Help debugging blackbox
Discussion in 'General Talk' started by O G, Jun 27, 2019.
  1. O G
    O G New
    So I have a blackbox motion control to drive an ACRO1515 plugged to a raspi controller over wifi using the web interface.
    I can connect to the blackbox just fine. I can even flash the firmware to use the special acro grbl firmware. I can go in the troubleshoot tab and check that my limit switches are being detected correctly when I press on them.
    But I can't move my motors at all. I plugged in just the X to make sure I'm not breaking anything and it just won't move.
    I tried individually each motor on each port, no luck.
    The black box fan is not running. The I/O icon below the USB icon on the side of the black box is not light up. Of the 4 icons on the side of the blackbox only the one on the far left is light up.
    Any help is appreciated.
    [ $$ ] $0=10 ;Step pulse time, microseconds
    [ $$ ] $1=255 ;Step idle delay, milliseconds
    [ $$ ] $2=0 ;Step pulse invert, mask
    [ $$ ] $3=1 ;Step direction invert, mask
    [ $$ ] $4=1 ;Invert step enable pin, boolean
    [ $$ ] $5=0 ;Invert limit pins, boolean
    [ $$ ] $6=0 ;Invert probe pin, boolean
    [ $$ ] $10=1 ;Status report options, mask
    [ $$ ] $11=0.020 ;Junction deviation, millimeters
    [ $$ ] $12=0.002 ;Arc tolerance, millimeters
    [ $$ ] $13=0 ;Report in inches, boolean
    [ $$ ] $20=0 ;Soft limits enable, boolean
    [ $$ ] $21=0 ;Hard limits enable, boolean
    [ $$ ] $22=0 ;Homing cycle enable, boolean
    [ $$ ] $23=7 ;Homing direction invert, mask
    [ $$ ] $24=100.000 ;Homing locate feed rate, mm/min
    [ $$ ] $25=1000.000 ;Homing search seek rate, mm/min
    [ $$ ] $26=250 ;Homing switch debounce delay, milliseconds
    [ $$ ] $27=5.000 ;Homing switch pull-off distance, millimeters
    [ $$ ] $30=1000 ;Maximum spindle speed, RPM
    [ $$ ] $31=0 ;Minimum spindle speed, RPM
    [ $$ ] $32=1 ;Laser-mode enable, boolean
    [ $$ ] $100=57.143 ;X-axis steps per millimeter
    [ $$ ] $101=57.143 ;Y-axis steps per millimeter
    [ $$ ] $102=57.143 ;Z-axis steps per millimeter
    [ $$ ] $110=5000.000 ;X-axis maximum rate, mm/min
    [ $$ ] $111=5000.000 ;Y-axis maximum rate, mm/min
    [ $$ ] $112=5000.000 ;Z-axis maximum rate, mm/min
    [ $$ ] $120=500.000 ;X-axis acceleration, mm/sec^2
    [ $$ ] $121=500.000 ;Y-axis acceleration, mm/sec^2
    [ $$ ] $122=500.000 ;Z-axis acceleration, mm/sec^2
    [ $$ ] $130=1300.000 ;X-axis maximum travel, millimeters
    [ $$ ] $131=1300.000 ;Y-axis maximum travel, millimeters
    [ $$ ] $132=70.000 ;Z-axis maximum travel, millimeters
    [ $$ ] ok
  2. O G
    O G New
    Literally as I hit send I realise my powersupply is set to 220v instead of 120/115
    Can an admin close this thread?
    Glad you are sorted! Leave the thread :) Someday it's gonna help someone in the same pinch as you (;
    Alex Chambers and sharmstr like this.
