Help With Installing Limit Switches to Chinese GRBL 0.9j
Discussion in 'CNC Mills/Routers' started by 1759adam, Jun 16, 2019.
  1. 1759adam
    1759adam New
    New to the forum and I've just completed assembly and modification of a Chinese CNC Router.
    I have limit switches mounted now on 2 on X, 2 on Y and 1 on the top of Z, but I can't figure out how to wire them to my Chinese 0.9j GRBL board.
    I have looked at many diagrams for wiring in series, but my GRBL Board has 3 pins on each of the X,Y and Z limit inputs. These are marked + - and S on the backside of board.
    Can anyone suggest how I should wire a Normally Closed circuit to this with my 5 Micro Switches, please.....?
    Image of mystery board attached with Limit Pins to the right of image.
    Many thanks in advance,
  2. Giarc
    I am not familiar with that board. Have you tried the manufacturer's customer service yet? They may be in the best position to help you.
    1759adam likes this.
  3. Christian James
    Christian James Journeyman
    I don't know that board either but the 3rd input pin (S) must be the signal pin and would be used together with the +/- pins for an optical sensor connection. If you are using micro-switches however, then just use the S and ground (-) pin, the "S" to "normally closed" on the switch and ground to "C" on the switch.
    Just do not wire it wrong ( keep away from the + pin - that's for the optical sensor)
    Have a look here at the series and parallel switch wiring..
    gnea/grbl
    #3 Christian James, Jun 18, 2019
  4. 1759adam
    1759adam New
    Thanks for replies. I'll get to work. Regards,
    Adam
  5. 1759adam
    1759adam New
    Thanks for your advice. I've connected 1 micro-switch as you suggested and it's now working. To get left and right limits on X Axis, should I connect Micro-Switches together via COM pins, and to -, and wire both NC pins together into S on the board?
    Many thanks,
    Adam
  6. Alex Chambers
    For Normally Closed switches you need to wire two switches on the same axis in series - signal (control board) to nc (switch one), common (switch one) to nc (switch two), common (switch two) to ground (control board)
  7. 1759adam
    1759adam New
    Many thanks, I was about to ask if this diagram is correct, but I think you have already described.
  8. Christian James
  9. Alex Chambers
    Bear in mind however that is for normally open limit switches.
  10. Christian James
    Yes Alex, and I believe pin 12 should be used and not pin 11.
  11. Alex Chambers
    Can't help with that one @Christian James, but hopefully someone who is familiar with that set-up will clarify that before someone tries to use that diagram. I think @sharmstr has used an arduino and may be able to help.
    Refer to the Grbl wiki for all the pin information gnea/grbl
  13. Christian James
    Yes Peter, that confirms what I thought and how mine is wired. Pin 11 has been grabbed for use by the spindle while the Z switch pin has been shoved onto pin 12
