How to finish a 3D project
Discussion in 'General Talk' started by KEITHABEAR, Nov 9, 2019.
  1. KEITHABEAR
    KEITHABEAR Well-Known
    I mostly use southern yellow pine for 3D carving and would like suggestions on what kind of staining and the process, any input would be helpful
  2. Giarc
    I have used pine for furniture before and you need to put on a pre stain treatment before staining because pine takes stain unevenly without it and ends up blotchy (if that is a word).
  3. Giarc
    If I recall correctly, I used a pre-stain product from minwax. Here is a quick video showing it although I do not know why he is demonstrating on oak. Oak doesn't need it. The video also confirmed "blotchy" is a word.:thumbsup:
    #3 Giarc, Nov 9, 2019
  4. Alex Chambers
    Use a spirit based stain on pine if you want to change the colour (because of the resin in the pine water based stains do not take evenly). Be prepared to experiment with diluting it to get the colour you want.
    Polyurethane varnishes tend to yellow with age (but pine tends to darken with age as well).
    If you want a gloss finish and can get it where you are Rustin's Plastic Coating gives the most hard wearing finish.
    Or you could use a wax finish (with or without a stain added) - apply with very fine wire wool and buff off when dry with a clean cloth. Wax can get grubby over time.
