Shapeoko CNC router - Not working M3 ,M5 Command
Discussion in 'CNC Mills/Routers' started by Vmgobinath, Nov 29, 2019.
  1. Vmgobinath
    I have Shapeoko CNC router and want to use servo motor using PWM pin (D11) via universal gcode sender
    But unfortunately, M3, M4 or M5 code is not making any movement on servo motor (MG955) like rotating or on or off the servo motor which is attached with PWM pin , 5V and Grd. No error also not showing in the universal gcode sender.
    is there any modification required on config .h and upload grblupload once again?
    Anyone can support me to solve this issue?
    Info: GRBL version 1.1
    #1 Vmgobinath, Nov 29, 2019
    You need a Servo capable Grbl build, stock Grbl does not support Servos. See cprezzi/grbl-servo
    Then control it with M3 Sxxx where xxx = number between 0 and 255
    Vmgobinath likes this.
  3. Vmgobinath
    Thanks a lot. I will try and tell you the feedback.
  4. Vmgobinath
    Sorry to say. Still not working M3 or M5
    Please support
    That developer (cprezzi) does not offer support, so you will need to play with it on your own, or perhaps the supplier of your machine/controller can offer advice.
    Compile and upload. Perhaps you did not upload correctly?
    Or have it wired wrong?
    Are you sending M3 Sxxx (not M3 on its own)
    Or replace your controller with an OpenBuilds BlackBox BlackBox Motion Control System
    then you can use: OpenBuilds BlackBox 4X Documentation
  6. Vmgobinath
    Thanks alot. One more time I will upload and try.
    I ahve tried M3/ M03 / M3S1000 / M03S10000/ M03225/ M3 225
  7. Vmgobinath
    Still not working
  8. Vmgobinath
    Wow worked out ......$32 - laser was enabled and set to 0 Now working
    Thanks a lot for your kind support.
  9. Vmgobinath
    Oops stop working when I tried to universal gcode sender
  10. Vmgobinath
    Servo working very fine with following code
    Conclusion :
    1. Servo Motor is fine
    2. Connection is Fine
    3. Power for Servo also ok
    May be issue
    .1 GRBL command
    2. UGS - Options
    3. Current Settings
    Code:
    #include <Servo.h>
    Servo servo;
    int angle = 0;
    void setup() {
    servo.attach(11);
    servo.write(angle);
    void loop()
    // scan from 0 to 180 degrees
    for(angle = 0; angle < 80; angle++)
    servo.write(angle);
    delay(15);
    // now scan back from 180 to 0 degrees
    for(angle = 50; angle > 0; angle--)
    servo.write(angle);
    delay(15);
    Doesnt UGS or your gcode include a $32=1 somehow? (overwriting your settings back to laser mode)
    Use software.openbuilds.com instead
  12. Vmgobinath
    Thanks alot.. working fine now
  13. Vmgobinath
    I have connected one servo motor with pwm pin (D11). I want to connect one more servo ..is it possible ? If yes which pin and how to control via gcode ?
    All those questions are limited by Grbl's functionality, it has only one PWM output by default (stock grbl uses that pin for spindle and laser, cprezzi's fork uses it for servo pwm) - see gnea/grbl for details on how the available pins are used
