center zy help needed
Discussion in 'CNC Mills/Routers' started by jamesd2000, Dec 5, 2019.
  1. jamesd2000
    Just started to engrave, however i am having a problem with candle/carbide.
    I have a 3018 pro
    I layout some text in carbide
    set zero in center
    genarate G code
    Save
    Measure my wood for engraving
    mark center pont
    set all zeros in candle
    load g-code start to engrave
    The engraving then is about 5mm to left of center and 5mm down from center.
    hope you understand what i mean...
    Thanks in advance for help
    Things to check:
    1) Is your axes calibrated (else it may be "smaller" than expected, and thus seem to be offset)
    2) Post the GCODE so we can check it
  3. jamesd2000
    hi peter
    thank you for the quick reply...
    would that be the code i genarate in carbide or the code in the control box in candle?
    Let's say both :)
  5. jamesd2000
    from carbide
    (TOOL/MILL,0.1,0.05,0.000,0)
    (FILENAME: )
    G21
    G90
    G0X0.000Y0.000Z12.700
    (TOOL/MILL,12.7000,0,1.0000,30.0)
    M6 T302
    M3 S6111
    G0X-9.418Y-5.874
    G0Z12.700
    G1Z-0.254F19.4
    G1X-9.531Y-5.879F155.2
    X-9.637Y-5.894
    X-9.738Y-5.918
    X-9.832Y-5.953
    X-9.921Y-5.997
    X-10.003Y-6.051
    X-10.079Y-6.115
    X-10.149Y-6.188
    X-10.213Y-6.272
    X-10.271Y-6.365
    Y-5.943
    X-10.645
    Y-9.494
    X-10.247
    Y-8.045
    X-10.185Y-8.146
    X-10.118Y-8.237
    X-10.045Y-8.318
    X-9.968Y-8.388
    X-9.886Y-8.447
    X-9.798Y-8.495
    X-9.706Y-8.532
    X-9.608Y-8.559
    X-9.506Y-8.575
    X-9.398Y-8.581
    X-9.290Y-8.577
    X-9.187Y-8.564
    X-9.089Y-8.543
    X-8.996Y-8.515
    X-8.908Y-8.478
    X-8.825Y-8.433
    X-8.746Y-8.380
    X-8.672Y-8.319
    X-8.603Y-8.250
    X-8.538Y-8.173
    X-8.484Y-8.097
    X-8.436Y-8.016
    X-8.393Y-7.932
    X-8.355Y-7.844
    X-8.323Y-7.752
    X-8.297Y-7.656
    X-8.276Y-7.557
    X-8.262Y-7.453
    X-8.253Y-7.346
    X-8.250Y-7.235
    X-8.253Y-7.121
    X-8.262Y-7.011
    X-8.276Y-6.905
    X-8.297Y-6.804
    X-8.324Y-6.708
    X-8.356Y-6.615
    X-8.394Y-6.527
    X-8.438Y-6.443
    X-8.488Y-6.363
    X-8.543Y-6.286
    X-8.610Y-6.207
    X-8.681Y-6.136
    X-8.757Y-6.074
    X-8.837Y-6.021
    X-8.923Y-5.976
    X-9.012Y-5.939
    X-9.107Y-5.910
    X-9.206Y-5.890
    X-9.310Y-5.878
    X-9.418Y-5.874
    G1Z-0.508F19.4
    X-9.637Y-5.894
    X-9.738Y-5.918
    X-9.832Y-5.953
    X-9.921Y-5.997
    X-10.003Y-6.051
    X-10.079Y-6.115
    X-10.149Y-6.188
    X-10.213Y-6.272
    X-10.271Y-6.365
    Y-5.943
    X-10.645
    Y-9.494
    X-10.247
    Y-8.045
    X-10.185Y-8.146
    X-10.118Y-8.237
    X-10.045Y-8.318
    X-9.968Y-8.388
    X-9.886Y-8.447
    X-9.798Y-8.495
    X-9.706Y-8.532
    X-9.608Y-8.559
    X-9.506Y-8.575
    X-9.398Y-8.581
    X-9.290Y-8.577
    X-9.187Y-8.564
    X-9.089Y-8.543
    X-8.996Y-8.515
    X-8.908Y-8.478
    X-8.825Y-8.433
    X-8.746Y-8.380
    X-8.672Y-8.319
    X-8.603Y-8.250
    X-8.538Y-8.173
    X-8.484Y-8.097
    X-8.436Y-8.016
    X-8.393Y-7.932
    X-8.355Y-7.844
    X-8.323Y-7.752
    X-8.297Y-7.656
    X-8.276Y-7.557
    X-8.262Y-7.453
    X-8.253Y-7.346
    X-8.250Y-7.235
    X-8.253Y-7.121
    X-8.262Y-7.011
    X-8.276Y-6.905
    X-8.297Y-6.804
    X-8.324Y-6.708
    X-8.356Y-6.615
    X-8.394Y-6.527
    X-8.438Y-6.443
    X-8.488Y-6.363
    X-8.543Y-6.286
    X-8.610Y-6.207
    X-8.681Y-6.136
    X-8.757Y-6.074
    X-8.837Y-6.021
    X-8.923Y-5.976
    X-9.012Y-5.939
    X-9.107Y-5.910
    X-9.206Y-5.890
    X-9.310Y-5.878
    X-9.418Y-5.874
    G1Z-0.700F19.4
    X-9.637Y-5.894
    X-9.738Y-5.918
    X-9.832Y-5.953
    X-9.921Y-5.997
    X-10.003Y-6.051
    X-10.079Y-6.115
    X-10.149Y-6.188
    X-10.213Y-6.272
    X-10.271Y-6.365
    Y-5.943
    X-10.645
    Y-9.494
    X-10.247
    Y-8.045
    X-10.185Y-8.146
    X-10.118Y-8.237
    X-10.045Y-8.318
    X-9.968Y-8.388
    X-9.886Y-8.447
    X-9.798Y-8.495
    X-9.706Y-8.532
    X-9.608Y-8.559
    X-9.506Y-8.575
    X-9.398Y-8.581
    X-9.290Y-8.577
    X-9.187Y-8.564
    X-9.089Y-8.543
    X-8.996Y-8.515
    X-8.908Y-8.478
    X-8.825Y-8.433
    X-8.746Y-8.380
    X-8.672Y-8.319
    X-8.603Y-8.250
    X-8.538Y-8.173
    X-8.484Y-8.097
    X-8.436Y-8.016
    X-8.393Y-7.932
    X-8.355Y-7.844
    X-8.323Y-7.752
    X-8.297Y-7.656
    X-8.276Y-7.557
    X-8.262Y-7.453
    X-8.253Y-7.346
    X-8.250Y-7.235
    X-8.253Y-7.121
    X-8.262Y-7.011
    X-8.276Y-6.905
    X-8.297Y-6.804
    X-8.324Y-6.708
    X-8.356Y-6.615
    X-8.394Y-6.527
    X-8.438Y-6.443
    X-8.488Y-6.363
    X-8.543Y-6.286
    X-8.610Y-6.207
    X-8.681Y-6.136
    X-8.757Y-6.074
    X-8.837Y-6.021
    X-8.923Y-5.976
    X-9.012Y-5.939
    X-9.107Y-5.910
    X-9.206Y-5.890
    X-9.310Y-5.878
    X-9.418Y-5.874
    G0Z12.700
    G0Z12.700
    G0X-9.467Y-6.201
    G0
    G1Z-0.254F19.4
    G1X-9.387Y-6.204F155.2
    X-9.311Y-6.213
    X-9.239Y-6.229
    X-9.171Y-6.250
    X-9.106Y-6.277
    X-9.046Y-6.311
    X-8.989Y-6.351
    X-8.936Y-6.397
    X-8.887Y-6.450
    X-8.841Y-6.509
    X-8.807Y-6.565
    X-8.777Y-6.624
    X-8.749Y-6.687
    X-8.725Y-6.754
    X-8.705Y-6.825
    X-8.688Y-6.900
    X-8.675Y-6.978
    X-8.665Y-7.060
    X-8.659Y-7.146
    X-8.657Y-7.235
    X-8.659Y-7.325
    X-8.665Y-7.412
    X-8.675Y-7.495
    X-8.688Y-7.573
    X-8.706Y-7.648
    X-8.727Y-7.719
    X-8.753Y-7.787
    X-8.782Y-7.850
    X-8.815Y-7.909
    X-8.851Y-7.965
    X-8.896Y-8.019
    X-8.946Y-8.067
    X-8.999Y-8.111
    X-9.056Y-8.148
    X-9.116Y-8.180
    X-9.181Y-8.206
