1200X600 SPHINX
Discussion in 'CNC Mills/Routers' started by blue25, Dec 12, 2017.
  1. blue25
    blue25 New
  2. blue25
    blue25 New
    how is to adjust eccentric spacer? spent hours but still can't get it right. also need help to tighten the wheels with the bolt
  3. blue25
    blue25 New
    Progress per today
    I don't know if the wheel tension right, but i have try with cordless drill and the plates moving.
    But the leadscrew is wobble. Is that because it too long? Will it affect the performance?
    Need advice here
    Regards,
  4. Kevon Ritter
    Kevon Ritter Veteran
    I'm sorry that you haven't gotten a response. An 8mm lead screw simply can't handle a length this long. Alternatives include 10mm, 12mm, 3/8", and 1/2" lead screws.
  5. ChadRat6458
    You might try putting some tension on the lead screw.
  6. Gary Caruso
    If you have the length and it looks like you might, setup the screw collars so they put the screw in tension instead of compression, it does help.
    You will need to swap the plates around.
    Michael.M likes this.
  7. Srednasoft
    Did it work out well with the 2.2kw water cooled spindle on your Sphinx?
    I have ordered the same type of spindle for my Kyo Sphinx, but I’m worried about the weight.
  8. Kevon Ritter
    I would not recommend anything above 1.5kW. Honestly, even an 800W will be more than enough for this platform, especially if you go with a larger work area.
  9. Srednasoft
    The Size of my machine is 600x800 so it’s not super large.
    On my old machine I used a Makita router and I have many milling bits with 8mm shank. The ER11 1.5kW has a max collet size of 7mm. That is why I chose the ER20 model. But I can see the weight could be a big problem. Around 5kg on that spindle:(
    I've got some ER11 8mm collets sitting on my desk, Aliexpress has them up to 10mm
    Srednasoft likes this.
  11. Srednasoft
    #11 Srednasoft, May 5, 2020
