Move Function not working correctly
Discussion in 'CAM' started by gunsett, Mar 15, 2020.
Tags:
  1. gunsett
    gunsett New
    Trying to use mouse move mode on my dxf to 0,0 and it has a crazy leg going on.
    Exported from Fusion 360 Files included
    Unfortunately there are sometimes points in a DXF that can confuse the parser and its nearly impossible to cover every possible edge case.
    Saving-as a older version of the DXF format (say DXF R14) or manually converting it to Polylines using the Explode commands in qcad/draftsight/autocad may help
    You could also use your CAD application to move it to 0,0
  3. gunsett
    gunsett New
    Thanks for the quick response ! Worked like a charm