    X-9.250Y-8.227
    X-9.323Y-8.242
    X-9.401Y-8.250
    X-9.482Y-8.253
    X-9.552Y-8.251
    X-9.619Y-8.242
    X-9.682Y-8.228
    X-9.743Y-8.209
    X-9.800Y-8.184
    X-9.854Y-8.153
    X-9.906Y-8.118
    X-9.954Y-8.077
    X-10.000Y-8.031
    X-10.043Y-7.979
    X-10.086Y-7.923
    X-10.123Y-7.863
    X-10.156Y-7.799
    X-10.185Y-7.733
    X-10.208Y-7.662
    X-10.228Y-7.589
    X-10.243Y-7.512
    X-10.253Y-7.431
    X-10.260Y-7.347
    X-10.262Y-7.259
    Y-7.209
    X-10.260Y-7.124
    X-10.254Y-7.043
    X-10.244Y-6.964
    X-10.231Y-6.888
    X-10.213Y-6.816
    X-10.192Y-6.747
    X-10.167Y-6.681
    X-10.138Y-6.619
    X-10.105Y-6.560
    X-10.068Y-6.505
    X-10.024Y-6.447
    X-9.977Y-6.395
    X-9.926Y-6.349
    X-9.871Y-6.310
    X-9.812Y-6.277
    X-9.750Y-6.249
    X-9.685Y-6.228
    X-9.616Y-6.213
    X-9.543Y-6.204
    X-9.467Y-6.201
    G1Z-0.508F19.4
    X-9.311Y-6.213
    X-9.239Y-6.229
    X-9.171Y-6.250
    X-9.106Y-6.277
    X-9.046Y-6.311
    X-8.989Y-6.351
    X-8.936Y-6.397
    X-8.887Y-6.450
    X-8.841Y-6.509
    X-8.807Y-6.565
    X-8.777Y-6.624
    X-8.749Y-6.687
    X-8.725Y-6.754
    X-8.705Y-6.825
    X-8.688Y-6.900
    X-8.675Y-6.978
    X-8.665Y-7.060
    X-8.659Y-7.146
    X-8.657Y-7.235
    X-8.659Y-7.325
    X-8.665Y-7.412
    X-8.675Y-7.495
    X-8.688Y-7.573
    X-8.706Y-7.648
    X-8.727Y-7.719
    X-8.753Y-7.787
    X-8.782Y-7.850
    X-8.815Y-7.909
    X-8.851Y-7.965
    X-8.896Y-8.019
    X-8.946Y-8.067
    X-8.999Y-8.111
    X-9.056Y-8.148
    X-9.116Y-8.180
    X-9.181Y-8.206
    X-9.250Y-8.227
    X-9.323Y-8.242
    X-9.401Y-8.250
    X-9.482Y-8.253
    X-9.552Y-8.251
    X-9.619Y-8.242
    X-9.682Y-8.228
    X-9.743Y-8.209
    X-9.800Y-8.184
    X-9.854Y-8.153
    X-9.906Y-8.118
    X-9.954Y-8.077
    X-10.000Y-8.031
    X-10.043Y-7.979
    X-10.086Y-7.923
    X-10.123Y-7.863
    X-10.156Y-7.799
    X-10.185Y-7.733
    X-10.208Y-7.662
    X-10.228Y-7.589
    X-10.243Y-7.512
    X-10.253Y-7.431
    X-10.260Y-7.347
    X-10.262Y-7.259
    Y-7.209
    X-10.260Y-7.124
    X-10.254Y-7.043
    X-10.244Y-6.964
    X-10.231Y-6.888
    X-10.213Y-6.816
    X-10.192Y-6.747
    X-10.167Y-6.681
    X-10.138Y-6.619
    X-10.105Y-6.560
    X-10.068Y-6.505
    X-10.024Y-6.447
    X-9.977Y-6.395
    X-9.926Y-6.349
    X-9.871Y-6.310
    X-9.812Y-6.277
    X-9.750Y-6.249
    X-9.685Y-6.228
    X-9.616Y-6.213
    X-9.543Y-6.204
    X-9.467Y-6.201
    G1Z-0.700F19.4
    X-9.311Y-6.213
    X-9.239Y-6.229
    X-9.171Y-6.250
    X-9.106Y-6.277
    X-9.046Y-6.311
    X-8.989Y-6.351
    X-8.936Y-6.397
    X-8.887Y-6.450
    X-8.841Y-6.509
    X-8.807Y-6.565
    X-8.777Y-6.624
    X-8.749Y-6.687
    X-8.725Y-6.754
    X-8.705Y-6.825
    X-8.688Y-6.900
    X-8.675Y-6.978
    X-8.665Y-7.060
    X-8.659Y-7.146
    X-8.657Y-7.235
    X-8.659Y-7.325
    X-8.665Y-7.412
    X-8.675Y-7.495
    X-8.688Y-7.573
    X-8.706Y-7.648
    X-8.727Y-7.719
    X-8.753Y-7.787
    X-8.782Y-7.850
    X-8.815Y-7.909
    X-8.851Y-7.965
    X-8.896Y-8.019
    X-8.946Y-8.067
    X-8.999Y-8.111
    X-9.056Y-8.148
    X-9.116Y-8.180
    X-9.181Y-8.206
    X-9.250Y-8.227
    X-9.323Y-8.242
    X-9.401Y-8.250
    X-9.482Y-8.253
    X-9.552Y-8.251
    X-9.619Y-8.242
    X-9.682Y-8.228
    X-9.743Y-8.209
    X-9.800Y-8.184
    X-9.854Y-8.153
    X-9.906Y-8.118
    X-9.954Y-8.077
    X-10.000Y-8.031
    X-10.043Y-7.979
    X-10.086Y-7.923
    X-10.123Y-7.863
    X-10.156Y-7.799
    X-10.185Y-7.733
    X-10.208Y-7.662
    X-10.228Y-7.589
    X-10.243Y-7.512
    X-10.253Y-7.431
    X-10.260Y-7.347
    X-10.262Y-7.259
    Y-7.209
    X-10.260Y-7.124
    X-10.254Y-7.043
    X-10.244Y-6.964
    X-10.231Y-6.888
    X-10.213Y-6.816
    X-10.192Y-6.747
    X-10.167Y-6.681
    X-10.138Y-6.619
    X-10.105Y-6.560
    X-10.068Y-6.505
    X-10.024Y-6.447
    X-9.977Y-6.395
    X-9.926Y-6.349
    X-9.871Y-6.310
    X-9.812Y-6.277
    X-9.750Y-6.249
    X-9.685Y-6.228
    X-9.616Y-6.213
    X-9.543Y-6.204
    X-9.467Y-6.201
    G0Z12.700
    G0Z12.700
    G0X-7.566Y-5.943
    G0
    G1Z-0.254F19.4
    G1Y-8.510F155.2
    X-7.168
    Y-5.943
    X-7.566
    G1Z-0.508F19.4
    G1Y-8.510F155.2
    X-7.168
    Y-5.943
    X-7.566
    G1Z-0.700F19.4
    G1Y-8.510F155.2
    X-7.168
    Y-5.943
    X-7.566
    G0Z12.700
    G0Z12.700
    G0X-7.367Y-4.974
    G0
    G1Z-0.254F19.4
    G1X-7.392Y-4.975F155.2
    X-7.416Y-4.977
    X-7.439Y-4.981
    X-7.462Y-4.987
    X-7.483Y-4.994
    X-7.504Y-5.004
    X-7.524Y-5.015
    X-7.543Y-5.027
    X-7.562Y-5.042
    X-7.580Y-5.059
    X-7.597Y-5.075
    X-7.612Y-5.091
    X-7.625Y-5.109
    X-7.636Y-5.128
    X-7.645Y-5.148
    X-7.653Y-5.170
    X-7.658Y-5.192
    X-7.662Y-5.216
    X-7.664Y-5.241
    X-7.665Y-5.268
    X-7.664Y-5.293
    X-7.662Y-5.317
    X-7.658Y-5.340
    X-7.653Y-5.362
    X-7.645Y-5.384
    X-7.636Y-5.405
    X-7.625Y-5.425
    X-7.612Y-5.444
    X-7.597Y-5.463
    X-7.580Y-5.481
    X-7.562Y-5.497
    X-7.543Y-5.511
    X-7.524Y-5.523
    X-7.504Y-5.535
    X-7.483Y-5.544
    X-7.462Y-5.552
    X-7.439Y-5.558
    X-7.416Y-5.562
    X-7.392Y-5.565
    X-7.367Y-5.566
    X-7.342Y-5.565
    X-7.318Y-5.562
    X-7.295Y-5.558
    X-7.273Y-5.552
    X-7.251Y-5.544
    X-7.230Y-5.535
    X-7.210Y-5.523
    X-7.190Y-5.511
    X-7.172Y-5.497
    X-7.153Y-5.481
    X-7.136Y-5.463
    X-7.121Y-5.444
    X-7.108Y-5.425
    X-7.096Y-5.405
    X-7.086Y-5.384
    X-7.078Y-5.362
    X-7.072Y-5.340
    X-7.067Y-5.317
    X-7.065Y-5.293
    X-7.064Y-5.268
    X-7.065Y-5.241
    X-7.067Y-5.216
    X-7.072Y-5.192
