Update Duet web interface?
Discussion in 'CNC Mills/Routers' started by Handlebar, Mar 28, 2020.
  1. Handlebar
    Handlebar New
    Maybe a stupid question, but how on earth do I update the web interface on my Duet with my Ooznest Workbe?
    I've downloaded every file and done everytning that's stated in the manual, but still no luck.
    Would be magic to get some millin' done in these isolated times.
    Thanks all!
  2. Alex Chambers
    You didn't say, but I assume you are updating to version 7, and that you have followed the instructions and loaded the system settings for your machine to the Duet controller, and that you now can't see the new User Interface. If that is the case you have missed the step in the attached pic - the user interface update is a separate step. Using the Duet Web Control upload that zip file - you don't need to unzip it first.
  3. Handlebar
    Handlebar New
    Hi Alex,
    Thanks so much! I'll look into this straight away. I really thought I did this, but I must've missed it somehow. I'll try! Thanks!
  4. Handlebar
    Handlebar New
    Worked like a charm! Wonderful!
    Now, can I connect to my Workbee from my iMac that I have in my shop? Everything is working fine with my Windows laptop, but I guess a chrome window on an iMac will work just as good?
    Thanks again!
  5. Alex Chambers
    Any web browser can connect to the Duet Web Control so you should have no problems.
  6. Handlebar
    Handlebar New
    Perfect, that's great news! Any clues where I can find a way to set that up on the mac?
    I'm trying to change the Ethernet settings to the same as on the Windows machine, but no luck.
    Many thanks! // martin
  7. Alex Chambers
    You did make a note of the IP address you set for the Duet? If not I'll try to remember how to find it (it's a long time since I did it). If you type that address into your browser it should find the Duet Web Control - bookmark it.
  8. Handlebar
    Handlebar New
    I did, and I copied it exactly from my Windows computer but still no connection.
    I followed Ryan Locks' guide on YT and it worked just fine on my Windows machine, but not on the mac.
    Thanks!
  9. Alex Chambers
    Not sure what the problem is @Handlebar , but once you have set up the Duet any browser can access it if you type the address into it. The Duet Web Control is just a web page like any other. Do you have the Ethernet or WiFi version of the Duet.
  10. Handlebar
    Handlebar New
    Thank you Alex for taking the time to reply!
    The problem is this:
    WINDOWS: 192.168.2.14 -> Workes fine!
    MAC OSX: 192.168.2.14 -> Doesn't work.
    Not sure what I'm doing wrong, probably it's just something super simple. Thanks for helping a noob out!
    Warm regards! /martin
  11. Alex Chambers
    You didn't say what version of the Duet you have, but people with the WiFi version are controlling their Duet with all sorts of devices. How is your Mac connected to you lan?
  12. Handlebar
    Handlebar New
    Ah, sorry about that. I've got the Duet 2 Ethernet version directly connected to my computer with an ethernet cable.
    Just like you say it seems to be quite an easy task, so I guess it's me. Thanks!
    Did you remember to set a static IP on the Mac?
    Check if the windows PC has a static IP?
  14. Handlebar
    Handlebar New
    Yes, at least I think I did.
    I set it to "Manual" and copied the IP. Though, I'm not sure if the "Router" field is the same as Gateway.
    Cheers!
    Which IP. Make sure you didnt set the Duet and Mac to have the same IP. Each has its own, same subnet
