Laser protective acrylic
Discussion in 'Laser Cutters' started by nportelli, Mar 28, 2018.
  1. nportelli
    nportelli New
    What do people use? And why is it so expensive? Is it because it is tested or special type? I'm looking for a protective sheet for a 445nm diode laser.
  2. BNMaker
    BNMaker Well-Known
    For a 445nm laser, orange acrylic in 3mm will give you ‘adequate’ protection from the odd stray reflection for diodes <3W, but there’s no substitute for glasses and you should still wear them - you’ve only got one spare eye ;)
    The darker the orange tint, the more the protection.
    You can beef up the protection if you have a 3W<8W laser by putting a layer of reflective acrylic ‘one way’ sheet on the inside. The kind of stick-on sheet you would use for an infinity mirror (which is where I got mine - off-cuts from my infinity clock).
    Gregory Luckett likes this.
  3. Giarc
    I bought a piece from jtech photonics because even with glasses, I did not feel the protection was adequate because reflected light would get under the lenses sometimes. The stuff they sell is tested. The shipping is what was expensive, but it came in two days. I looked at Tap plastic's orange acrylic but no data was available so I went with jtech. I need my eyes to make a living - and because I like them. It was worth the $32 IMHO.
  4. Scotty Orr
    Scotty Orr Journeyman
  5. Giarc
    I am building a box as well. Unfortunately, mine will be much longer since the focal length of my laser is about 180 mm.
  6. JustinTime
    Scotty, is that a cream-cheese/sour-cream tub that is encasing your diode?
  7. Scotty Orr
    No, that's my 3D printed router adapter for my Makita - I just leave it in place when swapping out the router for the laser mount.
  8. Mark Carew
    Scotty Orr likes this.
  9. BNMaker
    BNMaker Well-Known
    Yep, you've only got one spare!
    But... orange is orange. These 'laser safety' companies are charging huge money for what is just normal coloured acrylic. They give all sorts of fancy figures, and 'OD' numbers, but what they really do is to buy a bunch of off-the-shelf acrylic and put it through a spectrum analyser - which you can do at home, except the cost of an analyser is more than a sheet of 'laser' acrylic.., but, I just happen to have a transmissive and reflective spectrum analyser and the absorption capabilities of yellow through red acrylic give varying levels of absorption of 445nm light, from over 50% to over 90%.
    And I live in the middle of nowhere in SE Asia, where you can't easily buy 'laser safe acrylic'... unless you want to pay US$150 for shipping of a 12"x12" square.
    There's nothing special about 'laser safe' acrylic - its just coloured acrylic that naturally absorbs a specific range of frequencies of light. Orange is high up on the visible spectrum - around 640-650nm - which means it doesn't transmit other, lower colours, but passes the range we see as orange.
    If you had a blue sheet of acrylic, that's low on the spectrum - 420-470nm, depending on the colour. That would pass a 445nm laser, but block a red diode laser at 640nm
    It very much matters a) what kind of laser - diode vs CO2 b) the power of your laser c) IR or visible spectrum d) the opacity of your acrylic.
    For IR lasers, even a sheet of clear acrylic will block 95% of IR. But a clear sheet won't do much at all for a visible-light diode... and theres a reason black acrylic is easy to cut - it absorbs all the energy and converts it to heat.
    So, don't worry too much about it - if you have a 500mw - 10W 'blue' laser diode, a sheet of 50% orange acrylic will cut down the transmission of harmful rays to a non-harmful level. So will dark sunglasses, but without knowing the colour of the glasses and the frequency of the laser, you are just being stupid to use sunglasses as your primary defence.
    And you can test it yourself - get a piece of acrylic you want to test, set your laser at 90deg to the beam, place a piece of tissue paper or other easily burned object and fire up. You won't even be able to scorch light tissue with the beam focused on the paper.
    Reflection is the major source of stray coherent light beams in unexpected places. And, unless you're cutting or engraving mirrors 0.o then the reflected beam is going to be significantly lower powered than the beam that struck the object. it will also absorb some of the 'speed' of the beam, shifting it to a lower frequency.
    If you want to DIY your laser shielding, get some complementary coloured acrylic and for additional safety some 'one way' reflective film for the inside and you will be fine - but ALWAYS wear your safety specs, even if you have shielding. One accident is all it takes.
    Tux&Apron and JustinTime like this.
  10. Giarc
    I agree with what you are saying. However, for me the decision was that since Tap Plastics was just a few dollars less for orange acrylic shipped to my house then Jtech was, and Jtech took the time to provide me with data I would go with theirs. I could have got the Tap Plastics piece significantly cheaper if I drove to the store, but I started putting a dollar amount on my weekend time and to me it was not worth the gas burned and the hour to hour and a half round trip.