    X-7.078Y-5.170
    X-7.086Y-5.148
    X-7.096Y-5.128
    X-7.108Y-5.109
    X-7.121Y-5.091
    X-7.136Y-5.075
    X-7.153Y-5.059
    X-7.172Y-5.042
    X-7.190Y-5.027
    X-7.210Y-5.015
    X-7.230Y-5.004
    X-7.251Y-4.994
    X-7.273Y-4.987
    X-7.295Y-4.981
    X-7.318Y-4.977
    X-7.342Y-4.975
    X-7.367Y-4.974
    G1Z-0.508F19.4
    X-7.416Y-4.977
    X-7.439Y-4.981
    X-7.462Y-4.987
    X-7.483Y-4.994
    X-7.504Y-5.004
    X-7.524Y-5.015
    X-7.543Y-5.027
    X-7.562Y-5.042
    X-7.580Y-5.059
    X-7.597Y-5.075
    X-7.612Y-5.091
    X-7.625Y-5.109
    X-7.636Y-5.128
    X-7.645Y-5.148
    X-7.653Y-5.170
    X-7.658Y-5.192
    X-7.662Y-5.216
    X-7.664Y-5.241
    X-7.665Y-5.268
    X-7.664Y-5.293
    X-7.662Y-5.317
    X-7.658Y-5.340
    X-7.653Y-5.362
    X-7.645Y-5.384
    X-7.636Y-5.405
    X-7.625Y-5.425
    X-7.612Y-5.444
    X-7.597Y-5.463
    X-7.580Y-5.481
    X-7.562Y-5.497
    X-7.543Y-5.511
    X-7.524Y-5.523
    X-7.504Y-5.535
    X-7.483Y-5.544
    X-7.462Y-5.552
    X-7.439Y-5.558
    X-7.416Y-5.562
    X-7.392Y-5.565
    X-7.367Y-5.566
    X-7.342Y-5.565
    X-7.318Y-5.562
    X-7.295Y-5.558
    X-7.273Y-5.552
    X-7.251Y-5.544
    X-7.230Y-5.535
    X-7.210Y-5.523
    X-7.190Y-5.511
    X-7.172Y-5.497
    X-7.153Y-5.481
    X-7.136Y-5.463
    X-7.121Y-5.444
    X-7.108Y-5.425
    X-7.096Y-5.405
    X-7.086Y-5.384
    X-7.078Y-5.362
    X-7.072Y-5.340
    X-7.067Y-5.317
    X-7.065Y-5.293
    X-7.064Y-5.268
    X-7.065Y-5.241
    X-7.067Y-5.216
    X-7.072Y-5.192
    X-7.078Y-5.170
    X-7.086Y-5.148
    X-7.096Y-5.128
    X-7.108Y-5.109
    X-7.121Y-5.091
    X-7.136Y-5.075
    X-7.153Y-5.059
    X-7.172Y-5.042
    X-7.190Y-5.027
    X-7.210Y-5.015
    X-7.230Y-5.004
    X-7.251Y-4.994
    X-7.273Y-4.987
    X-7.295Y-4.981
    X-7.318Y-4.977
    X-7.342Y-4.975
    X-7.367Y-4.974
    G1Z-0.700F19.4
    X-7.416Y-4.977
    X-7.439Y-4.981
    X-7.462Y-4.987
    X-7.483Y-4.994
    X-7.504Y-5.004
    X-7.524Y-5.015
    X-7.543Y-5.027
    X-7.562Y-5.042
    X-7.580Y-5.059
    X-7.597Y-5.075
    X-7.612Y-5.091
    X-7.625Y-5.109
    X-7.636Y-5.128
    X-7.645Y-5.148
    X-7.653Y-5.170
    X-7.658Y-5.192
    X-7.662Y-5.216
    X-7.664Y-5.241
    X-7.665Y-5.268
    X-7.664Y-5.293
    X-7.662Y-5.317
    X-7.658Y-5.340
    X-7.653Y-5.362
    X-7.645Y-5.384
    X-7.636Y-5.405
    X-7.625Y-5.425
    X-7.612Y-5.444
    X-7.597Y-5.463
    X-7.580Y-5.481
    X-7.562Y-5.497
    X-7.543Y-5.511
    X-7.524Y-5.523
    X-7.504Y-5.535
    X-7.483Y-5.544
    X-7.462Y-5.552
    X-7.439Y-5.558
    X-7.416Y-5.562
    X-7.392Y-5.565
    X-7.367Y-5.566
    X-7.342Y-5.565
    X-7.318Y-5.562
    X-7.295Y-5.558
    X-7.273Y-5.552
    X-7.251Y-5.544
    X-7.230Y-5.535
    X-7.210Y-5.523
    X-7.190Y-5.511
    X-7.172Y-5.497
    X-7.153Y-5.481
    X-7.136Y-5.463
    X-7.121Y-5.444
    X-7.108Y-5.425
    X-7.096Y-5.405
    X-7.086Y-5.384
    X-7.078Y-5.362
    X-7.072Y-5.340
    X-7.067Y-5.317
    X-7.065Y-5.293
    X-7.064Y-5.268
    X-7.065Y-5.241
    X-7.067Y-5.216
    X-7.072Y-5.192
    X-7.078Y-5.170
    X-7.086Y-5.148
    X-7.096Y-5.128
    X-7.108Y-5.109
    X-7.121Y-5.091
    X-7.136Y-5.075
    X-7.153Y-5.059
    X-7.172Y-5.042
    X-7.190Y-5.027
    X-7.210Y-5.015
    X-7.230Y-5.004
    X-7.251Y-4.994
    X-7.273Y-4.987
    X-7.295Y-4.981
    X-7.318Y-4.977
    X-7.342Y-4.975
    X-7.367Y-4.974
    G0Z12.700
    G0Z12.700
    G0X-5.251Y-5.874
    G0
    G1Z-0.254F19.4
    G1X-5.301Y-5.875F155.2
    X-5.351Y-5.879
    X-5.399Y-5.885
    X-5.447Y-5.893
    X-5.493Y-5.903
    X-5.539Y-5.916
    X-5.584Y-5.932
    X-5.628Y-5.950
    X-5.671Y-5.970
    X-5.713Y-5.993
    X-5.754Y-6.016
    X-5.793Y-6.042
    X-5.831Y-6.069
    X-5.868Y-6.099
    X-5.903Y-6.131
    X-5.936Y-6.165
    X-5.969Y-6.200
    X-5.999Y-6.238
    X-6.028Y-6.278
    X-6.056Y-6.320
    Y-5.943
    X-6.454
    Y-8.510
    X-6.056
    Y-6.962
    X-6.050Y-6.893
    X-6.040Y-6.827
    X-6.026Y-6.765
    X-6.009Y-6.705
    X-5.988Y-6.648
    X-5.964Y-6.594
    X-5.935Y-6.543
    X-5.903Y-6.494
    X-5.867Y-6.448
    X-5.828Y-6.405
    X-5.788Y-6.368
    X-5.747Y-6.335
    X-5.705Y-6.306
    X-5.661Y-6.281
    X-5.615Y-6.260
    X-5.568Y-6.242
    X-5.520Y-6.229
    X-5.470Y-6.219
    X-5.419Y-6.213
    X-5.366Y-6.211
    X-5.238Y-6.219
    X-5.124Y-6.241
    X-5.023Y-6.278
    X-4.935Y-6.331
    X-4.860Y-6.398
    X-4.799Y-6.481
    X-4.752Y-6.578
    X-4.718Y-6.691
    X-4.697Y-6.819
    X-4.690Y-6.962
    Y-8.510
    X-4.293
    Y-6.932
    X-4.302Y-6.730
    X-4.331Y-6.551
    X-4.379Y-6.392
    X-4.447Y-6.254
    X-4.533Y-6.138
    X-4.639Y-6.043
    X-4.763Y-5.969
    X-4.907Y-5.916
    X-5.069Y-5.885
    X-5.251Y-5.874
    G1Z-0.508F19.4
    X-5.351Y-5.879
    X-5.399Y-5.885
    X-5.447Y-5.893
    X-5.493Y-5.903
    X-5.539Y-5.916
    X-5.584Y-5.932
    X-5.628Y-5.950
    X-5.671Y-5.970
    X-5.713Y-5.993
    X-5.754Y-6.016
    X-5.793Y-6.042
    X-5.831Y-6.069
    X-5.868Y-6.099
    X-5.903Y-6.131
    X-5.936Y-6.165
    X-5.969Y-6.200
    X-5.999Y-6.238
    X-6.028Y-6.278
    X-6.056Y-6.320
    Y-5.943
    X-6.454
    Y-8.510
    X-6.056
    Y-6.962
    X-6.050Y-6.893
    X-6.040Y-6.827
    X-6.026Y-6.765
    X-6.009Y-6.705
    X-5.988Y-6.648
    X-5.964Y-6.594
    X-5.935Y-6.543
    X-5.903Y-6.494
    X-5.867Y-6.448
    X-5.828Y-6.405
    X-5.788Y-6.368
    X-5.747Y-6.335
    X-5.705Y-6.306
    X-5.661Y-6.281
    X-5.615Y-6.260
    X-5.568Y-6.242
    X-5.520Y-6.229
    X-5.470Y-6.219
    X-5.419Y-6.213
    X-5.366Y-6.211
    X-5.238Y-6.219
    X-5.124Y-6.241
    X-5.023Y-6.278
