C-Beam Mods
Discussion in 'CNC Mills/Routers' started by tmadrms, Oct 24, 2019.
  1. tmadrms
    tmadrms New
  2. GeoffH
    GeoffH Journeyman
    Nice build, I have a C-beam X-Large and have added SBR rails to the Y Axis, the MGN12 looks like a nice solution to get rid of the flexing on the X & Z; I am encouraged at your success so I'll do it :)
    Geoff
    PS Did you fit 2 guide blocks to each rail?
    At this time, only some functions are available as keyboard shortcuts: For example your request for Z-Probe - as it launches a gui and needs inputs etc is not really ideal to tie to a single shortcut button. If you need any specifics do request them though: https://github.com/OpenBuilds/OpenBuilds-CONTROL/issues :) it might be considered if it makes sense and is a popular need
  4. tmadrms
    tmadrms New
    I did two on each trail for the X and Y but only one for the Z. You certainly could do two but the single’s seems to handle the load without issue so far. Good luck!!
    GeoffH likes this.
  5. tmadrms
    tmadrms New
    Totally understand why they aren’t single keys. Would be cool to have a combo key shortcut so they cannot be done accidentally. In my case the z-probe is all defaults so makes this feasible for me, but I see your point that others may find no value in it. I tinkered around with having the StreamDeck do some screen clicks but it was far too unreliable. I’ll give it some more thought and submit requests on GitHub for consideration. Thanks to you and the team for such a great controller!!
    CTRL, ALT, SHIFT are supported: When capturing the new key, just hold down the modifiers you want :)
  7. tmadrms
    tmadrms New
    Sorry, meant for things like z-probe, but that is a cool feature that I didn’t know about!
