How to start using ACME lead screw with delrin nut block
Discussion in 'Tutorials' started by winand, Nov 4, 2014.
  1. winand
    winand Well-Known
    Today i received my materials for building my 3D printer.
    It was very well packed! - thumbs up!- (unfortunately had to pay $39 customs duty on top the $50 shipping)
    When trying the delrin nut block on the lead screw, it does fit, but it's very tight!
    By hand i can only twist the block on the screw until the screw is starting to come out on the other side.
    Then my hand starts losing grip on the screw and i can't get it any further.
    Do i have to wear the blocks in in some kind of way (run the blocks up and down using a drill), should i lubricate them right from the start? (and if so, with what?)
    Please help me out?
    #1 winand, Nov 4, 2014
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Hi Winand,
    They have been made tight and will loosen-up (bed-in) with use.
    Running them back and forward with a drill a few times (no lubrication necessary) will do the trick. ;)
    Tweakie.
  3. winand
    winand Well-Known
    Great, will try that!
  4. winand
    winand Well-Known
    D*mn, spent over 10 minutes turning the blocks back and forth over the 1 meter lead screw..
    They seem to loosen up just a tiny little bit, but i still can't turn them by hand?
    I don't want that all my stepper motors force goes into moving the block over the screw :)
    For my CNC router i used a polish stainless M10 screw with a delrin block made for it.
    That one was gliding like butter..
    Any other tips?
  5. Rick 2.0
    Can you provide a photo or internet link showing the style of the nut?
  6. dddman
    dddman Journeyman
    Let me guess... UPS? Just for fun, from where to where was the shipping?
  7. winand
    winand Well-Known
    @Rick2.0: The nut is the Openbuilds nut, the lead screw the Openbuilds lead screw.
    The nuts were ordered however at iprototype.nl a distributor of openbuilds material since the nuts were out of stock on the openbuildpartstore.
    I now have experimented with some lubrication, i used graphite lock lubricant spray.
    It's much better now! strange though that lubrication seems necessary.
    @dddman; Shipping was UPS from the USA to The Netherlands..
  8. Rick 2.0
    Interesting. I tend to prefer the V-Slot Acme Nut Plate as all the nut blocks I have received are so loose that if I hold them vertically, a 1m stick of TR8*8 will actually spin itself through under its own weight. It appears there are some serious quality control issued in the manufacture.
  9. WatchingWasaga
    I'n assembling a 1515 and the lead screws seem quite tight and a little difficult to turn by hand. Do the nut blocks loosen up a bit with use? Thanks
  10. Alex Chambers
    Yes they do loosen up. Hold the leadscrew in a portable dril, lubricate the leadscrew with DRY ptfe or silicone spray and run the leadscrew back and forth until it runs more freely.
  11. WatchingWasaga
    Thank you Alex.
