My first CNC
Discussion in 'CNC Mills/Routers' started by joefroooo, Jan 6, 2020.
  1. joefroooo
    joefroooo New
    I have been working on my CNC using extrusions and wheels from Open Builds. I wanted a machine that can cut balsa, plywood to assist me in building RC airplanes for my hobby. The machine has a 50 inch cut length, 16 inch wide and 4.5 Z height.
    All the plates were drawn up by myself and cut by my friend Mike on his CNC. So far I am quite happy with the movement of all axis using the Open Build control and Black box.
    Peter Van Der Walt and Rick 2.0 like this.
  2. joefroooo
    joefroooo New
    I am using 1/2 10 5 start lead screw from Mcmaster Carr. I made the Delrin nuts and 4 extras for down the road and so far with jogging all axis around the nuts are smooth and quiet. Everything is very repeatable with no backlash. I need to get some limit \ homing switches and hook up a emergency stop switch. Once I get them I can start my calibration on the machine.
    Im still unsure on what I am going to use to spin my cutter.
    Joe
    Gofertpc and Peter Van Der Walt like this.