    X-4.935Y-6.331
    X-4.860Y-6.398
    X-4.799Y-6.481
    X-4.752Y-6.578
    X-4.718Y-6.691
    X-4.697Y-6.819
    X-4.690Y-6.962
    Y-8.510
    X-4.293
    Y-6.932
    X-4.302Y-6.730
    X-4.331Y-6.551
    X-4.379Y-6.392
    X-4.447Y-6.254
    X-4.533Y-6.138
    X-4.639Y-6.043
    X-4.763Y-5.969
    X-4.907Y-5.916
    X-5.069Y-5.885
    X-5.251Y-5.874
    G1Z-0.700F19.4
    X-5.351Y-5.879
    X-5.399Y-5.885
    X-5.447Y-5.893
    X-5.493Y-5.903
    X-5.539Y-5.916
    X-5.584Y-5.932
    X-5.628Y-5.950
    X-5.671Y-5.970
    X-5.713Y-5.993
    X-5.754Y-6.016
    X-5.793Y-6.042
    X-5.831Y-6.069
    X-5.868Y-6.099
    X-5.903Y-6.131
    X-5.936Y-6.165
    X-5.969Y-6.200
    X-5.999Y-6.238
    X-6.028Y-6.278
    X-6.056Y-6.320
    Y-5.943
    X-6.454
    Y-8.510
    X-6.056
    Y-6.962
    X-6.050Y-6.893
    X-6.040Y-6.827
    X-6.026Y-6.765
    X-6.009Y-6.705
    X-5.988Y-6.648
    X-5.964Y-6.594
    X-5.935Y-6.543
    X-5.903Y-6.494
    X-5.867Y-6.448
    X-5.828Y-6.405
    X-5.788Y-6.368
    X-5.747Y-6.335
    X-5.705Y-6.306
    X-5.661Y-6.281
    X-5.615Y-6.260
    X-5.568Y-6.242
    X-5.520Y-6.229
    X-5.470Y-6.219
    X-5.419Y-6.213
    X-5.366Y-6.211
    X-5.238Y-6.219
    X-5.124Y-6.241
    X-5.023Y-6.278
    X-4.935Y-6.331
    X-4.860Y-6.398
    X-4.799Y-6.481
    X-4.752Y-6.578
    X-4.718Y-6.691
    X-4.697Y-6.819
    X-4.690Y-6.962
    Y-8.510
    X-4.293
    Y-6.932
    X-4.302Y-6.730
    X-4.331Y-6.551
    X-4.379Y-6.392
    X-4.447Y-6.254
    X-4.533Y-6.138
    X-4.639Y-6.043
    X-4.763Y-5.969
    X-4.907Y-5.916
    X-5.069Y-5.885
    X-5.251Y-5.874
    G0Z12.700
    G0Z12.700
    G0X-3.660Y-4.895
    G0
    G1Z-0.254F19.4
    G1Y-8.510F155.2
    X-3.262
    Y-7.602
    X-2.854Y-7.235
    X-1.851Y-8.510
    X-1.340
    X-2.581Y-6.976
    X-1.449Y-5.943
    X-1.975
    X-3.262Y-7.135
    Y-4.895
    X-3.660
    G1Z-0.508F19.4
    G1Y-8.510F155.2
    X-3.262
    Y-7.602
    X-2.854Y-7.235
    X-1.851Y-8.510
    X-1.340
    X-2.581Y-6.976
    X-1.449Y-5.943
    X-1.975
    X-3.262Y-7.135
    Y-4.895
    X-3.660
    G1Z-0.700F19.4
    G1Y-8.510F155.2
    X-3.262
    Y-7.602
    X-2.854Y-7.235
    X-1.851Y-8.510
    X-1.340
    X-2.581Y-6.976
    X-1.449Y-5.943
    X-1.975
    X-3.262Y-7.135
    Y-4.895
    X-3.660
    G0Z12.700
    G0Z12.700
    G0X1.638Y-4.964
    G0
    G1Z-0.254F19.4
    G1X1.574Y-4.966F155.2
    X1.513Y-4.972
    X1.455Y-4.981
    X1.400Y-4.993
    X1.348Y-5.010
    X1.300Y-5.030
    X1.254Y-5.054
    X1.212Y-5.082
    X1.173Y-5.113
    X1.137Y-5.149
    X1.105Y-5.186
    X1.077Y-5.226
    X1.053Y-5.268
    X1.031Y-5.314
    X1.013Y-5.362
    X0.998Y-5.413
    X0.987Y-5.468
    X0.978Y-5.525
    X0.974Y-5.586
    X0.972Y-5.650
    Y-5.943
    X0.327
    Y-6.275
    X0.972
    Y-8.510
    X1.370
    Y-6.275
    X2.095
    Y-5.943
    X1.370
    Y-5.661
    X1.370Y-5.624
    X1.373Y-5.590
    X1.377Y-5.558
    X1.382Y-5.528
    X1.389Y-5.500
    X1.397Y-5.474
    X1.407Y-5.450
    X1.418Y-5.428
    X1.431Y-5.409
    X1.445Y-5.391
    X1.460Y-5.375
    X1.478Y-5.360
    X1.498Y-5.347
    X1.520Y-5.336
    X1.543Y-5.327
    X1.569Y-5.320
    X1.596Y-5.315
    X1.625Y-5.311
    X1.655Y-5.308
    X1.687Y-5.308
    X2.130
    Y-4.964
    X1.638
    G1Z-0.508F19.4
    X1.513Y-4.972
    X1.455Y-4.981
    X1.400Y-4.993
    X1.348Y-5.010
    X1.300Y-5.030
    X1.254Y-5.054
    X1.212Y-5.082
    X1.173Y-5.113
    X1.137Y-5.149
    X1.105Y-5.186
    X1.077Y-5.226
    X1.053Y-5.268
    X1.031Y-5.314
    X1.013Y-5.362
    X0.998Y-5.413
    X0.987Y-5.468
    X0.978Y-5.525
    X0.974Y-5.586
    X0.972Y-5.650
    Y-5.943
    X0.327
    Y-6.275
    X0.972
    Y-8.510
    X1.370
    Y-6.275
    X2.095
    Y-5.943
    X1.370
    Y-5.661
    X1.370Y-5.624
    X1.373Y-5.590
    X1.377Y-5.558
    X1.382Y-5.528
    X1.389Y-5.500
    X1.397Y-5.474
    X1.407Y-5.450
    X1.418Y-5.428
    X1.431Y-5.409
    X1.445Y-5.391
    X1.460Y-5.375
    X1.478Y-5.360
    X1.498Y-5.347
    X1.520Y-5.336
    X1.543Y-5.327
    X1.569Y-5.320
    X1.596Y-5.315
    X1.625Y-5.311
    X1.655Y-5.308
    X1.687Y-5.308
    X2.130
    Y-4.964
    X1.638
    G1Z-0.700F19.4
    X1.513Y-4.972
    X1.455Y-4.981
    X1.400Y-4.993
    X1.348Y-5.010
    X1.300Y-5.030
    X1.254Y-5.054
    X1.212Y-5.082
    X1.173Y-5.113
    X1.137Y-5.149
    X1.105Y-5.186
    X1.077Y-5.226
    X1.053Y-5.268
    X1.031Y-5.314
    X1.013Y-5.362
    X0.998Y-5.413
    X0.987Y-5.468
    X0.978Y-5.525
    X0.974Y-5.586
    X0.972Y-5.650
    Y-5.943
    X0.327
    Y-6.275
    X0.972
    Y-8.510
    X1.370
    Y-6.275
    X2.095
    Y-5.943
    X1.370
    Y-5.661
    X1.370Y-5.624
    X1.373Y-5.590
    X1.377Y-5.558
    X1.382Y-5.528
    X1.389Y-5.500
    X1.397Y-5.474
    X1.407Y-5.450
    X1.418Y-5.428
    X1.431Y-5.409
    X1.445Y-5.391
    X1.460Y-5.375
    X1.478Y-5.360
    X1.498Y-5.347
    X1.520Y-5.336
    X1.543Y-5.327
    X1.569Y-5.320
    X1.596Y-5.315
    X1.625Y-5.311
    X1.655Y-5.308
    X1.687Y-5.308
    X2.130
    Y-4.964
    X1.638
    G0Z12.700
    G0Z12.700
    G0X2.552Y-4.895
    G0
    G1Z-0.254F19.4
    G1Y-8.510F155.2
    X2.945
    Y-4.895
    X2.552
    G1Z-0.508F19.4
    G1Y-8.510F155.2
    X2.945
    Y-4.895
    X2.552
    G1Z-0.700F19.4
    G1Y-8.510F155.2
    X2.945
    Y-4.895
    X2.552
    G0Z12.700
    G0Z12.700
    G0X4.785Y-5.874
    G0
    G1Z-0.254F19.4
    G1X4.671Y-5.878F155.2
    X4.562Y-5.890
    X4.458Y-5.909
    X4.359Y-5.936
    X4.265Y-5.972
    X4.176Y-6.015
    X4.091Y-6.067
    X4.011Y-6.126
    X3.936Y-6.194
    X3.865Y-6.271
    X3.803Y-6.349
