Fatal error on write to GRBL
Discussion in 'Control Software' started by Johnopc21, Mar 29, 2020.
  1. Johnopc21
    Johnopc21 New
    Hi I am new to all of this and not computer clued up I have a problem with my 4 axis foam cutter
    Part way through the cut my cutter stop and I get the following Message
    Fatal error on write to GRBL a device attached to the system is not functioning
    Can someone tell me what is happening with my foam cutter?
    Thanks in advance
  2. Alex Chambers
    We will need more info to help @Johnopc21. What controller (electronics) are you using? What software do you use to send your code to the machine? If it connects with a USB cable it's worth trying a different cable.
    Sounds like the port went away. Windows shuts down USB port if they suffer EMI, Overcurrent or short circuits.
    EMI - move USB cables away from power, motor, mains, etc wires
    Short circuit - if you have incorrectly wired limits you can short 5v to GND (depending on what controller you have)
  4. Johnopc21
    Johnopc21 New
    Thank you both for your advice I have taken both picece of advice I have changed the USB cables and disconeced them from both the computor and the mother board over night to see if this works I will let you now if it works
    Regards
    John
    Leaving them out for the night won't make a difference
    Look at where you route the USB cable over the desk, avoid laying it parallel or near power/motor/mains wiring for example
  6. Johnopc21
    Johnopc21 New
    Thanks Peter
    I will try all advice given to me I have just received new USB cables Iwill use the to see if there was a problem with the old cables
    Thanks again
    John
