G Code error
Discussion in 'CNC Mills/Routers' started by KEITHABEAR, Dec 8, 2019.
  1. KEITHABEAR
    KEITHABEAR Well-Known
    Is there a way to check gcodes for errors I am getting ready to do a project that will take about 12 hours
    If you used a Grbl Post (popular and proven one) GCODE errors are very unlikely. In a real world scenario you'd more likely have issues with
    1) EMI
    2) Windows
    3) Endmills breaking
    4) Stocking coming out of the clamps
    5) Power failures
  3. David the swarfer
    send $C to GRBL then send the Gcode. $C puts it into check mode.
    give another $C to get back to normal mode. This does do a soft reset so do check your offsets before you start the job.
  4. KEITHABEAR
    Thanks for the reply