    X3.748Y-6.430
    X3.698Y-6.516
    X3.656Y-6.606
    X3.620Y-6.700
    X3.590Y-6.798
    X3.567Y-6.899
    X3.551Y-7.005
    X3.541Y-7.116
    X3.538Y-7.230
    X3.541Y-7.343
    X3.551Y-7.451
    X3.567Y-7.556
    X3.590Y-7.657
    X3.620Y-7.754
    X3.656Y-7.847
    X3.698Y-7.936
    X3.748Y-8.021
    X3.803Y-8.102
    X3.865Y-8.178
    X3.936Y-8.255
    X4.011Y-8.323
    X4.091Y-8.383
    X4.176Y-8.436
    X4.265Y-8.480
    X4.359Y-8.516
    X4.458Y-8.545
    X4.562Y-8.565
    X4.671Y-8.577
    X4.785Y-8.581
    X4.897Y-8.577
    X5.005Y-8.565
    X5.109Y-8.545
    X5.208Y-8.516
    X5.302Y-8.480
    X5.392Y-8.436
    X5.478Y-8.383
    X5.559Y-8.323
    X5.635Y-8.255
    X5.708Y-8.178
    X5.769Y-8.102
    X5.823Y-8.021
    X5.872Y-7.936
    X5.914Y-7.847
    X5.950Y-7.754
    X5.979Y-7.657
    X6.002Y-7.556
    X6.018Y-7.451
    X6.028Y-7.343
    X6.031Y-7.230
    X6.028Y-7.116
    X6.018Y-7.005
    X6.002Y-6.899
    X5.979Y-6.798
    X5.949Y-6.700
    X5.913Y-6.606
    X5.870Y-6.516
    X5.821Y-6.430
    X5.765Y-6.349
    X5.703Y-6.271
    X5.632Y-6.194
    X5.556Y-6.126
    X5.476Y-6.067
    X5.391Y-6.015
    X5.301Y-5.972
    X5.207Y-5.936
    X5.108Y-5.909
    X5.005Y-5.890
    X4.897Y-5.878
    X4.785Y-5.874
    G1Z-0.508F19.4
    X4.562Y-5.890
    X4.458Y-5.909
    X4.359Y-5.936
    X4.265Y-5.972
    X4.176Y-6.015
    X4.091Y-6.067
    X4.011Y-6.126
    X3.936Y-6.194
    X3.865Y-6.271
    X3.803Y-6.349
    X3.748Y-6.430
    X3.698Y-6.516
    X3.656Y-6.606
    X3.620Y-6.700
    X3.590Y-6.798
    X3.567Y-6.899
    X3.551Y-7.005
    X3.541Y-7.116
    X3.538Y-7.230
    X3.541Y-7.343
    X3.551Y-7.451
    X3.567Y-7.556
    X3.590Y-7.657
    X3.620Y-7.754
    X3.656Y-7.847
    X3.698Y-7.936
    X3.748Y-8.021
    X3.803Y-8.102
    X3.865Y-8.178
    X3.936Y-8.255
    X4.011Y-8.323
    X4.091Y-8.383
    X4.176Y-8.436
    X4.265Y-8.480
    X4.359Y-8.516
    X4.458Y-8.545
    X4.562Y-8.565
    X4.671Y-8.577
    X4.785Y-8.581
    X4.897Y-8.577
    X5.005Y-8.565
    X5.109Y-8.545
    X5.208Y-8.516
    X5.302Y-8.480
    X5.392Y-8.436
    X5.478Y-8.383
    X5.559Y-8.323
    X5.635Y-8.255
    X5.708Y-8.178
    X5.769Y-8.102
    X5.823Y-8.021
    X5.872Y-7.936
    X5.914Y-7.847
    X5.950Y-7.754
    X5.979Y-7.657
    X6.002Y-7.556
    X6.018Y-7.451
    X6.028Y-7.343
    X6.031Y-7.230
    X6.028Y-7.116
    X6.018Y-7.005
    X6.002Y-6.899
    X5.979Y-6.798
    X5.949Y-6.700
    X5.913Y-6.606
    X5.870Y-6.516
    X5.821Y-6.430
    X5.765Y-6.349
    X5.703Y-6.271
    X5.632Y-6.194
    X5.556Y-6.126
    X5.476Y-6.067
    X5.391Y-6.015
    X5.301Y-5.972
    X5.207Y-5.936
    X5.108Y-5.909
    X5.005Y-5.890
    X4.897Y-5.878
    X4.785Y-5.874
    G1Z-0.700F19.4
    X4.562Y-5.890
    X4.458Y-5.909
    X4.359Y-5.936
    X4.265Y-5.972
    X4.176Y-6.015
    X4.091Y-6.067
    X4.011Y-6.126
    X3.936Y-6.194
    X3.865Y-6.271
    X3.803Y-6.349
    X3.748Y-6.430
    X3.698Y-6.516
    X3.656Y-6.606
    X3.620Y-6.700
    X3.590Y-6.798
    X3.567Y-6.899
    X3.551Y-7.005
    X3.541Y-7.116
    X3.538Y-7.230
    X3.541Y-7.343
    X3.551Y-7.451
    X3.567Y-7.556
    X3.590Y-7.657
    X3.620Y-7.754
    X3.656Y-7.847
    X3.698Y-7.936
    X3.748Y-8.021
    X3.803Y-8.102
    X3.865Y-8.178
    X3.936Y-8.255
    X4.011Y-8.323
    X4.091Y-8.383
    X4.176Y-8.436
    X4.265Y-8.480
    X4.359Y-8.516
    X4.458Y-8.545
    X4.562Y-8.565
    X4.671Y-8.577
    X4.785Y-8.581
    X4.897Y-8.577
    X5.005Y-8.565
    X5.109Y-8.545
    X5.208Y-8.516
    X5.302Y-8.480
    X5.392Y-8.436
    X5.478Y-8.383
    X5.559Y-8.323
    X5.635Y-8.255
    X5.708Y-8.178
    X5.769Y-8.102
    X5.823Y-8.021
    X5.872Y-7.936
    X5.914Y-7.847
    X5.950Y-7.754
    X5.979Y-7.657
    X6.002Y-7.556
    X6.018Y-7.451
    X6.028Y-7.343
    X6.031Y-7.230
    X6.028Y-7.116
    X6.018Y-7.005
    X6.002Y-6.899
    X5.979Y-6.798
    X5.949Y-6.700
    X5.913Y-6.606
    X5.870Y-6.516
    X5.821Y-6.430
    X5.765Y-6.349
    X5.703Y-6.271
    X5.632Y-6.194
    X5.556Y-6.126
    X5.476Y-6.067
    X5.391Y-6.015
    X5.301Y-5.972
    X5.207Y-5.936
    X5.108Y-5.909
    X5.005Y-5.890
    X4.897Y-5.878
    X4.785Y-5.874
    G0Z12.700
    G0Z12.700
    G0Y-6.206
    G0
    G1Z-0.254F19.4
    G1X4.863Y-6.209F155.2
    X4.939Y-6.219
    X5.011Y-6.234
    X5.080Y-6.256
    X5.146Y-6.285
    X5.208Y-6.319
    X5.267Y-6.360
    X5.323Y-6.407
    X5.376Y-6.460
    X5.425Y-6.519
    X5.463Y-6.577
    X5.497Y-6.638
    X5.528Y-6.702
    X5.554Y-6.768
    X5.577Y-6.837
    X5.595Y-6.909
    X5.610Y-6.985
    X5.620Y-7.063
    X5.627Y-7.145
    X5.629Y-7.230
    X5.627Y-7.312
    X5.620Y-7.392
    X5.610Y-7.469
    X5.595Y-7.544
    X5.577Y-7.616
    X5.554Y-7.685
    X5.528Y-7.752
    X5.497Y-7.816
    X5.463Y-7.877
    X5.425Y-7.934
    X5.376Y-7.994
    X5.323Y-8.047
    X5.267Y-8.094
    X5.208Y-8.135
    X5.146Y-8.169
    X5.080Y-8.197
    X5.011Y-8.219
    X4.939Y-8.235
    X4.863Y-8.244
    X4.785Y-8.247
    X4.704Y-8.244
    X4.628Y-8.235
    X4.555Y-8.219
    X4.485Y-8.197
    X4.420Y-8.169
    X4.358Y-8.135
    X4.300Y-8.094
    X4.245Y-8.047
    X4.195Y-7.994
    X4.148Y-7.934
    X4.109Y-7.877
    X4.074Y-7.816
    X4.043Y-7.753
    X4.017Y-7.687
    X3.994Y-7.618
    X3.976Y-7.546
    X3.962Y-7.471
    X3.952Y-7.394
    X3.946Y-7.313
    X3.944Y-7.230
    X3.946Y-7.145
    X3.952Y-7.063
    X3.962Y-6.985
    X3.976Y-6.909
    X3.994Y-6.837
    X4.017Y-6.768
    X4.043Y-6.702
    X4.074Y-6.638
    X4.109Y-6.577
    X4.148Y-6.519
    X4.195Y-6.460
    X4.245Y-6.407
    X4.300Y-6.360
    X4.358Y-6.319
