Lautr3k
Discussion in '3D printers' started by skarab, Jan 7, 2014.
  1. Axel
    Axel New
  2. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    While on night shift I had some time to work on an all metal extruder idea I have in my nerd, so far, so good :thumbsup:
    #212 Robert Hummel, Aug 15, 2014
    carl, belacesta and skarab like this.
  3. Robert Hummel
    Moderator
    We'll here it is, now just a waiting game on the filament gear :(
    All assembled :D
    skarab and carl like this.
  4. Lluis
    Lluis New
  5. skarab
    skarab Journeyman
    Hi Lluis,
    Yes as already seen in this topic it can be adapted. But we must machine the ends.
    Look forward to seeing your build :)
  6. Sc00ter
    Sc00ter New
    What Infill % is best when printing parts???
  7. skarab
    skarab Journeyman
    The more you are prepared to do, but at least 20-25%.
  8. DiggerJ
    DiggerJ Journeyman
    Looking for someone to print parts for this build. Can't find anyone locally. I would gladly order the filament and ship it to you. Wanting a funky color. (Magenta!!)
  9. dddman
    dddman Journeyman
    Is there any reason you didn't use V-slots everywhere? Do you think that using only the lead screws from openbuilds store would work?
  10. skarab
    skarab Journeyman
    Find a 3D printer near you will be easier than finding the right lead screws. Look at http://www.3dhubs.com.
    The price and I find unfortunate to waste good linear guides for the structure.
    Yes i think but not at high speed, @Robert Hummel should easily answer the question, it make a Aluminium version with it.
  11. Sc00ter
    Sc00ter New
    Are you printing parts in ABS or PLA???
    Scott
  12. DiggerJ
    DiggerJ Journeyman
    Who are you asking?
  13. Sc00ter
    Sc00ter New
    Skarab !
  14. DiggerJ
    DiggerJ Journeyman
    Cool, things get a bit messy in here from time.
  15. Robert Hummel
    Moderator
    Yes I make out well before motors stall at anything above 30mm a sec.
    I'm looking to get 2 amp drivers and bump up to 24v with a rumba board
  16. DiggerJ
    DiggerJ Journeyman
    OK guys, I sent the parts stl's off to be printed, and the printer thinks that some of the parts might need quantities of more than one. The BOM that I saw dealt with the parts other than the plastic pieces, so does anyone have quantities of each printed parts list? He is printing, and wants to do it all together.
  17. dddman
    dddman Journeyman
  18. DiggerJ
    DiggerJ Journeyman
    Yep, I found I after I posted and went to the build manual. Duh. I'm guilty of premature posting.
  19. Sc00ter
    Sc00ter New
    Hi Folks!
    Is there any way someone (Skarab???) could modify the "x carriage - nut side" and "y carriage" to fit the igus 10x25 lead screw nut??? It appears to have a slightly larger bolt pattern. I've included the .stl for the igus nut. (I'm not a CAD guy...yet! ;-)
    For anyone interested, I've also attached the quote for 2 nuts and the 10x25 lead screw which is 1000mm long and will have to be cut and machined.
    Scott
  20. DiggerJ
    DiggerJ Journeyman
    What nema 17's are people from the states using? The motors in the BOM are really stout from the specs (compared to most I looked at and on the OB store). I already have one of the nema 17's from OpenBuilds store. If these will work well, I will just order 3 more. Thanks
  21. Rick 2.0
    Actually, the ones in the parts list are shown as 4.08 and 4.8 kg/cm whereas the ones in the OB parts store are 5.47 kg/cm.
  22. DiggerJ
    DiggerJ Journeyman
    OOPS, I did my conversion wrong. Thanks for the catch.
  23. Sc00ter
    Sc00ter New
    The ones in the "Parts" store are too long at 48mm for the two "Z" axis motors (40mm max) unless you raise the entire bed.
  24. DiggerJ
    DiggerJ Journeyman
    So I am looking for steppers. Having problems selecting the right motors. Can someone who is/has built this printer in the states make some suggestions?
  25. Kees
    Kees New
    Hello Digger,
    I have a good working printer now.
    First i used a Arduino and Ramps1.4 had troubles all the time and a LOT of noise.
    Now I have since 3 month a RamBo board (http://reprap.me/electronic/rambo-v1-2.html)
    Works perfect. you can adjust the motors Amp in Merlin software:
    In "Configuration_Adv.h
    // Motor Current setting (Only functional when motor driver current ref pins are connected to a digital trimpot on supported boards)
    #define DIGIPOT_MOTOR_CURRENT {185,250,60,60,135} // Values 0-255 (RAMBO 135 = ~0.75A, 185 = ~1A)
    I do have a complete configured Marlin file for you to start with.
    I use Wantai Nema 17 motors 42BYGHW811
    Machine is running just fine, last month over 100 hours :)
    Greetings,
    Dutchdreamer
  26. skarab
    skarab Journeyman
    I looked quickly, it takes a lot of change. This nut is huge !!! and the STL is for 8mm, I downloaded from the website of igus and it is the same ....
    Nema17 of openbuilds doing very well, and for the Z axis, no problemo, just add some feet to the printer. 2014-02-02 13.03.17.jpg DSC_0024.JPG
  27. DiggerJ
    DiggerJ Journeyman
    Thanks guys. I will just continue my revenue streaming to Mark at the OB store
  28. Hexag
    Hexag New
    @skarab : I'm quite new to the world of 3D printing and I just have some basic questions about your awesome printer ;) :
    • Why did you choose to use lead screws for all axis ? I often see 3D printers which use lead screws on the Z axis (Lulzbot Taz 4, Prusa i3, etc.) but they often use belts for the others axis.
    • What are your reasons for choosing the design "Y bed XZ head" and not "Z bed XY head", for example ? I'm planning to build a 3D printer and I'm esitating between these two common designs.
    Thank's in advance.
  29. Florian
    Florian New
    Hi everybody,
    hi skarab,
    is there any proven way to build this printer without the lead screws from trinity lab?
    I read all posts yesterday and there are serveral other lead screws mentioned here, but did anybody made a build with them?
    Pictures? STL files?
    Thanks in advance.
  30. Gumpwa Luong
