OpenBuilds ACRO Z Axis
Discussion in 'Laser Cutters' started by petethepig, May 31, 2019.
  1. petethepig
    petethepig published a new build:
  2. Scotty Orr
    Scotty Orr Journeyman
    This is cool! I hope you can publish a few more photos (close-ups). Thanks!
  3. Mark Carew
    Ditto @petethepig looking forward to seeing more pics as well! Nice job
  4. yogeshnd
    yogeshnd New
    This is really awesome! I was just thinking of building the acro system, but was refraining as it doesn't have a Z axis.
    I'll be primarily using it to cut paper/cardboard with laser or a plotter cutting blade.
    Just curious, Do you think it can mill murals like these?? just works of art on foam or light wood maybe?
    Looking forward for updates!! Great job!
  5. petethepig
    Hi @yogeshnd. I don't think it will be able to do murals like that unfortunately. In foam — sure, but I don't think it could handle wood.
    I don't have any experience with milling, but I always thought there must be a reason those machines are always just much bigger and heavier than a 3d printer or a laser.
    yogeshnd likes this.
  6. petethepig
    Thank you guys, I updated the post with some pictures.
    Scotty Orr likes this.
  7. Scotty Orr
    Great job!! Thanks for the added detail!
  8. the_greek
    the_greek New
    Hello. What type of spindle have you attached?
  9. petethepig
    Hi, I'm currently using one of these brushless motors
    It's good enough for drilling small holes, but not good for milling.
    the_greek likes this.
  10. syl
    syl New
    Did you add a place to add an end stop for your z axis? Also how long did it take you to print out the 3d parts on your Prusa?
  11. Todd Brous
    Beautiful design on the Z-axis!
    I love how you have the support for the drag train on the top of the Z motor. I need to do something like this. So smart!
    I noticed that there is a threaded rod inserted in the light-blue 3d printed plastic piece on top of the Z-motor. What is this used for?
    Does the lead screw rub away the red plastic at the bottom of the Z-axis?
    Thanks,
    -Todd
  12. petethepig
    I'm not using any physical endstops, going with TMC 2130 drivers and their stallGuard feature. Speaking of printing, it took around 10 hours for the main part.
  13. petethepig
    Thanks Todd!
    That threaded rod is used as a spool pin for cotton thread. I use it when I make string art.
    Speaking of lead screw and the plastic — it doesn't rub away the plastic, the hole is larger than the lead screw. But I do think putting a bearing there would be a good idea.
  14. MatAff
    MatAff New
  15. petethepig
    MatAff likes this.
  16. DeltaCon
    DeltaCon New
    I am thinking of converting this Z-Axis setup to my Stinger Laser. Biggest difference is it has a 40x40 X-Axis rail. I like how compact this setup is. Question though: You are using eccentric nuts on 3d-printed plates. How is that holding up long-term? I always thought that it ould nbot work because it will wear off. How is your experience?
  17. DeltaCon
    DeltaCon New
    Second question: You made STLs of the carriage and the gantry plate with and without supports, but despite the difference in filesize, I see exactly NO difference. How does this work?
  18. petethepig
    That part has been working fine for me so far. Honestly, not sure what you mean by wear in this case. Are you worried the eccentric nuts will kinda rotate and move slightly over time? I haven't seen this happen with my set up. There are nylon nuts on the other side and they seem to be holding the whole thing in place well. This machine only has seen maybe around a 100 hours of work though, so your mileage may vary.
    Yeah, sorry it's not super clear, I answered a similar question on Thingiverse before: OpenBuilds ACRO Z Axis by petethepig
  19. DimitriGeelen
    would be happy to be able to order it as a kit, now scrambling to get all parts together
  20. julius64
    julius64 New
    Hello!, Great job!! I would like to ask you if you have seen any difference in the V-Slot Linear Rails (if the Linear Rails have been distorted for example)??
  21. petethepig
    Hi, are you asking if they bent or deformed or something like that under load?
    No, with this build plastic starts flexing way before aluminum.
    julius64 likes this.
  22. rhgrafix
    rhgrafix New
    What is the wattage of the laser part and approx. price? Thanks and good job!
  23. Alexander AG
    Hey. I have not found any STL files to align the profile. Can you post them?
  24. Eric Lorenz
    Fantastic Design! Compact and super sturdy! Thanks so much!
    It would help if there would be a bit more documentation/directions of the assembly process. The what goes where is clear but because it's so compact when I built it I had to take out a few bolts again because I realized too late that another one needs to go in first. But I also didn't take any notes I could share, so I'm not complaining ;)
    Thanks again!
