Duet Controller/Fusion 360 post fix
Discussion in 'CAM' started by Alex Chambers, Jul 21, 2019.
  1. Alex Chambers
    Hi @ian McFadden, I would be grateful if you could cast an eye over the attached Fusion post processor and tell me if I have correctly incorporated your wcs changes (with some modification for the new beta 3 firmware and Duet Web Control-2 from Ooznest - I have allowed up to 6 workplace offsets as we are now using G53 as absolute[machine] co-ordinates).
    Alex.:):)
    PS that worked fine with one wcs (once I had learned how to use multiple wcs in Fusion).
    Also worked fine with two work offsets - because I'm using a modified version of my toolchange post processor it puts macro calls between each toolpath so it should be simple to write those to make sure there is a clear path around any fixtures at each wcs change.
    #91 Alex Chambers, Oct 19, 2019
    Ryan Lock likes this.
  2. Ryan Lock
    Ryan Lock Veteran
    I have adjusted the theming really slightly to make see if that helps. The tone of the colours has gone down one on the scale.
    GeoffH and Alex Chambers like this.
  3. Ryan Lock
    Ryan Lock Veteran
    Awesome! I will have to try this out myself.
  4. Alex Chambers
    Thanks @Ryan Lock, I'll give that a try.
    Multiple work offsets is looking really good now Geoff and I have stopped making stupid mistakes.
  5. Alex Chambers
    Now that we have G53 I am going to re-write my toolchange macros - they just move to defined position and waited for user input.
  6. GeoffH
    GeoffH Journeyman
    Good stuff Ryan. By the way, I was discussing with Alex a few days ago about the general problem of operating the browser with a mouse or keypad whilst watching the machine, particularly when Jogging, we said that we had both had accidentally hit the wrong button when maybe the cursor drifts a bit, and you are watching the machine more than the browser screen.
    This might, of course be related to our great age, mine being the greatest unfortunately:(, but Alex suggested that keyboard shortcuts would be good particularly for jogging; I'd agree with that, and then maybe a programmable keypad could be added?
    On a few occasions I've drifted onto the buttons surrounding the jog buttons whilst jogging particularly the big "Goto Work Zero", and others which can cause severe loss of composure :eek:.
    Anyway just a few thoughts for the future, but really liking your WorkBee DWC :thumbsup::thumbsup:- Geoff
  7. Alex Chambers
    Full credit here must go to @GeoffH who showed me how to add macro calls to the post processor, and @ian McFadden who added multiple work offsets to the Fusion/Duet post processor. I wouldn't know where to start without their help.
  8. GeoffH
    GeoffH Journeyman
    Ryan, this Wireless UGS Pendant is the sort of thing I had in mind, a USB wired Jelly Comb is less than a tenner, but isn't programmable - Geoff
  9. Ryan Lock
    Ryan Lock Veteran
    This is probably the most requested feature we have on our list. So after the initial release it will be the first thing i am adding.
    For a physical pendant that would be something i will have to work closely with Duet3D to make work, we have spoke about, and at the stage where we have decided on the most popular pendants that can be bought, now we just need to make them compatible. In the meantime i think i might try and add a virtual pendant in the web control.
    For what you linked about, once i introduce keyboard mapping, i think using that would be possible.
    Ryan
    GeoffH likes this.
  10. Alex Chambers
    Hi @Ryan Lock, since the "go to work zero" button is so big how about shrinking it to make space for buttons the user can link to system files. I guess the buttons might have to be linked to "pre-named" files that the user could then write themselves?
    GeoffH likes this.
  11. GeoffH
    GeoffH Journeyman
    Yes Alex, I guess that you would need some text on these buttons, so that could come from "settings", together with the corresponding macro name.
    In any event, I would welcome reducing the size of the "Goto Work Zero" button, or maybe moving it onto the drop-down above the jog controls, which Ryan said will contain the Probing options.
    By the way, in my workzero.g I've made the final Z move down (normally to Z0) optional with M291 etc, just in case I have written a program where Z0 is at the bottom of the material, something I have done only a few times.
    By default in Vcarve, I have a home position with a 10mm clearance above the material top (which is Z0), so I move to Z10 in any case in workzero.g
    - Geoff (Journeyman today, not sure whether I have been promoted or demoted?;):confused:)
  12. Alex Chambers
    We have all been demoted @GeoffH. Not sure why, but there appear to be no masters around anymore. Have to say (since it happened over a week ago) you appear to share my disinterest in the whole "status" thing.