    X4.420Y-6.285
    X4.485Y-6.256
    X4.555Y-6.234
    X4.628Y-6.219
    X4.704Y-6.209
    X4.785Y-6.206
    G1Z-0.508F19.4
    X4.939Y-6.219
    X5.011Y-6.234
    X5.080Y-6.256
    X5.146Y-6.285
    X5.208Y-6.319
    X5.267Y-6.360
    X5.323Y-6.407
    X5.376Y-6.460
    X5.425Y-6.519
    X5.463Y-6.577
    X5.497Y-6.638
    X5.528Y-6.702
    X5.554Y-6.768
    X5.577Y-6.837
    X5.595Y-6.909
    X5.610Y-6.985
    X5.620Y-7.063
    X5.627Y-7.145
    X5.629Y-7.230
    X5.627Y-7.312
    X5.620Y-7.392
    X5.610Y-7.469
    X5.595Y-7.544
    X5.577Y-7.616
    X5.554Y-7.685
    X5.528Y-7.752
    X5.497Y-7.816
    X5.463Y-7.877
    X5.425Y-7.934
    X5.376Y-7.994
    X5.323Y-8.047
    X5.267Y-8.094
    X5.208Y-8.135
    X5.146Y-8.169
    X5.080Y-8.197
    X5.011Y-8.219
    X4.939Y-8.235
    X4.863Y-8.244
    X4.785Y-8.247
    X4.704Y-8.244
    X4.628Y-8.235
    X4.555Y-8.219
    X4.485Y-8.197
    X4.420Y-8.169
    X4.358Y-8.135
    X4.300Y-8.094
    X4.245Y-8.047
    X4.195Y-7.994
    X4.148Y-7.934
    X4.109Y-7.877
    X4.074Y-7.816
    X4.043Y-7.753
    X4.017Y-7.687
    X3.994Y-7.618
    X3.976Y-7.546
    X3.962Y-7.471
    X3.952Y-7.394
    X3.946Y-7.313
    X3.944Y-7.230
    X3.946Y-7.145
    X3.952Y-7.063
    X3.962Y-6.985
    X3.976Y-6.909
    X3.994Y-6.837
    X4.017Y-6.768
    X4.043Y-6.702
    X4.074Y-6.638
    X4.109Y-6.577
    X4.148Y-6.519
    X4.195Y-6.460
    X4.245Y-6.407
    X4.300Y-6.360
    X4.358Y-6.319
    X4.420Y-6.285
    X4.485Y-6.256
    X4.555Y-6.234
    X4.628Y-6.219
    X4.704Y-6.209
    X4.785Y-6.206
    G1Z-0.700F19.4
    X4.939Y-6.219
    X5.011Y-6.234
    X5.080Y-6.256
    X5.146Y-6.285
    X5.208Y-6.319
    X5.267Y-6.360
    X5.323Y-6.407
    X5.376Y-6.460
    X5.425Y-6.519
    X5.463Y-6.577
    X5.497Y-6.638
    X5.528Y-6.702
    X5.554Y-6.768
    X5.577Y-6.837
    X5.595Y-6.909
    X5.610Y-6.985
    X5.620Y-7.063
    X5.627Y-7.145
    X5.629Y-7.230
    X5.627Y-7.312
    X5.620Y-7.392
    X5.610Y-7.469
    X5.595Y-7.544
    X5.577Y-7.616
    X5.554Y-7.685
    X5.528Y-7.752
    X5.497Y-7.816
    X5.463Y-7.877
    X5.425Y-7.934
    X5.376Y-7.994
    X5.323Y-8.047
    X5.267Y-8.094
    X5.208Y-8.135
    X5.146Y-8.169
    X5.080Y-8.197
    X5.011Y-8.219
    X4.939Y-8.235
    X4.863Y-8.244
    X4.785Y-8.247
    X4.704Y-8.244
    X4.628Y-8.235
    X4.555Y-8.219
    X4.485Y-8.197
    X4.420Y-8.169
    X4.358Y-8.135
    X4.300Y-8.094
    X4.245Y-8.047
    X4.195Y-7.994
    X4.148Y-7.934
    X4.109Y-7.877
    X4.074Y-7.816
    X4.043Y-7.753
    X4.017Y-7.687
    X3.994Y-7.618
    X3.976Y-7.546
    X3.962Y-7.471
    X3.952Y-7.394
    X3.946Y-7.313
    X3.944Y-7.230
    X3.946Y-7.145
    X3.952Y-7.063
    X3.962Y-6.985
    X3.976Y-6.909
    X3.994Y-6.837
    X4.017Y-6.768
    X4.043Y-6.702
    X4.074Y-6.638
    X4.109Y-6.577
    X4.148Y-6.519
    X4.195Y-6.460
    X4.245Y-6.407
    X4.300Y-6.360
    X4.358Y-6.319
    X4.420Y-6.285
    X4.485Y-6.256
    X4.555Y-6.234
    X4.628Y-6.219
    X4.704Y-6.209
    X4.785Y-6.206
    G0Z12.700
    G0Z12.700
    G0X6.303Y-5.943
    G0
    G1Z-0.254F19.4
    G1X7.177Y-8.510F155.2
    X7.550
    X8.156Y-6.445
    X8.752Y-8.510
    X9.129
    X10.003Y-5.943
    X9.566
    X8.936Y-8.024
    X8.339Y-5.943
    X7.967
    X7.371Y-8.024
    X6.740Y-5.943
    X6.303
    G1Z-0.508F19.4
    X7.550
    X8.156Y-6.445
    X8.752Y-8.510
    X9.129
    X10.003Y-5.943
    X9.566
    X8.936Y-8.024
    X8.339Y-5.943
    X7.967
    X7.371Y-8.024
    X6.740Y-5.943
    X6.303
    G1Z-0.700F19.4
    X7.550
    X8.156Y-6.445
    X8.752Y-8.510
    X9.129
    X10.003Y-5.943
    X9.566
    X8.936Y-8.024
    X8.339Y-5.943
    X7.967
    X7.371Y-8.024
    X6.740Y-5.943
    X6.303
    G0Z12.700
    G0Z12.700
    G0X11.370Y-5.874
    G0
    G1Z-0.254F19.4
    G1X11.260Y-5.878F155.2
    X11.156Y-5.890
    X11.056Y-5.910
    X10.961Y-5.938
    X10.870Y-5.974
    X10.784Y-6.018
    X10.703Y-6.071
    X10.626Y-6.131
    X10.553Y-6.199
    X10.486Y-6.275
    X10.424Y-6.353
    X10.368Y-6.435
    X10.320Y-6.521
    X10.278Y-6.610
    X10.243Y-6.703
    X10.214Y-6.800
    X10.192Y-6.901
    X10.176Y-7.005
    X10.166Y-7.113
    X10.163Y-7.225
    X10.166Y-7.347
    X10.176Y-7.465
    X10.193Y-7.577
    X10.216Y-7.683
    X10.246Y-7.785
    X10.283Y-7.881
    X10.327Y-7.973
    X10.378Y-8.060
    X10.435Y-8.141
    X10.500Y-8.218
    X10.568Y-8.286
    X10.641Y-8.347
    X10.718Y-8.401
    X10.800Y-8.449
    X10.886Y-8.489
    X10.977Y-8.522
    X11.073Y-8.547
    X11.172Y-8.566
    X11.276Y-8.577
    X11.384Y-8.581
    X11.483Y-8.578
    X11.577Y-8.569
    X11.668Y-8.554
    X11.756Y-8.534
    X11.839Y-8.507
    X11.919Y-8.476
    X11.996Y-8.438
    X12.069Y-8.395
    X12.138Y-8.346
    X12.204Y-8.292
    X12.254Y-8.243
    X12.301Y-8.192
    X12.344Y-8.138
    X12.384Y-8.082
    X12.420Y-8.023
    X12.453Y-7.961
    X12.483Y-7.897
    X12.509Y-7.830
    X12.532Y-7.760
    X12.552Y-7.687
    X12.154
    X12.135Y-7.739
    X12.113Y-7.789
    X12.091Y-7.836
    X12.067Y-7.880
    X12.042Y-7.921
    X12.016Y-7.960
    X11.988Y-7.996
    X11.959Y-8.030
    X11.928Y-8.061
    X11.896Y-8.088
    X11.856Y-8.118
    X11.813Y-8.145
    X11.768Y-8.169
    X11.720Y-8.189
    X11.670Y-8.207
    X11.617Y-8.221
    X11.562Y-8.233
    X11.505Y-8.241
    X11.446Y-8.246
    X11.384Y-8.247
    X11.313Y-8.245
    X11.244Y-8.238
    X11.179Y-8.226
    X11.116Y-8.209
    X11.057Y-8.188
    X11.001Y-8.162
    X10.948Y-8.131
    X10.898Y-8.095
    X10.852Y-8.055
    X10.808Y-8.010
    X10.768Y-7.960
    X10.732Y-7.906
    X10.700Y-7.849
    X10.672Y-7.788
