UGS Platform doesn't home.
Discussion in 'CNC Mills/Routers' started by ajkelsey, Mar 1, 2020.
  1. ajkelsey
    ajkelsey New
    As a result of the USB errors I get using Estlcam (mentioned in my previous thread), I am attempting to use UGS Platform. For some reason, when I try to home the machine, it moves right through the end switches and doesn't stop. I can home just fine using Estlcam. I know Estlcam makes changes to the firmware, but I don't know what it does. I do have to restore the old firmware to get UGS to communicate with the controller. I am using GRBL 1.1F.
  2. Christian James
    Christian James Journeyman
    Have you looked in UGS diagnostics to check if homing is enabled in the firmware? (maybe 2nd last setting - "settings: is homing enabled"
  3. ajkelsey
    ajkelsey New
    It is enabled. Along with hard limits. UGS will throw an error if you try to home without it enables.
  4. Gary Caruso
    Ajkelsey,
    Not clear, so you did restore? If you can see your GRBL settings than it should be restored correctly.
    Post your GRBL settings here.
    What type and speck PC are you using, did you disable usb suspend? what baud are you connecting to?
    Did you try reinstalling the drivers? Try these instructions regardless if you are using an Arduino or BlackBox (same driver)
    Gary
  5. ajkelsey
    ajkelsey New
    I did restore. UGS won't connect with Estlcam firmware.
    **** Connected to COM4 @ 115200 baud ****
    Grbl 1.1e ['$' for help]
    $0 = 5 (Step pulse time, microseconds)
    $1 = 25 (Step idle delay, milliseconds)
    $2 = 0 (Step pulse invert, mask)
    $3 = 0 (Step direction invert, mask)
    $4 = 0 (Invert step enable pin, boolean)
    $5 = 0 (Invert limit pins, boolean)
    $6 = 1 (Invert probe pin, boolean)
    $10 = 1 (Status report options, mask)
    $11 = 0.010 (Junction deviation, millimeters)
    $12 = 0.002 (Arc tolerance, millimeters)
    $13 = 1 (Report in inches, boolean)
    $20 = 0 (Soft limits enable, boolean)
    $21 = 1 (Hard limits enable, boolean)
    $22 = 1 (Homing cycle enable, boolean)
    $23 = 4 (Homing direction invert, mask)
    $24 = 500.000 (Homing locate feed rate, mm/min)
    $25 = 8000.000 (Homing search seek rate, mm/min)
    $26 = 5 (Homing switch debounce delay, milliseconds)
    $27 = 500.000 (Homing switch pull-off distance, millimeters)
    $30 = 10000 (Maximum spindle speed, RPM)
    $31 = 0 (Minimum spindle speed, RPM)
    $32 = 0 (Laser-mode enable, boolean)
    $100 = 80.000 (X-axis travel resolution, step/mm)
    $101 = 80.000 (Y-axis travel resolution, step/mm)
    $102 = 250.000 (Z-axis travel resolution, step/mm)
    $110 = 500.000 (X-axis maximum rate, mm/min)
    $111 = 500.000 (Y-axis maximum rate, mm/min)
    $112 = 500.000 (Z-axis maximum rate, mm/min)
    $120 = 800.000 (X-axis acceleration, mm/sec^2)
    $121 = 800.000 (Y-axis acceleration, mm/sec^2)
    $122 = 82.550 (Z-axis acceleration, mm/sec^2)
    $130 = 307.975 (X-axis maximum travel, millimeters)
    $131 = 630.377 (Y-axis maximum travel, millimeters)
    $132 = 82.500 (Z-axis maximum travel, millimeters)
    ok
    Using a Windows 10 PC. AMD Athlon 5350 with 2 GB Ram.
    USB suspend was enabled. I have disabled it and will test the change.
    Baud 115200.
    I will reinstall drivers and report back.
    What exactly am I following in the instructions you linked?
  6. ajkelsey
    ajkelsey New
    Ok. I have reinstalled the USB drivers, disabled USB suspend, and rebooted. UGS still doesn't react to the end switches.
  7. Alex Chambers
    I am definitely not an expert on this, so I won't pretend to be able to answer your problem. I did notice though that you have the homing pull off distance ($27) set at 500 mm.
  8. Gary Caruso
    The 500mm and the speed for home seek is much too high 8000mm/min and your max speed is 500 so might be a bug? Set your, seek speed to 500 and your pull off to 5mm.
    Also 80steps per mm on x and y and 250 on z are odd numbers? Are they correct?
    Is this a belt machine? Or screws? What’s your microstep setting?
