, I will click on "Apply" once I have my settings complete and then it gets stuck in "Calculating Toolpath" and I have to close the whole window down and lose my project. I am using Chrome as my web browser. Any ideas what is causing this? Anybody else have this issue?
  17. Award
    Award Well-Known
    I'm not sure if this what is causing the same issue for you but I had the same symptoms when I first used OB CAM because I put in the depth of cut as zero and it had a sulk when trying to calculate the path :oops:. Division by zero makes it go into an infinite loop and uses up all of Chromes memory.
    Adam
    Please post your file (dxf or svg) and screenshot of your pocket settings
  19. gregers05
    Those arent my final feed rates and I may have adjust the depth once I decide what my work piece will be, I am basically just messing around with the software trying to learn it.
  20. Peter Van Der Walt
    Now just this (;
  21. gregers05
    oops sorry...I was bringing in a .jpeg. Imported well, I havent had luck importing .dxf files either, but one thing at a time lol
  22. gregers05
    here is my jpg
  23. Peter Van Der Walt
    Make sure you export as DXF R14 Polyline format :)
    OK so took your file, and ran a Lettering, Gear and Circles ops, same settings as yours, no problems :)
    Attached OBC file (Can be imported from CAM -> File -> Import OBC) to see what I did.
    I am not sure of your PC specs, but if its a entry level/oldie it might just be running out of steam. Try disabling the Tool-Width-Preview from Settings
    and at the bottom here, the attached OBC (Workspace export)
  24. gregers05
    Awesome thanks. I was trying to do an inverse of what you did, which would leave the lettering, gear and circles raised and everything else recessed. When I selected to make a pocket out of the "ring" with the lettering inside of it, I would select the larger circle that borders that pocket and use that to create a pocket. Should I have selected something else? I am doing this on my work computer so it has plenty of juice, it is what I run solidworks on. I will try it also on my personal desktop as well.
    As for the DXF R14 polyline format, it actually made it worse doing that. Could be because I sketched over a photo in solidworks using splines and it just isnt converting well? In the dxf preview when I converted to dxf it looked good, but went crazy when I import it into OB CAM. I attached the OBC file and the dxf for that.
    Supposed to look like this:
  25. Peter Van Der Walt
    Explode your Splines to Polylines
  26. Peter Van Der Walt
    :) fair enough, guessed at it
    But moral of the story is that i dont think its bug, per-se. The bigger problem here is workflow: I would never expect to do such a massive pocket with a 1/8inch bit! So its creating unneccesarily large toolpaths. Sure you can do that in Fusion360 or Vectric but on the free solutions one sometimes has to compromise on expectations. In this job I would probably do my pocket with say a 8mm or 10mm bit, then run the letters as Outside cuts with the 1/8th to cleanup their details
  27. gregers05
    Not sure how to explode the splines to polylines, but I will look into it and see what I can work out. I did actually have luck just importing the .jpg file until I tried the logo with text and the text looked different than the logo, but I will mess around with that too.
  28. Peter Van Der Walt
    All just some trial-and-error-learning :)
    Simulator and preview helps a lot!
    Explode: I dont have SW, but you can always have an intermediate step -> Export DXF -> DXF into something like LibreCAD or Draftsight, explode, export as R14 Polylines
  29. gregers05
    I agree on the 1/8" bit for those pockets, I would probably use something bigger if I were actually cutting it out. The advice of running the letters with a smaller bit is a good idea though! I am just now starting to play with this software now that I am to that point in my build, so I am not sure what to expect with it. But the more I play with it, I will become familiar.
  30. gregers05
    Okay cool, I will try that tonight to see how it does if I can find some free time.
