OpenBuilds Control Size Check
Discussion in 'CAM' started by Timothy Pinto, Mar 6, 2019.
  1. Timothy Pinto
    I was getting started with OpenBuilds Control software. What is the "Size Check" feature do? I clicked on it and my router gantry started moving - I E-stopped it before it quit moving.
    Draws the bounding box of where the job is in XY space
    Helps you to check if the job fits your stock.
    Or for laser, helps to see if you are right where you want to burn
    Position it above the workpiece, do the setzeroes. Then run checksize after loading gcode
  3. Timothy Pinto
    I can see where this would be helpful. Thanks.
  4. JamesBoone
    I'm having an issue with this feature recently. When I press check size the gantry will take off on the x-axis and not stop until I hit the emergency stop.
    If I just run the program without checking the size it will run fine and cut what needs to be cut.
    @Peter Van Der Walt any idea?
    Did you remember to SetZero before the Check Size?
  6. JamesBoone
    I always set zero then check size, adjust if necessary, then run job.
    Sweet, so next quick test. Recently we introduced mm/inch, could be that
    Send a G21 from the Serial Console before Checksize and see if that fixes it?
    If it does i know what to fix when I get to work later (;
  8. JamesBoone
    Thanks, I'll check in the morning (PST) and follow up.
    I checked and its not inch/mm :)
    Can you post the gcode file? Maybe something in it adding to the 3D view's boundary box, beyond where the job is.
  10. Ron Marshall
    I know this is an old post but I just built my WorkBee and am having the same issue.
  11. Ron Marshall
    Forgot to mention. I created the file in Aspire using the Grbl (inch) PP.
    Note: I created GCODE in OpenBuilds CAM and it is acting correctly. Is it the wrong PostProcessor?
    Note 2: Went back into Aspire and changed the PP to Grbl (mm) and it works correctly. Not sure I like it that my 3D shows to be in mm in OpenBuilds Control software.. I am an inches type guy.
    #11 Ron Marshall, Jan 27, 2020
    mm gcode does render a little better in the 3D viewer, but thanks for submitting a test case file, will add it to the list of edge cases and see if we can improve viewer for inch gcode in future versions
  13. Ron Marshall
    As an update from my testing. If I set my start point as the center of the board and use the Grbl (mm) PP, it works fine. It outlines my carving space. If I use the Grbl (in) PP, the gantry takes off to the front left corner until I abort it. Sending G21 seems to have no affect. Definitely seems to be the difference between inch and mm.
    No updated code available yet, keep an eye on the Changelog in the troubleshooting tab, you'll see a note there when improvements has been made to inch mode/check size
    Updated the codebase with a fix for the Checksize when in Inch mode: It'll be live in v1.0.207 and that is expected to be released maybe today, or tomorrow at the latest. Thanks for reporting the issue and even more thanks for your patience in waiting for the fix!
    @Alex Chambers FYI too - the Vectric Inch mode post will now play nice with the updated Checksize fix, so we can recommend it without fear now (referring to Aspire to OB Control)
  16. philcava
    philcava New
    Hi, after update of Openbuilds CONTROL to v1.0.2015, the check Size don't work anymore.
    Also, in Wizards & Tools, Surfacing, after input all, software don't let see the work in consol.
    When run the Job he do it fine but you can't follow the process.
    Hmm, wasn't any direct changes in that last couple versions, so
    1) press F12 or Ctrl+shift+I to open devtools
    2) Check Console tab for clues while using these functions
    I am on leave today but will check deeper tomorrow
  18. philcava
    philcava New
    Thanks Peter, After check I don't see the 3D view also, see attached picture
  19. Peter Van Der Walt
    Either 1) accidentally disabled 3D viewer from Troubleshooting tab > diagnostics menu
    Or 2) incompatible GPU
    Checksize depends on the 3D view to calculate extents of the job, and of course the preview of the surfacing job as well.
  20. philcava
    philcava New
    Thanks Peter, it is not a accidentally disabled 3D viewer because I check it. Why it work with version v1.0.214?
    Can I download the old version?
  21. Peter Van Der Walt
    Newer versions of Electron/Chromium updates the blacklist of bad GPUs (Google Groups) as they build up lots of reports from users with a certain GPU that misbehaves / doesn't properly support WebGL, etc: What GPU do you have in there by the way?
    It could be a case of just updating your GPU drivers, when was the last time you did that? I assume the day the PC was built or last reformatted and never again since? The blacklist takes several factors into account, driver version being one of them
    #21 Peter Van Der Walt, Mar 25, 2020
  22. Ron Marshall
    My viewer works after I upgraded. The only issue was the upgrade failed so I installed from scratch. Had to reset some GRBL and re-calibrate. I didn't use the Check size. I will try today.
