OpenBuilds Control surfacing wizard bug?
Discussion in 'CNC Mills/Routers' started by BruceD, Nov 10, 2019.
  1. BruceD
    BruceD New
    I have tried twice to surface my spoilboard and each time it runs the whole surface then cleans up the left side, goes to the right side and starts to clean up that edge. At approx 5 1/2 inches it shuts down the router, runs down the right side and returns home? Anybody else seen this issue?
    When you generate the Gcode, it puts it on the "gcode editor" tab
    There is a save button on the bottom. Download the gcode, post it here, and I'll check what went wrong (make sure the gcode you upload did indeed fail)
    Also paste the serial log of around the time it went wrong
  3. BruceD
    BruceD New
    Thanks I will do that, where do I find the serial log?
    #3 BruceD, Nov 11, 2019
    The log prints to the Serial Console:
  5. BruceD
    BruceD New
    Hello Peter, I have attached the requested files, one this run it shut the router down almost as soon as it started the right side. Thanks for the help.
    #5 BruceD, Nov 13, 2019
  6. BruceD
    BruceD New
    Just moved to a new place, havent unpacked the CNC yet, but the M5 (spindle off) is right at the end of both gcode files... (So gcode looks correct to me)
    So hows the router wired, connected and controlled?
  8. BruceD
    BruceD New
    The Router is getting power from a high power iot relay receptacle that I got off Amazon. Signal wire comes from gnd/pwm connector on blockbox. Cable is shielded and grounded on blackbox end. The IOT runs off opposite 120 leg from blackbox.
    Not sure why then, as the M5 is at the end after all the moves, so not an issue with the Wizards, it puts the right spindle off command in the right spot
