YL620-A VFD Question
Discussion in 'General Electronics' started by DxN32, Apr 17, 2020.
  1. DxN32
    DxN32 New
    I’m currently running a 1.5kw spindle motor with the yl620-a vfd and would like to upgrade to a 2.2kw spindle. Can my current yl620-a power the 2.2kw with some parameter changes, or will I have to buy a new vfd along with the 2.2kw spindle.
    it would be nice if I could use my current vfd since my settings and wiring are already dialed in and just make the setting changes needed to power the 2.2kw spindle.
    thanks in advance
  2. Ryan Matthes
    I have the 2.2 kw spindle and this is the vfd they sent with mine. I assume it should be fine you might only have to make some changes in the vfd. I have this vfd. I’m trying to set this up at the moment. If you can send me anything that might be helpful that would be greatly appreciated. Do you have a black box? What wires did you send the 0-10v to the vfd?
    #2 Ryan Matthes, Apr 22, 2020
    Checkout (you don't need a PWM to 0-10v converter, BlackBox already has 0-10v output built in)
    (0-10v to VI1)
    Steveathome likes this.