  11. BNMaker
    BNMaker Well-Known
    J tech haven”t made some special plastic - they’ve just sourced good quality orange acrylic.
    Most of the world isn’t within easy driving distance, and the original question was about what works.
    If it is orange, it’s filtering blue light.
    It’s not rocket science.
  12. LazrManny
    LazrManny New
    Hi Scotty & others: I'm new to this forum (joined today!). I have an XY table from a fluid dispensing system and wanted to turn it into a laser engraver. Here's the specification of the 15W Laser Head Engraving Module that I have purchased.
    15W Laser Head Engraving Module 450nm Blu-ray w/TTL Wood Marking Cutting Tool | eBay
    I also have (orange acrylic) Laser Protective Sheets from Polymer solutions with the following specification:
    Polymer Solutions Inc 1019-145 Near VIS Laser Protective Sheet 7" X 11" X .140"
    Uses: Broad-band, cost-effective protection for multiple laser threats in a single environment. Material: Acrylic. Laser Protective Range: OD greater than 5 from 190 to 375 nm, OD greater than 4 from 376 to 533 nm, OD greater than 5 at 1064 nm, OD greater than 4 from 900 to 1070 nm, OD greater than 5 at 10,600 nm. Transmission: 16.5%
    I'd like to build a shield around the laser head using this protective acrylic sheet. Questions:
    i) Is this the right combination of laser wavelength and shielding?
    ii) Could someone please upload a laser engraver wattage chart so I can better understand what my system will be capable of?
    iii) Is LightBurn software absolutely essential to this enterprise? (I already have other means of generating g-code.)
    Best regards,
    Manny
  13. Anthony Bolgar
    Anthony Bolgar Journeyman
    In regards to LightBurn, it is not essential, but it is a lot easier to work with. It is an all in one design and control software package designed specifically for lasers. The Gcode version is only $40, but there is a free trial available at LightBurn Software Give it a try, and if you like using it you can always purchase it. If not, nothing lost.
  14. Giarc
    I have been mulling this one over for my K40. Right now I use k40 whisperer with the stock board.
  15. Anthony Bolgar
    You would need to upgrade the stock K40 controller to use LightBurn. But it does make it much more versatile. Cohesion3D.com and Awesome.tech both sell drop in plug and play upgrade controllers.
  16. BNMaker
    BNMaker Well-Known
    The most powerful laser diode made by man is ~7W - anyone claiming a single diode is more is ‘marketing’ to an easily suckered audience.
    As I posted before, any orange/red translucent acrylic will work fine. You can test by firing your laser through the acrylic to rice/tissue paper. You will be unlikely to even scorch it, let alone burn.
    One issue is simply the brightness of the beam - it’s tiring on the eyes and even with protection, you should never look at the beam.
    I’ve built a number of diode lasers and not used a shield with any of them, but you won’t get in my workshop without proper safety glasses.
    Rick 2.0 likes this.
  17. Irene Bronkhorst
    Hi we are building our own laser machine and I saw you say any acrylic wil work for laser mashine co2 80watt is the a spesific thickness i need to keep in mind
    The base is done the elektronics so It's just to close is.
    Thanks irene
  18. JustTheFacts
    I really hoped your suggestions worked and the reflective film may be a big plus!
    Green laser protective, CE Certified, acrylic was tested. It blocked 100% on my IR meter (950 nm) with 30% VIS transparency (550nm). I then tested 16 colored standard acrylic sheets sold on Amazon (Red, blue, green, light green, yellow, etc.). The typical IR blocking was 4-5% with 95% of the IR energy of straight line radiation passing through.
    There was one darker green sheet that blocked 20% of IR (still dangerous for YAG). Unfortunately, this doesn't come close to the certified and higher priced material. There are many colors made by different manufacturers, so I may try others to continue to test this theory. At this point, it would be potentially highly unsafe not to use certified, and tested material unless you are able to test it yourself.
  19. Jim Robert
    Newbie question here. Do you have to re-tram the router when removing it from the mount or does that stay intact.
  20. Alex Chambers
    Even with an aluminium router mount I find the tram needs tweaking if I remove the router and replace it.
  21. Jim Robert
    Thank you. I was afraid of that.
  22. Peter Van Der Walt
    Router within the mount sets back in position perfectly. Tramming is more a case of building the entire machine squarely: Tramming: A generic guideline
  23. Scotty Orr
    My adapter is 3D printed. Back then, I did not re-tram after swapping out. I've since learned that I probably should have. I'll be swapping out my adapter for an aluminum one soon...
