Lead screw whipping on LEAD CNC
Discussion in 'CNC Mills/Routers' started by jeffmorris, Jan 11, 2020.
  1. jeffmorris
    jeffmorris Journeyman
    I found out that one of the lead screws on one of the Y-AXIS were whipping on my modified LEAD CNC. How can I fix this problem? I'm not sure if I can turn the end plates around so that the bearings and collars are outside because the lead screws are not long enough. I know that some people put 12mm lead screws on their machines but they had to make custom nut blocks.
  2. Rick 2.0
    While whip is a natural part of the process it can be minimized by straightening and aligning the screws as much as possible. A general description of the process can be found here.
  3. Wallied
    Wallied New
    The end plate switcheroo can be done by cutting your extrusions slightly shorter.
  4. jeffmorris
    Are there stores in USA that sell 1100mm Tr8*8-2p (4 starts) lead screws?
  5. Rick 2.0
    Well, the Lead shouldnt suffer from whip, and its only one one axis you say? Sounds less like a whipping issue and more like a bent screw (;
  7. jeffmorris
    I think that OpenBuilds should sell longer lead screws so that the bearings and lock collars are outside the end plates.
    If you reach out to http://support.openbuilds.com/support/home you can order custom lengths
  9. jeffmorris
    I did a quick doublecheck for you, to see why I remember they do:
    The DO do custom lengths, BUT the maximum length is 1040mm. You can order custom lengths, but has to be less than 1040mm. Good to know :) but yeah, then doesnt help you with your plan, sorry.
    Wallied has a interesting plan though (;
  11. jeffmorris
  12. Christian James
    Christian James Journeyman
    Have a look at my build log below and scroll down to "Lead-screw Mod and nut blocks", dunno if that helps?
    Workbee "style" 1010 cnc
