Control not responding
Discussion in 'Controller Boards' started by KEITHABEAR, Sep 24, 2019.
  1. KEITHABEAR
    KEITHABEAR Well-Known
    Can't seem to understand why control not responding or takes a long to respond
    1) Specifications of your PC:
    1.1 RAM
    1.2 CPU
    1.3 GPU
    2) More details, when does it hang? When loading certain files, etc, and provide files that does
    3) Version in use?
  3. KEITHABEAR
    Windows 8.1 64-bit
    AMD A6-5200 APU with Radeon HD Graphics
    8GB
    Loads fine starts fine after 10 or 15 min says not responding
    9.518
    Specs look OK, but the behavior is not.
    Try a different PC (or upgrade/reformat windows to test on a clean slate) - its one of those cases of 'only you have this issue' so it must be something on that PC/Windows install that doesnt play nice, or some other software on the PC is causing it
    #4 Peter Van Der Walt, Sep 25, 2019
