OpenBuilds LEAD CNC
  1. jamin35008
    jamin35008 Well-Known
    I have black connected on the top and red in the middle.
    Middle and top might not be as good to check as the printed labels next to the pins. Should be C (Common), NO (Normally Open) and NC (Normally Closed)
    If you run Normally Open (Wired between C and NO) set $5=1
    If you run Normally Closed(Wired between C and NC) set $5=0
    (note that all switches on the machine must be wired the same config as you cannot configure NO/NC per-axis
  3. gregers05
    gregers05 Well-Known
    Thanks, what did you do with the blue wire? Not needed?
  4. gregers05
    Thanks for that ^^^!.
    Do the OB switches run NO or NC? Which would you recommend? I have seen positives and negatives to both.
    We run Normally Open. To mitigate the cons those boards have onboard RC noise filters (; its more than just a switch
  6. jamin35008
    Unfortunately I don't see any printed labels next to the pins on the cnc4newbies z axis limit switch. I tried following the same connection as mentioned for the limited switches in the LEAD 1010 assembly video.
    I don't have a blue wire for the limit switch. I used the same wire that would have been used for the original LEAD Z axis limit switch which was just a black and red wire.
    They might be embossed
    I think they use this style? All the ones I've had in hand had it molded on the sides. Maybe the side installed on the plate?
  8. Alex Chambers
    If you really can't find the markings it's very easy to identify them with a meter set to continuity/resistance - continuity/low resistance =NC pair, same when switch pressed = NO.
  9. jamin35008
    Yes I believe this looks like the same type however they attached it upside down compared to your diagram so the COM is on top and NC on the bottom. So I have black connected to the COM and red to NO.
  10. jbhurst
    jbhurst New
    I'm having a weird homing problem on my LEAD 1010 w BlackBox, and am looking for some troubleshooting tips.
    Here's the sequence of events:
    1. Click home (or $h)
    2. Move machine to 0.5" x 0.5"x0.3" in WCS 54
    3. Position is perfectly centered to a pin there
    4. Move up in the Y, move back in the Y, machine no longer centered (off about +1-2 mm or so in the Y)
    The really weird part (to me) is that once I do #4, it STAYS correct.
    In fact, the super-kludgey workaround I am using is for all of my programs, I added a header that homes, then moves up in the Y a couple inches, then moves back, then does whatever it is going to do, and I set my WCS origin with that in mind. ie. - if I home it, and then immediately move somewhere and set an origin, then move away and come back, it will be off, but it i move it in the Y before setting the origin and make sure to always move it in the Y before running a program, the origin will remain true. The problem doesn't happen in the X or Z.
    Next on my list to try is running the above cycle with OpenBuilds control instead of bCNC and trying it in mm as well as in (bCNC, grbl, the macros, and the programs are in inches now due to the procedures in our shop). After I try those, however, I am pretty stumped for what else to even look at.
    Has anyone seen something like this before? Is there another forum I should post this on?
    -Brady
  11. sharmstr
    99% sure its backlash. Loose motor couplers, worn anti-backlash nuts and loose lock collars can cause this.
    jbhurst and Peter Van Der Walt like this.
  12. gregers05
    Thats strange. Mine had 3 wires and uses the 3 pin connectors on all my limit switches
  13. jamin35008
    I think I got some of the last of the older limit switches with the 1010. They only had two pin connectors.
  14. gregers05
    Yeah i guess thats what is throwing me off. I know what to do with the red and black, but not a clue where the blue singal wire is supposed to go
  15. Alex Chambers
    Click on the build tab above, scroll down to the videos, select the wiring one - 42' in it tells you how to connect the limit switch wiring to the blackbox - black = ground, red = positive, blue = signal.
  16. gregers05
    correct. I have no issues with connecting to the blackbox or knowing which color is what, but on the cnc4newbies limit switch, I don't know what to do with the blue wire. Those are always wired up with just a red and a black. Not sure if I need to tie in the signal wire with the red or black, or just stick it on the unused pin that the red and black arent connected to. So, if I am using the COM pin and the NO pin, does the blue go to NC, or does it tie in with the wire that is on NO or COM? Maybe the disconnect is that I don't know what the signal wire does?
  17. Alex Chambers
    The blue is the signal (NO if you are configuring the blackbox for normally open limit switches I believe - not an expert on the blackbox) red is positive. If you use a switch to connect red to black you will be connecting positive to ground.
    Perhaps @Peter Van Der Walt will chip in here (he is an expert on the blackbox) and correct me if I'm wrong.
    NO on switch = Sig on BlackBox
    C on switch = gnd on BlackBox
    not connected on switch = v+ on blackbox (dont connect anything to it)
    Set $5=1 in Grbl Settings to use NO (Normally Open) switches
    Snip off any 3rd wires
  19. gregers05
    perfect, exactly what I was looking for! My knowledge on limit switches/controllers and cncs is pretty limited as this is my first cnc build, so I am learning on the fly. Sorry for all the questions, but the customer support and community here is one of the main reasons I went with OB.
