WorkBee 1015 - G-code Error in Control Software and Fuison 360
Discussion in 'CNC Mills/Routers' started by yanai navon, Mar 3, 2020.
  1. yanai navon
    Hi I just finished building my lovely CNC workbee 1015.
    I'm exporting GRBL FILE from fusion 360 to Control WorkBee software, I'm setting up Zero Point. and then Run job.. and I got this message - G-code error (adding PRTSCRN)
    Thanks For help.
    Yanai
  2. Alex Chambers
    What controller, what post processor?
  3. yanai navon
    Controller - Open Builds
    Post processr - can you guide me in this ? i need post-processor for fusion 360
  4. Alex Chambers
    This link will take you to the correct post processor. You need to enable cloud in your preferences in Fusion.
    Fusion 360: grbl post processor install (the easy way)
    PS, next time you need to post a screenshot copy it into something like paint and crop it - your pic was too small to read on my phone. :)
    Alex, bigger crops help see whats in the background :) Better post both hehe.
    In this case background wasnt of interest but you'd be surprised how useful a fullscreen crop is in seeing unrelated things sometimes
  6. David the swarfer
    You are seeing that error because GRBL (what runs on the BlackBox) does not support toolchanges, the code is saying
    T1 ; be ready to switch to tool 1
    M6 ; switch to tool 1 now (the split nature of this makes sense for slow moving automatic tool changers where you can position tool 1 for changing long before actually needing it, thus saving time)
    you can turn tool changes off in the post or use the OB post given by Alex.
    f360/ob control
    (and the post above that one)
  7. Alex Chambers
    But I did work out what the problem was even though the relevant text was only two pixels high:D