  23. Peter Van Der Walt
    Grbl settings is not stored in control. Its stored in the EEPROM on the Atmega32p on the controller running Grbl (; So no need to change those if you are just working with the host applications
  24. Ron Marshall
    OK Thanks. I knew that but assumed that when I re-installed it that it sent default settings. What happened was, when I opened CONTROL, it said there was an upgrade available and it upgraded. But when I went to open CONTROL, none of my shortcuts worked from the Desktop or from Programs. I just downloaded it and installed it. I am running PC with Win10 in case you wanted to know.
  25. Brian Rowbotham
    Hello, Greetings from Johannesburg, South Africa.
    I've recently built a controller for a NEJE 7W laser, 'cos it comes with a proprietary board which is pretty useless unless you want raster or very limited gcode usage. Anyway, it has got new life with the OpenBuilds control S/W and an Arduino/CNC Shield, which runs beautifully. Two issues to mention:
    1. The 'Size check' does not turn on the laser - so it's a little difficult to see the physical boundaries, or line up edges. Perhaps a drop-down to allow the choice of tool activation? And possibly keep it running the perimeter until stopped to allow adjusting of the workpiece.
    2. The 'Tool On' does provide this drop down - but seems to be out of scale as even at 15%, the beam burns material and I need to adjust with the power slider to prevent marking the work. Of course - then I forget to put it back to 100% :(
    I have created two macros to turn on the laser at 1%, and then to turn it off again - this is my intermediate fix.
    Great work,
    Rgds,
    Brian
  26. Peter Van Der Walt
    Chinese diode drivers may lack linear response.
  27. Brian Rowbotham
    Agree, but then if there is a way to set the modulation, the non-linearity could be manually adjusted. On my macro I set it to 1/255 (M3 S1) and then it does not burn - although the dot is clear and easy to focus.
  28. Peter Van Der Walt
    PWM Freq? See gnea/grbl
    We just use Grbl as-is, where the PWM is a linear response and works perfectly with well designed drivers (JTech, Optlaser, etc)
    We provide settings down to 5% - for most diode lasers thats perfect
    Thats what macros are for. Customize away
    You can always use the Javascript macros functionality to a) turn laser on, b) checksize OpenBuilds/OpenBuilds-CONTROL and c) turn it off again
    You can do a looped run too: see Help getting started with Javascript Macros in Control... for a similar example
    #28 Peter Van Der Walt, Dec 13, 2020
  29. Brian Rowbotham
    Ah, thanks - that'll work. Ill delve into that code and write a macro to do it in one action.
    I tried the modulation with other GRBL controllers and they all appear to be quite linear - my feedback was simply an observation - no criticism intended.
    Thanks again for an excellent utility.
  30. Brian Rowbotham
    Hello,
    I've been struggling with the latter part of turning off the laser and am asking for help please.
    Initially I had a socket.emit('runCommand', "M5\n"); after the 'runJob' but that created an error 09 - Alarm or Jog so then I tried to wait for the job to finish but just cannot get it right.
    Here is the macro with various options commented out:
    var bbox2 = new THREE.Box3().setFromObject(object);
    console.log('bbox for Draw Bounding Box: ' + object + ' Min X: ', (bbox2.min.x), ' Max X:', (bbox2.max.x), 'Min Y: ', (bbox2.min.y), ' Max Y:', (bbox2.max.y));
    var feedrate = $('#jograte').val();
    if (laststatus.machine.firmware.type === 'grbl') {
    var moves = `
    $J=G90G21X` + (bbox2.min.x) + ` Y` + (bbox2.min.y) + ` F` + feedrate + `\n
    $J=G90G21X` + (bbox2.max.x) + ` Y` + (bbox2.min.y) + ` F` + feedrate + `\n
    $J=G90G21X` + (bbox2.max.x) + ` Y` + (bbox2.max.y) + ` F` + feedrate + `\n
    $J=G90G21X` + (bbox2.min.x) + ` Y` + (bbox2.max.y) + ` F` + feedrate + `\n
    } else {
    var moves = `
    G90\n
    G0 X` + (bbox2.min.x) + ` Y` + (bbox2.min.y) + ` F` + feedrate + `\n
    G0 X` + (bbox2.max.x) + ` Y` + (bbox2.min.y) + ` F` + feedrate + `\n
    G0 X` + (bbox2.max.x) + ` Y` + (bbox2.max.y) + ` F` + feedrate + `\n
    G0 X` + (bbox2.min.x) + ` Y` + (bbox2.max.y) + ` F` + feedrate + `\n
    G90\n`;
    socket.emit('runCommand', "M3S1\n"); // Laser on minimum power
    socket.emit('runJob', {
    data: moves,
    isJob: false,
    fileName: ""
    // socket.emit('runCommand', "M5\n"); This was the first attempt to turn off laser - it works as standalone macro
    // console.log('Running mode: ' + ((status.comms.runStatus)); // Complains bitterly about 'Uncaught TypeError: Cannot read property 'runStatus' of undefined'
    // while (status.comms.runStatus = 'Running' ) {};
    // socket.emit('runCommand', "G4 P0.5\n") // This also creates an error 09
    var lzrOff = 'M5\n'
    data: lzrOff,
    isJob: false,
    fileName: ""
    TIA,
    Brian