    Gary
    Is that supposed to work? Though Estlcam firmware works with EstlCAM software only?
  10. Gary Caruso
    Right, he was replying to my question if he had reverted back to grbl. I’ve done this successfully (just had to try the restore function in estlcam) but there are ways to muck it up, I suppose.
    Gary
    My bad! :) Sorry
  12. ajkelsey
    ajkelsey New
    Ok. I'll try the new settings for seek speed and pull off when I get home.
    I don't remember if I ever set the steps after I installed the latest grbl firmware. I'll dig I to that some more tonight.
    My x and y are belts and my z is a screw.
  13. ajkelsey
    ajkelsey New
    My microsteps are 1/8. I am trying to calibrate the steps using the wizard. I'm not quite sure I understand it. Is the wizard trying to move the axis in 1mm increments and I adjust the steps until that occurs?
  14. ajkelsey
    ajkelsey New
    Ok. So the first thing I did was to change the seek and pull off settings. That seemed to work at first. But when I went to change the homing direction invert setting to the machine homed in the correct direction, it stopped working. After that is when I went through the setup wizard. I think I have the steps set correctly. When at the screen to home, the Z axis would move in the opposite direction it should and would stop after about 1 cm of movement. If I kept at it until it made it to the endstop, the endstop would not react.
  15. Gary Caruso
    Sounds like you need to invert your home switch logic? $5
    z home should be up.
    Do you have capacitors installed to suppress false limit triggers?
    Gary
  16. ajkelsey
    ajkelsey New
    I have optocouplers on the way. I have my Z home set to positive. I verified this by jogging the machine and it travels the correct direction that way.
  17. ajkelsey
    ajkelsey New
    Tonight, I tried a GRBL controller on my phone. When attempting to home, the Z traveled in the wrong direction and I received an error stating that it was unable to clear the end switch. So it sounds like the controller believes the end switch is still engaged. I suppose that is a noise issue and I'll have to wait until my optocouplers arrive for that. It's strange that Estlcam doesn't have this issue though.
  18. ajkelsey
    ajkelsey New
    I think I figured it out. The Z limit switch pin on the arduino is not operational. I checked the Z limit switch plugged into other locations and it works. I tried other limit switches plugged into the Z pins on the shield and they dont work. I did the same directly to the arduino with the same behavior.
  19. Christian James
    Do you have pull-up resistors installed for the limit switches to the Arduino?
  20. ajkelsey
    ajkelsey New
    I just installed optocouplers for the limit switches.
  21. Semper Why
    This is probably unrelated to your difficulties, but that is a surprisingly low amount of RAM for a desktop Win10 machine. I normally run 8GB on my virtual machines, 12 GB on my HTPC and 20 GB on my main system.
  22. Peter Van Der Walt
    Which shield? Chinese fake of the Protoneer shield? If so, then note the chineses still have the old Grbl 0.8 pinout shield with different pinout (pins swapped between grbl 0.8 and 0.9 onwards)
    You are aware of the change of pinout between grbl 0.8 that the chinese CNC shield was based on, and v0.9 onwards?
    Giarc and Gary Caruso like this.
  23. ajkelsey
    ajkelsey New
    It's an old PC and it doesn't need any more RAM than what it has.
  24. ajkelsey
    ajkelsey New
    I tested the pinout on the arduino itself. No voltage. Currently have a Keyestudio CNC shield plugged in.
  25. ajkelsey
    ajkelsey New
    ‍♂️ I think you are correct here. The new shields use D12, right? This Keyestudio and this other Chinese shield are marked as using D11 for the Z end switch. I have a feeling that the Estlecam firmware was accounting for this and that is why it worked.
  26. Peter Van Der Walt
    Agreed its not related to the current issue of course, but it is a fair heads up, wait till you try an advanced 3D finishing toolpath from Vectric for example. Easily close to a million lines for a 300x400mm plaque. Then you might want to consider upgrades :)
  27. ajkelsey
    ajkelsey New
    Ok. I was able to get the original firmware onto the controller. Even though it is GRBL 1.1, I think they modified it to work with the old pin layout. I'm going to look for a real version 3 CNC shield. The good news here is that I am able to get the machine to home in UGS. I appreciate the help in getting this sorted out. I'm certainl;y learning the ins and outs of everything through this process.
  28. ajkelsey
    ajkelsey New
    Yeah, I don't have those kinds of plans for this CNC right now. Should I advance to that kind of thing, I'll make the necessary upgrades.
  29. ajkelsey
    ajkelsey New
    BTW, any advice on where to find a legit GRBL .9+ compatible shield?
  30. Peter Van Der Walt