  20. jeffmorris
    jeffmorris Journeyman
    I have CNC XPro V3, external stepper motor drivers, and 24V PSU inside a plastic box with 24V fan and E-Stop switch mounted on top. I put the box at the front of my LEAD Machine. The wiring video shows the BlackBox at rear of LEAD machine. How should I mount the cable chain along Y-Axis so that the wires come out of cable chain at front of my machine?
  21. jbhurst
    jbhurst New
    Can it not just be spun around and anchored to the front instead of the rear? ie - The chain would be fully extended with the gantry at the back instead of at the front, but it should work in either direction. Then, you'd need to run the wires for the Y steppers to the front, but they don't need to be in the chain. The front Y limit switch would also not need to be run to the back. With the chain terminating in the front, the rest of the wires such as the X and Z steppers and limits, ring light, and any other attachments you have would be at the front once the chain is reversed.
  22. gregers05
    I would agree with this. no reason you shouldnt be able to reverse it. Just double check your drag chain links to make sure the joints are bending the right way
  23. gregers05
    Well I finally got my build almost done and was able to fire it up and run the hello world test program!
    z limit switch is working great, appreciate all the help with that!
    @jamin35008 did you change any steps or anything else in grbl settings for the cnc4newbie z axis?
    How would one wire in a e stop button to the back box? The stop program button has a delay for me, which I think is due to my tablet just lagging.
  24. Peter Van Der Walt
    Yeah on a decent PC stop is near instant. You can wire a switch to the Door terminal. But note its not advised. EMERGENCY STOPS SHOULD CUT ALL POWER :)
    IE place a mushroom style emergency button inline with the mains coming to your power strip. An emergency can be ANYTHING (Router on fire, psu on fire, PC on fire, who knows) - do you really want to rely on software to just halt movements? What if (more likely) the problem is not movement... Think about it...
    jamin35008 likes this.
  25. gregers05
    That is a very good point! I also am not a fan of the E stop being only on software based. That being the case, I basically just flip the switch on my power strip that is mounted on my workbench that has all the psu plugged into it. I havent mounted it yet, so I need to make sure it is in a spot that is quickly accessible.
  26. Peter Van Der Walt
    Its one of those questions i have to answer way too often :) maybe as an engineer the logic of why a software estop is bad, is just too logical to me! Lol. But yeah, just a little thinking and you realize, yeah, power is the dangerous one (;
  27. jamin35008
    Nope. I didn't change anything and its working great.
    I have been using the on/off switch on the IOT relay. The switch is located right next to the machine and my laptop. Is that okay to use as an estop or should I consider getting a big red button and place it between the power outlet and the IOT?
    Also, the other day I was surfacing three boards I laminated together for an upcoming project and noticed that my 1" surfacing bit was leaving step marks. I did surface my wasteboard several months ago with no issues so I know its square to the machine so I'm thinking my router needed tramming. I found the method in the attached photos of using a board with a bolt in one end and a router bit in the other. The distance the bolt is from the surface will show how the router is sitting and whether its level or not by swinging the board around in a circle. Where the bolt is hitting the surface or low spot will indicate which way the top if the router is leaning.
    It was eye opening of how far out of alignment my router was!
    I adjusted the router by loosening the two screws on the front of the router mount, moving and leveling the router by eye and trying the tramming test again. This took several attempts before getting the bolt to within about 1mm deviation from the high and low spots which would mean its even less at the router bit.
    Is there an easier/better way to tram the router without having to mess with the screws on the router mount and moving the router by hand? Its hard to get very fine adjustments doing it this way. Every time I want make a fine adjustment I end up moving it way to much and having to start all over again. Thanks!
    jbhurst likes this.
  28. gregers05
    Good to hear about the Z axis working with no changes!
    As far as tramming I am curious about this as well. I am using the Makita router with a 3D printed spacer, so I assume I will be going through the same process you are.
  29. Alex Chambers
    I'm working on a gadget that might help with this - I couldn't work out how you could hold the router mount still to tighten screws after adjustment. Gadget is printing at the moment, so will be a day or two before I know whether it's any use. Will post in resources if it works.
    gregers05 and jamin35008 like this.
  30. Peter Van Der Walt
    Ultimately, its what you feel comfortable with. People tend to like the big button as a uncontrolled "bash" is enough to cut power (maybe you dont have time to find a smaller switch), but whatever you feel comfortable with. In a makerspace I used to be involved in we had two inline switches, with the one switch by the door on the way out: the logic was "you may want to cut power while you run for your life! " lol - a bit over the top, but then again that was for other's safety too
