Project Lead/Ballscrew Max Speed Calculations 2016-10-16
figure out how fast you can spin it before you risk whip
  1. Julius
    Julius Well-Known
    Jdog likes this.
  2. MaryD
    MaryD OpenBuilds Team
    Thanks for posting this!
  3. evilc66
    evilc66 Journeyman
    If I have this straight, the safe RPM's for the different stock lengths of the C-Beam would be as follows:
    250mm - 426 rpm
    500mm - 106 rpm
    1000mm - 26 rpm
    (80% of critical speed)
    This is assuming the root diameter of the lead screw is 6mm, and the supported length of the screw is the same length as the extrusion. From what I found, root diameter is the overall diameter minus the pitch
    According to this calculator, the OB steppers max out at the following:
    Nema 17:
    12v @ 1.68A - 382 rpm (3056mm/m, 120.3ipm)
    24v @ 1.68A - 768 rpm (6144mm/m, 241.9ipm)
    Nema 23:
    12v @ 2A - 300 rpm (2400mm/m, 94.5ipm)
    24v @ 2A - 600 rpm (4800mm/m, 189ipm)
    12v @ 2.8A - 214.2 rpm (1713.6mm/m, 67.5ipm)
    24v @ 2.8A - 428.4 rpm (3427.2mm/m, 134.9ipm)
    Nema 23 High Torque:
    12v @ 2A - 225 rpm (1800mm/m, 70.9ipm)
    24v @ 2A - 450rpm (3600mm/m, 141.7ipm)
    12v @ 3A - 150 rpm (1200mm/m, 47.2ipm)
    24v @ 3A - 300 rpm (2400mm/m, 94.5ipm)
    EDIT: Added mm/m and ipm travel speeds, assuming OB TR8*8-2 lead screw.
    #3 evilc66, Oct 19, 2016
  4. Julius
    Julius Well-Known
    Yes. That's why i don't like the idea of 5mm acme for over 250. I can bend it with my finger in the Z axis...
    I have 16mm ballscrews. With 48V they become the limit, at 300ipm. I'm ok with that! Currently at a max of 170 before the motors lose their torque.
    For my 1500mm machine next year i will have to use 2010 screws
  5. evilc66
    evilc66 Journeyman
    Added mm/m and ipm travel speeds to my post.
  6. Rafael Romero
    I know this is an old thread but I found it important.
    So, the RPM calculated by evilc66 are at 80% safety factor using Rigid/Free combination with 8mm lead screws.
    In my case, I ordered the Workbee 1010. It looks like it is Simple/Simple configuration
    At approx 20% from critical i should be safe from whip at about 300 rpm ... is this correct? I have not yet received it so Im not 100% sure of what support arrangements the unit has.
    Kind regards,
    Rafael
  7. kambo
    kambo New
  9. kambo
    kambo New
    Thank you so much Peter, i always forget this wayback machine :)