  13. GeoffH
    GeoffH Journeyman
    Oh yes, I see you're a Veteran now, presumably a bit of dodgy code, that the kids might call AI nowadays, either way it doesn't appear to work too well - "am I bovvered"? Geoff (Grumpy Old Man)
  14. Ryan Lock
    Ryan Lock Veteran
    Thanks for the suggestion, i need to get the current release finished, so i will leave it as is at the moment, but i can definitely re-work that aspect. Yes the button's would have to be linked to pre-named files. But there is always the macro tab for other buttons.
  15. Alex Chambers
    Understood. Very pleased with the progress so far.
    Alex. :thumbsup:
  16. GeoffH
    GeoffH Journeyman
    Hi @Ryan Lock, I have been using ncviewer.com recently to do Toolpath simulation at the Machine; it sits next to the DWC Tab in my Browser, looks a polished professional application and I find that it does a very nice job for me.
    It's also linked with Fusion 360, although I haven't tried that and I'm not sure why you would need it in the CAM system, but I think it's very useful by the Machine, often to double check that I'm about to run the correct program. I don't intend to run my CAM system by the Machine.
    Maybe there is a possibility in the future to integrate NC Viewer with the Workbee DWC which could make it a bit slicker, for example file loading and WCS??
    That said, it's only a suggestion for future consideration and I'm hearing what you say about a 1.07 release before anything else
    - Geoff
  17. Alex Chambers
    Hi @GeoffH, is that an online only viewer?
  18. GeoffH
    GeoffH Journeyman
    Alex, in the notes it says
    "- Offline Mode
    No installation! NC Viewer is automatically
    cached by your browser and will load offline!"
    I just tested it and it works offline - Geoff
  19. Alex Chambers
    I'll have to experiment to see if I can get that to work on my setup - don't have Internet on the machine I use with my workbee.
    Thanks, Alex.
  20. GeoffH
    GeoffH Journeyman
    You will have to get online at some stage, so that your Browser can cache the content. Then you can work offline with it. Geoff
  21. GeoffH
    GeoffH Journeyman
    I've tried a lot of these programs, this is by far the best for me. It seems that the coder works as a web developer for Autodesk which explains why it's linked to Fusion I guess. Geoff
  22. Ryan Lock
    Ryan Lock Veteran
    I agree a g-code viewer would be awesome! A g-code viewer is something soon come to DWC, i believe the original web control programmer is adding it in, if not i will see if i can add it myself :)
    Alex Chambers and GeoffH like this.
  23. Ryan Lock
    Ryan Lock Veteran
    Just to let you know the first official release of WorkBee Control in WorkBee Firmware 1.0.7 can be found here: WorkBee Firmware Releases
    Mark Carew, GeoffH and Alex Chambers like this.
  24. Alex Chambers
    Congratulations - well done!
    Alex. :thumbsup::thumbsup::thumbsup::D
  25. Alex Chambers
    Now you just need to tidy up your Web page on the learning portal so that the links work :rolleyes::rolleyes:
  26. GeoffH
    GeoffH Journeyman
    Nice one Ryan, looking great, do you plan to leave the Height Mapping / Compensation stuff in the Workbee DWC? Geoff
  27. Ryan Lock
    Ryan Lock Veteran
    Thanks, they should all work, Friday evening i had to quickly take them down for a few minutes as a small bug someone on the Facebook group made me aware of had to be fixed.
    Thanks, yes i do plan to keep it, as i know some people use it for PCB Milling. I also plan to make a guide on using it, now we have our own touch probe.
  28. jlipavsky79
    you don't by any chance have a compete edited copy of what your using that i can try out, i built the avid cnc 4x8 machine and went with the Duet3 control board and i have the machine working and all the macros written and everything works great but i cant seem to find a post processor that work.....
    Thank You in advance!!!!!
  29. Alex Chambers
  30. Pablo Guerra Prieto
    Some possibility that the workbee firmware will be updated, to include the latest version of DWC 3.2
    This version includes support for plugins, and there are already plugins to control with a gamepad the jog, Also, to display paths and others.
