OpenBuilds CONTROL Software
  1. Peter Van Der Walt
    Right so I grabbed 1.0.183, and connect just fine to my Grbl 1.1 test machine:
    So, going to reinstate it for download. Nothing wrong with 1.0.183!
    You may just have a wiring issue, check your endstops or disable Hard Limits.
    The big clue being that CNCjs doesnt improve it for you: Common denominator being the same machine in both tests
  2. WJC
    WJC New
    @Peter Van Der Walt I could not reproduce the z-probe error with v1.0.183. It worked perfect every time, at least on my machine. Thanks for the update.:thumbsup:
  3. Kevon Ritter
    Kevon Ritter Veteran
    @Peter Van Der Walt
    I've been gone for a while so I apologize for the delayed response. I definitely see your counter points. I do still stand by the "jog distance" part though.
    As for the code portion, I like that challenge!
  4. mrp192
    mrp192 New
    My router has been down for a few weeks. Got it working today.But before it broke Macros for XYZ probing was working without a problem. Now that im up and running they look to be off in X and Y for about 11mm.
    No changes in that area (macros run your code not ours)
    Check that your diameter offsets (in your macro gcodes) are correct (half endmill diameter + plate thickness)
  6. Mandy Ellifritz
    Peter, I use a laptop with a 12" screen with my machine. The control software does not fit on the screen well, specifically the cut preview. Is there any way to make that into a pop out screen so I can move/resize it? I use MatterControl for 3D printing and it has a similar function if you'd like to see an example.
    Not at this time, sorry
    Out of interest sake, whats the native resolution of the machine? (interface is more in Pixels than Inches)
  8. Blake Barr
    Probe Zero still working flawlessly
  9. wernerhillbert
    Open Builds Controller Software and TinyG Board
    Hi
    I'm Use on OX- Machine with TinyG Controller Board.
    If is possible to implenment this Controller Board to the Openbuild Controller Software?
    still i try to test but no service to TinyG.
    Greeeting Werner
  10. sharmstr
    Sorry no. Peter suggested Chilipeppr or CNC.js
    Unfortunately not, we do not supply any TinyG based systems, and the general community for it is insignificantly small.
    Have you considered getting a BlackBox Motion Control System
    Better drivers, easier to use, more widely supported, sinple to interface etc
    Mark Carew and sharmstr like this.
  12. Beëlzeblub
    Well i've switched from ugs to the openbuilds control and i like it very much. Even so i'm no longer using ugs. I realy realy like the OBCO!
    Now if the OBCA soft would have more functionality as to the designing/creating freedom that the easel soft of inventables has, well ***t i would be in heaven! the easel browser soft is just easy to use for creating fast stuf and OBCA is kinda going in that direction sow i'm keeping my fingers crossed!!!
  13. Rob Atha
    Rob Atha New
    Peter, Mark
    Just downloaded the new release of obcs but it won’t install, gets halfway through install on windows pc then crashes.
    Any ideas ?
    Rob
    Something on your PC
    1243 users without the issue (; just mentioning as its always a good check to determine if its just the user, or an issue with the installer for example
    - uninstall old version first
    - Cleanup OpenBuildsCONTROL install directory
    - Screenshot of "crash"? Or if no error, what does it do?
    - old versions are available at OpenBuilds/OpenBuilds-CONTROL
  15. GeneLV
    GeneLV New
    Hi all. New to CNC and just got Workbee put together and connected to my Blackbox and I noticed that the bit will get plunged into the material when I hit stop in the control software. Is there a setting that I can change to stop the plunging or have the z axis move the other way?
    Can you post some video?
    Stop really does "stop" all motion... Something else may be happening? (Z dropping under gravity as $1=255 is not set?)
  17. GeneLV
    GeneLV New
    I'm at work so I'll get a video when I get home. It is not a gravity drop, it is Z actively pushing the bit into the material at least 1/4".
  18. GeneLV
    GeneLV New
    I'm also having a problem with circles. I tried cutting a 15mm circle and the machine was jerky and the circles were elongated so I read on another one of your reply's concerning that type of problem to set $1=255 and sent myself a reminder to check it when I get home along with checking screws, wheels, etc.
  19. Peter Van Der Walt
    Jerky tends to be driver current incorrectly set, or (coupled with your weird Z) loose wiring. For example just 3 of the 4 wires to motor making good contact. Check all your connections and joints
  20. GeneLV
    GeneLV New
    Thanks Peter, I will check all of the connections this afternoon. I did make a large cut yesterday that consisted of a 27" circle, 11" circle and multiple 2.5" circles and the motion was smooth. The jerky motion only comes when cutting smaller holes so far.
  21. Peter Van Der Walt
    Old/Slow PC having trouble sending rapid short moves?
  22. GeneLV
    GeneLV New
    4 year old Asus ROG G750 w/ Core i7, 24GB RAM, GTX 860M and running off an SSD. Should be more than enough to handle it. My main computer has an i7-9700k, 64GB RAM, 2070 graphics card running off an NVME but I'm not going to drag it downstairs to the garage.
  23. Peter Van Der Walt
    yeah fair enough (; not the regular "i dug my 15 year old laptop out because I don't want dust on my new one" we tend to see (;
    GeneLV likes this.
  24. GeneLV
    GeneLV New
    Peter here is a link to the video showing Z push the bit down when stop is pressed in the control software.
    The jerking is better but is still there. Had to run my wife to an appointment so I'll get that video later.
  25. GeneLV
    GeneLV New
    Forgot to mention that $1=255 was already set.
  26. sharmstr
    Is your Z motor current set correctly? Just a guess here, but if you have it set to high, the driver will go into thermal shutdown. With the bit still spinning, perhaps its pulling the Z axis down into the material.
  27. GeneLV
    GeneLV New
    I used the stall method to set the current. It does the same thing when I have it do a run without cutting anything and push stop. It always drops the same amount.
  28. sharmstr
    Sorry. I failed to remember that this happens only when you hit stop. Hmmmm. Peter should be back online soon.
  29. Peter Van Der Walt
    Paste the output of the Serial Log tab around the stop (it echos all commands, lets see if theres a z move there)
  30. David the swarfer
    tick the 'smoothing' in the Fusion toolpath options, this reduces the number of short segments