    X10.647Y-7.723
    X10.626Y-7.653
    X10.608Y-7.581
    X10.594Y-7.504
    X10.583Y-7.423
    X10.575Y-7.339
    X12.602
    X12.596Y-7.208
    X12.585Y-7.082
    X12.568Y-6.962
    X12.546Y-6.848
    X12.519Y-6.741
    X12.487Y-6.639
    X12.449Y-6.543
    X12.406Y-6.453
    X12.357Y-6.369
    X12.304Y-6.291
    X12.238Y-6.212
    X12.166Y-6.141
    X12.088Y-6.078
    X12.004Y-6.024
    X11.913Y-5.978
    X11.817Y-5.941
    X11.714Y-5.911
    X11.605Y-5.891
    X11.491Y-5.878
    X11.370Y-5.874
    G1Z-0.508F19.4
    X11.156Y-5.890
    X11.056Y-5.910
    X10.961Y-5.938
    X10.870Y-5.974
    X10.784Y-6.018
    X10.703Y-6.071
    X10.626Y-6.131
    X10.553Y-6.199
    X10.486Y-6.275
    X10.424Y-6.353
    X10.368Y-6.435
    X10.320Y-6.521
    X10.278Y-6.610
    X10.243Y-6.703
    X10.214Y-6.800
    X10.192Y-6.901
    X10.176Y-7.005
    X10.166Y-7.113
    X10.163Y-7.225
    X10.166Y-7.347
    X10.176Y-7.465
    X10.193Y-7.577
    X10.216Y-7.683
    X10.246Y-7.785
    X10.283Y-7.881
    X10.327Y-7.973
    X10.378Y-8.060
    X10.435Y-8.141
    X10.500Y-8.218
    X10.568Y-8.286
    X10.641Y-8.347
    X10.718Y-8.401
    X10.800Y-8.449
    X10.886Y-8.489
    X10.977Y-8.522
    X11.073Y-8.547
    X11.172Y-8.566
    X11.276Y-8.577
    X11.384Y-8.581
    X11.483Y-8.578
    X11.577Y-8.569
    X11.668Y-8.554
    X11.756Y-8.534
    X11.839Y-8.507
    X11.919Y-8.476
    X11.996Y-8.438
    X12.069Y-8.395
    X12.138Y-8.346
    X12.204Y-8.292
    X12.254Y-8.243
    X12.301Y-8.192
    X12.344Y-8.138
    X12.384Y-8.082
    X12.420Y-8.023
    X12.453Y-7.961
    X12.483Y-7.897
    X12.509Y-7.830
    X12.532Y-7.760
    X12.552Y-7.687
    X12.154
    X12.135Y-7.739
    X12.113Y-7.789
    X12.091Y-7.836
    X12.067Y-7.880
    X12.042Y-7.921
    X12.016Y-7.960
    X11.988Y-7.996
    X11.959Y-8.030
    X11.928Y-8.061
    X11.896Y-8.088
    X11.856Y-8.118
    X11.813Y-8.145
    X11.768Y-8.169
    X11.720Y-8.189
    X11.670Y-8.207
    X11.617Y-8.221
    X11.562Y-8.233
    X11.505Y-8.241
    X11.446Y-8.246
    X11.384Y-8.247
    X11.313Y-8.245
    X11.244Y-8.238
    X11.179Y-8.226
    X11.116Y-8.209
    X11.057Y-8.188
    X11.001Y-8.162
    X10.948Y-8.131
    X10.898Y-8.095
    X10.852Y-8.055
    X10.808Y-8.010
    X10.768Y-7.960
    X10.732Y-7.906
    X10.700Y-7.849
    X10.672Y-7.788
    X10.647Y-7.723
    X10.626Y-7.653
    X10.608Y-7.581
    X10.594Y-7.504
    X10.583Y-7.423
    X10.575Y-7.339
    X12.602
    X12.596Y-7.208
    X12.585Y-7.082
    X12.568Y-6.962
    X12.546Y-6.848
    X12.519Y-6.741
    X12.487Y-6.639
    X12.449Y-6.543
    X12.406Y-6.453
    X12.357Y-6.369
    X12.304Y-6.291
    X12.238Y-6.212
    X12.166Y-6.141
    X12.088Y-6.078
    X12.004Y-6.024
    X11.913Y-5.978
    X11.817Y-5.941
    X11.714Y-5.911
    X11.605Y-5.891
    X11.491Y-5.878
    X11.370Y-5.874
    G1Z-0.700F19.4
    X11.156Y-5.890
    X11.056Y-5.910
    X10.961Y-5.938
    X10.870Y-5.974
    X10.784Y-6.018
    X10.703Y-6.071
    X10.626Y-6.131
    X10.553Y-6.199
    X10.486Y-6.275
    X10.424Y-6.353
    X10.368Y-6.435
    X10.320Y-6.521
    X10.278Y-6.610
    X10.243Y-6.703
    X10.214Y-6.800
    X10.192Y-6.901
    X10.176Y-7.005
    X10.166Y-7.113
    X10.163Y-7.225
    X10.166Y-7.347
    X10.176Y-7.465
    X10.193Y-7.577
    X10.216Y-7.683
    X10.246Y-7.785
    X10.283Y-7.881
    X10.327Y-7.973
    X10.378Y-8.060
    X10.435Y-8.141
    X10.500Y-8.218
    X10.568Y-8.286
    X10.641Y-8.347
    X10.718Y-8.401
    X10.800Y-8.449
    X10.886Y-8.489
    X10.977Y-8.522
    X11.073Y-8.547
    X11.172Y-8.566
    X11.276Y-8.577
    X11.384Y-8.581
    X11.483Y-8.578
    X11.577Y-8.569
    X11.668Y-8.554
    X11.756Y-8.534
    X11.839Y-8.507
    X11.919Y-8.476
    X11.996Y-8.438
    X12.069Y-8.395
    X12.138Y-8.346
    X12.204Y-8.292
    X12.254Y-8.243
    X12.301Y-8.192
    X12.344Y-8.138
    X12.384Y-8.082
    X12.420Y-8.023
    X12.453Y-7.961
    X12.483Y-7.897
    X12.509Y-7.830
    X12.532Y-7.760
    X12.552Y-7.687
    X12.154
    X12.135Y-7.739
    X12.113Y-7.789
    X12.091Y-7.836
    X12.067Y-7.880
    X12.042Y-7.921
    X12.016Y-7.960
    X11.988Y-7.996
    X11.959Y-8.030
    X11.928Y-8.061
    X11.896Y-8.088
    X11.856Y-8.118
    X11.813Y-8.145
    X11.768Y-8.169
    X11.720Y-8.189
    X11.670Y-8.207
    X11.617Y-8.221
    X11.562Y-8.233
    X11.505Y-8.241
    X11.446Y-8.246
    X11.384Y-8.247
    X11.313Y-8.245
    X11.244Y-8.238
    X11.179Y-8.226
    X11.116Y-8.209
    X11.057Y-8.188
    X11.001Y-8.162
    X10.948Y-8.131
    X10.898Y-8.095
    X10.852Y-8.055
    X10.808Y-8.010
    X10.768Y-7.960
    X10.732Y-7.906
    X10.700Y-7.849
    X10.672Y-7.788
    X10.647Y-7.723
    X10.626Y-7.653
    X10.608Y-7.581
    X10.594Y-7.504
    X10.583Y-7.423
    X10.575Y-7.339
    X12.602
    X12.596Y-7.208
    X12.585Y-7.082
    X12.568Y-6.962
    X12.546Y-6.848
    X12.519Y-6.741
    X12.487Y-6.639
    X12.449Y-6.543
    X12.406Y-6.453
    X12.357Y-6.369
    X12.304Y-6.291
    X12.238Y-6.212
    X12.166Y-6.141
    X12.088Y-6.078
    X12.004Y-6.024
    X11.913Y-5.978
    X11.817Y-5.941
    X11.714Y-5.911
    X11.605Y-5.891
    X11.491Y-5.878
    X11.370Y-5.874
    G0Z12.700
    G0Z12.700
    G0X11.380Y-6.206
    G0
    G1Z-0.254F19.4
    G1X11.519Y-6.214F155.2
    X11.646Y-6.239
    X11.760Y-6.280
    X11.860Y-6.338
    X11.948Y-6.412
    X12.023Y-6.502
    X12.085Y-6.609
    X12.133Y-6.733
    X12.168Y-6.874
    X12.190Y-7.031
    X10.585
    X10.594Y-6.957
    X10.606Y-6.885
    X10.622Y-6.817
    X10.641Y-6.753
    X10.664Y-6.691
    X10.690Y-6.633
    X10.719Y-6.577
    X10.752Y-6.525
