I need something a bit tougher and bigger than an OX, and am at work modifying sketchup plans for the oversized aluminium gantry plates and brackets. Once these plans are done I need someone to at least check the gcode and then cut them out for me. I figured that it's probably better to try this than to build a small machine just in order to make the bigger one. Any takers?