    X10.788Y-6.476
    X10.828Y-6.429
    X10.871Y-6.387
    X10.917Y-6.349
    X10.965Y-6.316
    X11.017Y-6.287
    X11.070Y-6.262
    X11.127Y-6.242
    X11.186Y-6.227
    X11.248Y-6.215
    X11.312Y-6.209
    X11.380Y-6.206
    G1Z-0.508F19.4
    X11.646Y-6.239
    X11.760Y-6.280
    X11.860Y-6.338
    X11.948Y-6.412
    X12.023Y-6.502
    X12.085Y-6.609
    X12.133Y-6.733
    X12.168Y-6.874
    X12.190Y-7.031
    X10.585
    X10.594Y-6.957
    X10.606Y-6.885
    X10.622Y-6.817
    X10.641Y-6.753
    X10.664Y-6.691
    X10.690Y-6.633
    X10.719Y-6.577
    X10.752Y-6.525
    X10.788Y-6.476
    X10.828Y-6.429
    X10.871Y-6.387
    X10.917Y-6.349
    X10.965Y-6.316
    X11.017Y-6.287
    X11.070Y-6.262
    X11.127Y-6.242
    X11.186Y-6.227
    X11.248Y-6.215
    X11.312Y-6.209
    X11.380Y-6.206
    G1Z-0.700F19.4
    X11.646Y-6.239
    X11.760Y-6.280
    X11.860Y-6.338
    X11.948Y-6.412
    X12.023Y-6.502
    X12.085Y-6.609
    X12.133Y-6.733
    X12.168Y-6.874
    X12.190Y-7.031
    X10.585
    X10.594Y-6.957
    X10.606Y-6.885
    X10.622Y-6.817
    X10.641Y-6.753
    X10.664Y-6.691
    X10.690Y-6.633
    X10.719Y-6.577
    X10.752Y-6.525
    X10.788Y-6.476
    X10.828Y-6.429
    X10.871Y-6.387
    X10.917Y-6.349
    X10.965Y-6.316
    X11.017Y-6.287
    X11.070Y-6.262
    X11.127Y-6.242
    X11.186Y-6.227
    X11.248Y-6.215
    X11.312Y-6.209
    X11.380Y-6.206
    G0Z12.700
    G0Z12.700
    G0X14.233Y-5.874
    G0
    G1Z-0.254F19.4
    G1X14.180Y-5.876F155.2
    X14.129Y-5.881
    X14.079Y-5.889
    X14.030Y-5.900
    X13.983Y-5.915
    X13.937Y-5.933
    X13.893Y-5.954
    X13.849Y-5.979
    X13.807Y-6.007
    X13.766Y-6.038
    X13.734Y-6.064
    X13.703Y-6.092
    X13.673Y-6.123
    X13.645Y-6.155
    X13.617Y-6.190
    X13.591Y-6.226
    X13.566Y-6.264
    X13.542Y-6.305
    X13.520Y-6.347
    X13.498Y-6.391
    Y-5.943
    X13.105
    Y-8.510
    X13.498
    Y-7.150
    X13.500Y-7.080
    X13.506Y-7.011
    X13.516Y-6.945
    X13.530Y-6.881
    X13.548Y-6.819
    X13.570Y-6.759
    X13.596Y-6.701
    X13.627Y-6.645
    X13.662Y-6.591
    X13.702Y-6.540
    X13.743Y-6.489
    X13.787Y-6.443
    X13.832Y-6.404
    X13.879Y-6.369
    X13.929Y-6.340
    X13.980Y-6.317
    X14.033Y-6.299
    X14.088Y-6.286
    X14.145Y-6.278
    X14.204Y-6.275
    X14.241Y-6.276
    X14.279Y-6.277
    X14.317Y-6.280
    X14.355Y-6.283
    X14.393Y-6.288
    X14.431Y-6.294
    X14.470Y-6.301
    X14.508Y-6.309
    X14.547Y-6.319
    X14.586Y-6.330
    Y-5.933
    X14.557Y-5.922
    X14.526Y-5.912
    X14.494Y-5.903
    X14.461Y-5.895
    X14.426Y-5.889
    X14.390Y-5.883
    X14.353Y-5.879
    X14.314Y-5.876
    X14.274Y-5.875
    X14.233Y-5.874
    G1Z-0.508F19.4
    X14.129Y-5.881
    X14.079Y-5.889
    X14.030Y-5.900
    X13.983Y-5.915
    X13.937Y-5.933
    X13.893Y-5.954
    X13.849Y-5.979
    X13.807Y-6.007
    X13.766Y-6.038
    X13.734Y-6.064
    X13.703Y-6.092
    X13.673Y-6.123
    X13.645Y-6.155
    X13.617Y-6.190
    X13.591Y-6.226
    X13.566Y-6.264
    X13.542Y-6.305
    X13.520Y-6.347
    X13.498Y-6.391
    Y-5.943
    X13.105
    Y-8.510
    X13.498
    Y-7.150
    X13.500Y-7.080
    X13.506Y-7.011
    X13.516Y-6.945
    X13.530Y-6.881
    X13.548Y-6.819
    X13.570Y-6.759
    X13.596Y-6.701
    X13.627Y-6.645
    X13.662Y-6.591
    X13.702Y-6.540
    X13.743Y-6.489
    X13.787Y-6.443
    X13.832Y-6.404
    X13.879Y-6.369
    X13.929Y-6.340
    X13.980Y-6.317
    X14.033Y-6.299
    X14.088Y-6.286
    X14.145Y-6.278
    X14.204Y-6.275
    X14.241Y-6.276
    X14.279Y-6.277
    X14.317Y-6.280
    X14.355Y-6.283
    X14.393Y-6.288
    X14.431Y-6.294
    X14.470Y-6.301
    X14.508Y-6.309
    X14.547Y-6.319
    X14.586Y-6.330
    Y-5.933
    X14.557Y-5.922
    X14.526Y-5.912
    X14.494Y-5.903
    X14.461Y-5.895
    X14.426Y-5.889
    X14.390Y-5.883
    X14.353Y-5.879
    X14.314Y-5.876
    X14.274Y-5.875
    X14.233Y-5.874
    G1Z-0.700F19.4
    X14.129Y-5.881
    X14.079Y-5.889
    X14.030Y-5.900
    X13.983Y-5.915
    X13.937Y-5.933
    X13.893Y-5.954
    X13.849Y-5.979
    X13.807Y-6.007
    X13.766Y-6.038
    X13.734Y-6.064
    X13.703Y-6.092
    X13.673Y-6.123
    X13.645Y-6.155
    X13.617Y-6.190
    X13.591Y-6.226
    X13.566Y-6.264
    X13.542Y-6.305
    X13.520Y-6.347
    X13.498Y-6.391
    Y-5.943
    X13.105
    Y-8.510
    X13.498
    Y-7.150
    X13.500Y-7.080
    X13.506Y-7.011
    X13.516Y-6.945
    X13.530Y-6.881
    X13.548Y-6.819
    X13.570Y-6.759
    X13.596Y-6.701
    X13.627Y-6.645
    X13.662Y-6.591
    X13.702Y-6.540
    X13.743Y-6.489
    X13.787Y-6.443
    X13.832Y-6.404
    X13.879Y-6.369
    X13.929Y-6.340
    X13.980Y-6.317
    X14.033Y-6.299
    X14.088Y-6.286
    X14.145Y-6.278
    X14.204Y-6.275
    X14.241Y-6.276
    X14.279Y-6.277
    X14.317Y-6.280
    X14.355Y-6.283
    X14.393Y-6.288
    X14.431Y-6.294
    X14.470Y-6.301
    X14.508Y-6.309
    X14.547Y-6.319
    X14.586Y-6.330
    Y-5.933
    X14.557Y-5.922
    X14.526Y-5.912
    X14.494Y-5.903
    X14.461Y-5.895
    X14.426Y-5.889
    X14.390Y-5.883
    X14.353Y-5.879
    X14.314Y-5.876
    X14.274Y-5.875
    X14.233Y-5.874
    G0Z12.700
    G0Z12.700
    G0Z12.700
    M5
    M30
    (END)
  6. jamesd2000
    sorry a don't know how to get it from candle.
    Dont see anything in the gcode
    Check your calibration then
  8. jamesd2000
    I think this is the problem that i cant overcome.
    the 0 spot in candle is different to the zero spot in carbide...
    in carbide its more above the F
  9. jamesd2000
    And same if i use easel.. to the left..
